[geos-commits] [SCM] GEOS branch main updated. 87af72224bf9f066353d2215e2e3dea50fba8cb1
git at osgeo.org
git at osgeo.org
Fri May 15 11:49:27 PDT 2026
the project "GEOS".
The branch, main has been updated
via 87af72224bf9f066353d2215e2e3dea50fba8cb1 (commit)
via dba47b90ed061f7d2d9584909f6e54f5dbdede26 (commit)
from 8b8b3da7a3d9fb8953ff60bc49aa0320d51ae45c (commit)
revisions in full, below.
commit 87af72224bf9f066353d2215e2e3dea50fba8cb1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed May 13 22:00:52 2026 +0000
Test for use division in minMemSize()
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index ebdba7a40..b4024dee1 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -857,11 +857,27 @@ void object::test<37>
buf.insert(buf.end(), inner.begin(), inner.end());
ensure_THROW(wkbreader.read(buf.data(), buf.size()), geos::io::ParseException);
- // try {
- // wkbreader.read(buf.data(), buf.size());
- // fail("Expected ParseException for deeply nested WKB");
- // } catch (const geos::util::GEOSException&) {}
+// Claimed element count larger than buffer can hold should throw ParseException
+template<>
+template<>
+void object::test<38>
+ set_test_name("ParseException when WKB element count exceeds buffer capacity");
+ // NDR GeometryCollection with numGeoms = 0x00FFFFFF in a 20-byte buffer
+ // Header: byteOrder=01, type=07000000, numGeoms=FFFFFF00 (little-endian 0x00FFFFFF)
+ std::vector<unsigned char> buf = {
+ 0x01, // NDR byte order
+ 0x07, 0x00, 0x00, 0x00, // type: GeometryCollection
+ 0xFF, 0xFF, 0xFF, 0x00, // numGeoms: 0x00FFFFFF (little-endian)
+ 0x00, 0x00, 0x00, 0x00, 0x00, // padding to make buffer 20 bytes
+ ensure_THROW(wkbreader.read(buf.data(), buf.size()), geos::io::ParseException);
} // namespace tut
commit dba47b90ed061f7d2d9584909f6e54f5dbdede26
Date: Wed May 13 22:00:16 2026 +0000
WKBReader: use division in minMemSize() to avoid overflow risk
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index d5683f2dc..b366d91b9 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -194,7 +194,6 @@ WKBReader::readHEX(const std::string& hex)
void
WKBReader::minMemSize(geom::GeometryTypeId geomType, uint64_t size) const
- uint64_t minSize = 0;
constexpr uint64_t minCoordSize = 2 * sizeof(double);
constexpr uint64_t minPtSize = (1+4) + minCoordSize;
constexpr uint64_t minLineSize = (1+4+4); // empty line
@@ -202,35 +201,36 @@ WKBReader::minMemSize(geom::GeometryTypeId geomType, uint64_t size) const
constexpr uint64_t minPolySize = (1+4+4); // empty polygon
constexpr uint64_t minGeomSize = minLineSize;
+ uint64_t perElement = 0;
switch(geomType) {
case GEOS_LINESTRING:
case GEOS_LINEARRING:
case GEOS_CIRCULARSTRING:
case GEOS_COMPOUNDCURVE:
case GEOS_POINT:
- minSize = size * minCoordSize;
+ perElement = minCoordSize;
break;
case GEOS_POLYGON:
case GEOS_CURVEPOLYGON:
- minSize = size * minRingSize;
+ perElement = minRingSize;
break;
case GEOS_MULTIPOINT:
- minSize = size * minPtSize;
+ perElement = minPtSize;
break;
case GEOS_MULTILINESTRING:
case GEOS_MULTICURVE:
- minSize = size * minLineSize;
+ perElement = minLineSize;
break;
case GEOS_MULTIPOLYGON:
case GEOS_MULTISURFACE:
- minSize = size * minPolySize;
+ perElement = minPolySize;
break;
case GEOS_GEOMETRYCOLLECTION:
- minSize = size * minGeomSize;
+ perElement = minGeomSize;
break;
- if (dis.size() < minSize) {
+ if (perElement > 0 && size > dis.size() / perElement) {
throw ParseException("Input buffer is smaller than requested object size");
Summary of changes:
src/io/WKBReader.cpp | 16 ++++++++--------
tests/unit/io/WKBReaderTest.cpp | 24 ++++++++++++++++++++----
2 files changed, 28 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
