[geos-commits] [SCM] GEOS branch main updated. 8b8b3da7a3d9fb8953ff60bc49aa0320d51ae45c
Wed May 13 12:12:56 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  8b8b3da7a3d9fb8953ff60bc49aa0320d51ae45c (commit)
      from  cf859843556dd76e9597c588543915b7aa7d7bc4 (commit)
revisions in full, below.
commit 8b8b3da7a3d9fb8953ff60bc49aa0320d51ae45c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed May 13 12:11:50 2026 -0700
    Limit recursion depth in WKT/WKB/GeoJSON readers
    Prevents stack overflow on malformed input.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index a1be8e65b..9488b4be9 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1147,6 +1147,7 @@ extern "C" {
         return execute(extHandle, [&]() {
             auto ids = clusters->getClusterIds(GEOS_CLUSTER_NONE);
             std::size_t* ids_buf = (size_t*) malloc(ids.size() * sizeof(std::size_t));
+            if (!ids_buf) return ids_buf;
             std::copy(ids.begin(), ids.end(), ids_buf);
             return ids_buf;
diff --git a/include/geos/io/GeoJSONReader.h b/include/geos/io/GeoJSONReader.h
index 41834f1dd..9d9d09d20 100644
--- a/include/geos/io/GeoJSONReader.h
+++ b/include/geos/io/GeoJSONReader.h
@@ -75,6 +75,7 @@ public:
 private:
     const geom::GeometryFactory& geometryFactory;
+    mutable int parseDepth_ = 0;
     std::unique_ptr<geom::Geometry> readFeatureForGeometry(const geos_nlohmann::json& j) const;
diff --git a/include/geos/io/WKBReader.h b/include/geos/io/WKBReader.h
index 58eeb8f74..3b97cb498 100644
--- a/include/geos/io/WKBReader.h
+++ b/include/geos/io/WKBReader.h
@@ -156,6 +156,8 @@ private:
     std::array<double, 4> ordValues;
+    int parseDepth_ = 0;
     std::unique_ptr<geom::Geometry> readGeometry();
     std::unique_ptr<geom::Point> readPoint();
diff --git a/include/geos/io/WKTReader.h b/include/geos/io/WKTReader.h
index 9fc86c978..bd4bc56cd 100644
--- a/include/geos/io/WKTReader.h
+++ b/include/geos/io/WKTReader.h
@@ -149,6 +149,7 @@ private:
     const geom::GeometryFactory* geometryFactory;
     const geom::PrecisionModel* precisionModel;
     bool fixStructure;
     void getPreciseCoordinate(io::StringTokenizer* tokenizer, OrdinateSet& ordinateFlags, geom::CoordinateXYZM&) const;
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 0f0817e32..1ab54dd9e 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -40,12 +40,15 @@ using json = geos_nlohmann::json;
 namespace geos {
 namespace io { // geos.io
+static constexpr int MAX_PARSE_DEPTH = 100;
 GeoJSONReader::GeoJSONReader(): GeoJSONReader(*(GeometryFactory::getDefaultInstance())) {}
 GeoJSONReader::GeoJSONReader(const geom::GeometryFactory& gf) : geometryFactory(gf) {}
 std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonText) const
+    parseDepth_ = 0;
     try {
         const json& j = json::parse(geoJsonText);
         const std::string& type = j.at("type");
@@ -66,6 +69,7 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonTe
 GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonText) const
+    parseDepth_ = 0;
     try {
@@ -121,6 +125,12 @@ std::map<std::string, GeoJSONValue> GeoJSONReader::readProperties(
 GeoJSONValue GeoJSONReader::readProperty(
     const geos_nlohmann::json& value) const
+    if (parseDepth_ >= MAX_PARSE_DEPTH) {
+        throw ParseException("Input property exceeds nesting depth limit");
+    ++parseDepth_;
+    struct DepthGuard { int& d; ~DepthGuard() { --d; } } guard{parseDepth_};
     if (value.is_string()) {
         return GeoJSONValue { value.get<std::string>() };
@@ -179,6 +189,12 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
 std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(
+        throw ParseException("Input geometry exceeds nesting depth limit");
+    ++parseDepth_;
     if (type == "Point") {
         return readPoint(j);
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 65ba6c4c1..d5683f2dc 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -252,13 +252,22 @@ WKBReader::read(std::istream& is)
 std::unique_ptr<Geometry>
 WKBReader::read(const unsigned char* buf, size_t size)
+    parseDepth_ = 0;
     dis = ByteOrderDataInStream(buf, size); // will default to machine endian
     return readGeometry();
 WKBReader::readGeometry()
+    ++parseDepth_;
     // determine byte order
     unsigned char byteOrder = dis.readByte();
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index 3c1d6fa69..a49b2cf98 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -49,9 +49,12 @@ using namespace geos::geom;
 namespace geos {
 WKTReader::read(const std::string& wellKnownText) const
+    parseDepth_ = 0;
     CLocalizer clocale;
     StringTokenizer tokenizer(wellKnownText);
     OrdinateSet ordinateFlags = OrdinateSet::createXY();
@@ -302,6 +305,12 @@ WKTReader::getNextWord(StringTokenizer* tokenizer)
 WKTReader::readGeometryTaggedText(StringTokenizer* tokenizer, OrdinateSet& ordinateFlags, const GeometryTypeId* emptyType) const
+    ++parseDepth_;
     std::string type = getNextWord(tokenizer);
     std::unique_ptr<Geometry> geom;
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index 2d474d3d7..c419eaf55 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -619,4 +619,21 @@ void object::test<40>
     ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 3u);
+// Deeply nested GeometryCollection should throw ParseException (not stack overflow)
+template<>
+template<>
+void object::test<41>
+    std::string geojson;
+    for (int i = 0; i < 200; i++) geojson += "{\"type\":\"GeometryCollection\",\"geometries\":[";
+    geojson += "{\"type\":\"Point\",\"coordinates\":[0,0]}";
+    for (int i = 0; i < 200; i++) geojson += "]}";
+    try {
+        geojsonreader.read(geojson);
+        fail("Expected ParseException for deeply nested GeoJSON");
+    } catch (const geos::io::ParseException&) {}
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index 6628351a8..ebdba7a40 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -7,11 +7,13 @@
 // tut
 #include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
 // geos
 #include <geos/io/WKBReader.h>
 #include <geos/io/WKBConstants.h>
 #include <geos/io/WKBWriter.h>
 #include <geos/io/WKTReader.h>
+#include <geos/io/ParseException.h>
 #include <geos/geom/CompoundCurve.h>
 #include <geos/geom/CurvePolygon.h>
 #include <geos/geom/PrecisionModel.h>
@@ -838,5 +840,29 @@ void object::test<36>
                    "ParseException: Expected SimpleCurve but got Point");
+template<>
+template<>
+void object::test<37>
+    set_test_name("ParseException on deeply nested WKB collection avoid stack overflow");
+    // Each GeometryCollection header (NDR): byteOrder=01, type=07000000, numGeoms=01000000
+    const std::vector<unsigned char> header = {0x01, 0x07, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00};
+    // Innermost empty GeometryCollection: byteOrder=01, type=07000000, numGeoms=00000000
+    const std::vector<unsigned char> inner = {0x01, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
+    std::vector<unsigned char> buf;
+    for (int i = 0; i < 200; i++) buf.insert(buf.end(), header.begin(), header.end());
+    buf.insert(buf.end(), inner.begin(), inner.end());
+    ensure_THROW(wkbreader.read(buf.data(), buf.size()), geos::io::ParseException);
+    // try {
+    //     wkbreader.read(buf.data(), buf.size());
+    //     fail("Expected ParseException for deeply nested WKB");
+    // } catch (const geos::util::GEOSException&) {}
 } // namespace tut
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index af9621916..2a28e805b 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -3,6 +3,7 @@
 // tut
 // geos
 #include <geos/io/WKTWriter.h>
@@ -162,17 +163,7 @@ template<>
 void object::test<6>
-    try {
-        wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))");
-        fail("Did not get expected exception");
-    catch(const geos::util::IllegalArgumentException& ex) {
-        ensure("Got expected exception", true);
-        (void)(ex.what());
-    catch(...) {
-        fail("Got unexpected exception");
+    ensure_THROW(wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))"), geos::util::IllegalArgumentException);
 // POINT(0 0) http://trac.osgeo.org/geos/ticket/610
@@ -499,4 +490,17 @@ void object::test<25>
     ensure_parseexception("POLYGON Z M EMPTY");
+template<>
+template<>
+void object::test<26>
+    set_test_name("ParseException on deeply nested WKT collection avoid stack overflow");
+    std::string wkt;
+    for (int i = 0; i < 200; i++) wkt += "GEOMETRYCOLLECTION(";
+    wkt += "POINT(0 0)";
+    for (int i = 0; i < 200; i++) wkt += ")";
+    ensure_parseexception(wkt);
 } // namespace tut
Summary of changes:
 capi/geos_ts_c.cpp                  |  1 +
 include/geos/io/GeoJSONReader.h     |  1 +
 include/geos/io/WKBReader.h         |  2 ++
 include/geos/io/WKTReader.h         |  1 +
 src/io/GeoJSONReader.cpp            | 16 ++++++++++++++++
 src/io/WKBReader.cpp                |  9 +++++++++
 src/io/WKTReader.cpp                |  9 +++++++++
 tests/unit/io/GeoJSONReaderTest.cpp | 17 +++++++++++++++++
 tests/unit/io/WKBReaderTest.cpp     | 26 ++++++++++++++++++++++++++
 tests/unit/io/WKTReaderTest.cpp     | 26 +++++++++++++++-----------
 10 files changed, 97 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
