[geos-commits] [SCM] GEOS branch 3.13 updated. 98da0fad0b9abff91349cf71d19196c5d48e258a
git at osgeo.org
git at osgeo.org
Wed May 13 15:26:34 PDT 2026
the project "GEOS".
The branch, 3.13 has been updated
via 98da0fad0b9abff91349cf71d19196c5d48e258a (commit)
via 663e9b48b606b5e9d274fdbb41e4be2cbcc1912e (commit)
from b61d1f844667f7649bfa696b5319df7e03df9237 (commit)
revisions in full, below.
commit 98da0fad0b9abff91349cf71d19196c5d48e258a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed May 13 15:26:02 2026 -0700
News entry for WKB overflow
diff --git a/NEWS.md b/NEWS.md
index 4a365a95a..be94fcc4d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -10,6 +10,7 @@
- Quiet FP_DIVBYZERO exception from CGAlgorithmsDD::intersection (GH-1235, Paul Ramsey)
- Avoid crash on buffer of geometry with only invalid coordinates (GH-1335, Dan Baston)
- Guard against stack overflow in inputs (GH-1437, Paul Ramsey)
+ - Avoid overflow risk in WKB reader (Paul Ramsey)
## Changes in 3.13.1
2025-03-03
commit 663e9b48b606b5e9d274fdbb41e4be2cbcc1912e
Date: Wed May 13 22:00:16 2026 +0000
WKBReader: use division in minMemSize() to avoid overflow risk
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index d81a88ddc..442d28506 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -187,7 +187,6 @@ WKBReader::readHEX(std::istream& is)
void
WKBReader::minMemSize(geom::GeometryTypeId geomType, uint64_t size) const
- uint64_t minSize = 0;
constexpr uint64_t minCoordSize = 2 * sizeof(double);
constexpr uint64_t minPtSize = (1+4) + minCoordSize;
constexpr uint64_t minLineSize = (1+4+4); // empty line
@@ -195,35 +194,36 @@ WKBReader::minMemSize(geom::GeometryTypeId geomType, uint64_t size) const
constexpr uint64_t minPolySize = (1+4+4); // empty polygon
constexpr uint64_t minGeomSize = minLineSize;
+ uint64_t perElement = 0;
switch(geomType) {
case GEOS_LINESTRING:
case GEOS_LINEARRING:
case GEOS_CIRCULARSTRING:
case GEOS_COMPOUNDCURVE:
case GEOS_POINT:
- minSize = size * minCoordSize;
+ perElement = minCoordSize;
break;
case GEOS_POLYGON:
case GEOS_CURVEPOLYGON:
- minSize = size * minRingSize;
+ perElement = minRingSize;
break;
case GEOS_MULTIPOINT:
- minSize = size * minPtSize;
+ perElement = minPtSize;
break;
case GEOS_MULTILINESTRING:
case GEOS_MULTICURVE:
- minSize = size * minLineSize;
+ perElement = minLineSize;
break;
case GEOS_MULTIPOLYGON:
case GEOS_MULTISURFACE:
- minSize = size * minPolySize;
+ perElement = minPolySize;
break;
case GEOS_GEOMETRYCOLLECTION:
- minSize = size * minGeomSize;
+ perElement = minGeomSize;
break;
- if (dis.size() < minSize) {
+ if (perElement > 0 && size > dis.size() / perElement) {
throw ParseException("Input buffer is smaller than requested object size");
Summary of changes:
NEWS.md | 1 +
src/io/WKBReader.cpp | 16 ++++++++--------
2 files changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
