[geos-commits] [SCM] GEOS branch 3.13 updated. c3a9f82726a5c90663f79272152194f1d6a43105
git at osgeo.org
git at osgeo.org
Wed May 13 14:37:17 PDT 2026
the project "GEOS".
The branch, 3.13 has been updated
via c3a9f82726a5c90663f79272152194f1d6a43105 (commit)
via f8910e84a0f3580f0847373cd77205703bf18c78 (commit)
from 1d2f7a27e98237776e365c25e4ab7b2a34370ff9 (commit)
revisions in full, below.
commit c3a9f82726a5c90663f79272152194f1d6a43105
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed May 13 13:46:33 2026 -0700
Fix CI issue for mingw64
diff --git a/include/geos/algorithm/distance/DistanceToPoint.h b/include/geos/algorithm/distance/DistanceToPoint.h
index 108b85506..f1889397b 100644
--- a/include/geos/algorithm/distance/DistanceToPoint.h
+++ b/include/geos/algorithm/distance/DistanceToPoint.h
@@ -19,6 +19,7 @@
#pragma once
#include <geos/geom/LineSegment.h> // for composition
+#include <geos/export.h>
namespace geos {
namespace algorithm {
@@ -43,7 +44,7 @@ namespace distance { // geos::algorithm::distance
* Also computes two points which are separated by the distance.
-class DistanceToPoint {
+class GEOS_DLL DistanceToPoint {
public:
DistanceToPoint() {}
commit f8910e84a0f3580f0847373cd77205703bf18c78
Date: Wed May 13 12:11:50 2026 -0700
Limit recursion depth in WKT/WKB/GeoJSON readers
Prevents stack overflow on malformed input.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index ef238229a..f76dc25ee 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -948,7 +948,6 @@ extern "C" {
Geometry*
GEOSGeomFromWKT_r(GEOSContextHandle_t extHandle, const char* wkt)
diff --git a/include/geos/io/GeoJSONReader.h b/include/geos/io/GeoJSONReader.h
index 41834f1dd..9d9d09d20 100644
--- a/include/geos/io/GeoJSONReader.h
+++ b/include/geos/io/GeoJSONReader.h
@@ -75,6 +75,7 @@ public:
private:
const geom::GeometryFactory& geometryFactory;
+ mutable int parseDepth_ = 0;
std::unique_ptr<geom::Geometry> readFeatureForGeometry(const geos_nlohmann::json& j) const;
diff --git a/include/geos/io/WKBReader.h b/include/geos/io/WKBReader.h
index 9d410c250..2b8b5beae 100644
--- a/include/geos/io/WKBReader.h
+++ b/include/geos/io/WKBReader.h
@@ -146,6 +146,8 @@ private:
std::array<double, 4> ordValues;
+ int parseDepth_ = 0;
std::unique_ptr<geom::Geometry> readGeometry();
std::unique_ptr<geom::Point> readPoint();
diff --git a/include/geos/io/WKTReader.h b/include/geos/io/WKTReader.h
index 7294d64f5..46529c3c8 100644
--- a/include/geos/io/WKTReader.h
+++ b/include/geos/io/WKTReader.h
@@ -148,6 +148,7 @@ private:
const geom::GeometryFactory* geometryFactory;
const geom::PrecisionModel* precisionModel;
bool fixStructure;
void getPreciseCoordinate(io::StringTokenizer* tokenizer, OrdinateSet& ordinateFlags, geom::CoordinateXYZM&) const;
diff --git a/src/io/GeoJSONReader.cpp b/src/io/GeoJSONReader.cpp
index 0f0817e32..1ab54dd9e 100644
--- a/src/io/GeoJSONReader.cpp
+++ b/src/io/GeoJSONReader.cpp
@@ -40,12 +40,15 @@ using json = geos_nlohmann::json;
namespace geos {
namespace io { // geos.io
+static constexpr int MAX_PARSE_DEPTH = 100;
GeoJSONReader::GeoJSONReader(): GeoJSONReader(*(GeometryFactory::getDefaultInstance())) {}
GeoJSONReader::GeoJSONReader(const geom::GeometryFactory& gf) : geometryFactory(gf) {}
std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonText) const
+ parseDepth_ = 0;
try {
const json& j = json::parse(geoJsonText);
const std::string& type = j.at("type");
@@ -66,6 +69,7 @@ std::unique_ptr<geom::Geometry> GeoJSONReader::read(const std::string& geoJsonTe
GeoJSONFeatureCollection GeoJSONReader::readFeatures(const std::string& geoJsonText) const
+ parseDepth_ = 0;
try {
@@ -121,6 +125,12 @@ std::map<std::string, GeoJSONValue> GeoJSONReader::readProperties(
GeoJSONValue GeoJSONReader::readProperty(
const geos_nlohmann::json& value) const
+ if (parseDepth_ >= MAX_PARSE_DEPTH) {
+ throw ParseException("Input property exceeds nesting depth limit");
+ ++parseDepth_;
+ struct DepthGuard { int& d; ~DepthGuard() { --d; } } guard{parseDepth_};
if (value.is_string()) {
return GeoJSONValue { value.get<std::string>() };
@@ -179,6 +189,12 @@ GeoJSONFeatureCollection GeoJSONReader::readFeatureCollection(
std::unique_ptr<geom::Geometry> GeoJSONReader::readGeometry(
+ throw ParseException("Input geometry exceeds nesting depth limit");
+ ++parseDepth_;
if (type == "Point") {
return readPoint(j);
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 5410ab0c7..d81a88ddc 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -245,13 +245,22 @@ WKBReader::read(std::istream& is)
std::unique_ptr<Geometry>
WKBReader::read(const unsigned char* buf, size_t size)
+ parseDepth_ = 0;
dis = ByteOrderDataInStream(buf, size); // will default to machine endian
return readGeometry();
WKBReader::readGeometry()
+ ++parseDepth_;
// determine byte order
unsigned char byteOrder = dis.readByte();
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index fc850d220..8b66e021c 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -49,9 +49,12 @@ using namespace geos::geom;
namespace geos {
WKTReader::read(const std::string& wellKnownText) const
+ parseDepth_ = 0;
CLocalizer clocale;
StringTokenizer tokenizer(wellKnownText);
OrdinateSet ordinateFlags = OrdinateSet::createXY();
@@ -267,6 +270,12 @@ WKTReader::getNextWord(StringTokenizer* tokenizer)
WKTReader::readGeometryTaggedText(StringTokenizer* tokenizer, OrdinateSet& ordinateFlags, const GeometryTypeId* emptyType) const
+ ++parseDepth_;
std::string type = getNextWord(tokenizer);
std::unique_ptr<Geometry> geom;
diff --git a/tests/unit/io/GeoJSONReaderTest.cpp b/tests/unit/io/GeoJSONReaderTest.cpp
index c5ff39db8..bafb21ffc 100644
--- a/tests/unit/io/GeoJSONReaderTest.cpp
+++ b/tests/unit/io/GeoJSONReaderTest.cpp
@@ -620,4 +620,21 @@ void object::test<40>
ensure_equals(static_cast<size_t>(geom->getCoordinateDimension()), 3u);
+// Deeply nested GeometryCollection should throw ParseException (not stack overflow)
+template<>
+template<>
+void object::test<41>
+ std::string geojson;
+ for (int i = 0; i < 200; i++) geojson += "{\"type\":\"GeometryCollection\",\"geometries\":[";
+ geojson += "{\"type\":\"Point\",\"coordinates\":[0,0]}";
+ for (int i = 0; i < 200; i++) geojson += "]}";
+ try {
+ geojsonreader.read(geojson);
+ fail("Expected ParseException for deeply nested GeoJSON");
+ } catch (const geos::io::ParseException&) {}
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index 6628351a8..0b6b540b6 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -7,11 +7,13 @@
// tut
#include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
// geos
#include <geos/io/WKBReader.h>
#include <geos/io/WKBConstants.h>
#include <geos/io/WKBWriter.h>
#include <geos/io/WKTReader.h>
+#include <geos/io/ParseException.h>
#include <geos/geom/CompoundCurve.h>
#include <geos/geom/CurvePolygon.h>
#include <geos/geom/PrecisionModel.h>
@@ -838,5 +840,24 @@ void object::test<36>
"ParseException: Expected SimpleCurve but got Point");
+template<>
+template<>
+void object::test<37>
+ set_test_name("ParseException on deeply nested WKB collection avoid stack overflow");
+ // Each GeometryCollection header (NDR): byteOrder=01, type=07000000, numGeoms=01000000
+ const std::vector<unsigned char> header = {0x01, 0x07, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00};
+ // Innermost empty GeometryCollection: byteOrder=01, type=07000000, numGeoms=00000000
+ const std::vector<unsigned char> inner = {0x01, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
+ std::vector<unsigned char> buf;
+ for (int i = 0; i < 200; i++) buf.insert(buf.end(), header.begin(), header.end());
+ buf.insert(buf.end(), inner.begin(), inner.end());
+ ensure_THROW(wkbreader.read(buf.data(), buf.size()), geos::io::ParseException);
} // namespace tut
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 59e5f1b25..5da2f3806 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -3,6 +3,7 @@
// tut
// geos
#include <geos/io/WKTWriter.h>
@@ -162,17 +163,7 @@ template<>
void object::test<6>
- try {
- wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))");
- fail("Did not get expected exception");
- catch(const geos::util::IllegalArgumentException& ex) {
- ensure("Got expected exception", true);
- (void)(ex.what());
- catch(...) {
- fail("Got unexpected exception");
+ ensure_THROW(wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))"), geos::util::IllegalArgumentException);
// POINT(0 0) http://trac.osgeo.org/geos/ticket/610
@@ -473,4 +464,17 @@ void object::test<24>
ensure_equals(geom->getNumGeometries(), 3u);
+template<>
+template<>
+void object::test<26>
+ set_test_name("ParseException on deeply nested WKT collection avoid stack overflow");
+ std::string wkt;
+ for (int i = 0; i < 200; i++) wkt += "GEOMETRYCOLLECTION(";
+ wkt += "POINT(0 0)";
+ for (int i = 0; i < 200; i++) wkt += ")";
+ ensure_parseexception(wkt);
} // namespace tut
Summary of changes:
capi/geos_ts_c.cpp | 1 -
include/geos/algorithm/distance/DistanceToPoint.h | 3 ++-
include/geos/io/GeoJSONReader.h | 1 +
include/geos/io/WKBReader.h | 2 ++
include/geos/io/WKTReader.h | 1 +
src/io/GeoJSONReader.cpp | 16 ++++++++++++++
src/io/WKBReader.cpp | 9 ++++++++
src/io/WKTReader.cpp | 9 ++++++++
tests/unit/io/GeoJSONReaderTest.cpp | 17 +++++++++++++++
tests/unit/io/WKBReaderTest.cpp | 21 ++++++++++++++++++
tests/unit/io/WKTReaderTest.cpp | 26 +++++++++++++----------
11 files changed, 93 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits
