[geos-commits] [SCM] GEOS branch dependabot/github_actions/all-actions-c2c22ea26e created. 87cce888a8b58f6814e6bf0af6c495d30d3796e1
Sun Nov 1 07:48:41 PST 2026
the project "GEOS".
The branch, dependabot/github_actions/all-actions-c2c22ea26e has been created
        at  87cce888a8b58f6814e6bf0af6c495d30d3796e1 (commit)
commit 87cce888a8b58f6814e6bf0af6c495d30d3796e1
Author: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
Date:   Sun Nov 1 15:48:13 2026 +0000
    Bump the all-actions group with 3 updates
    Bumps the all-actions group with 3 updates: [vmactions/freebsd-vm](https://github.com/vmactions/freebsd-vm), [github/codeql-action](https://github.com/github/codeql-action) and [docker/login-action](https://github.com/docker/login-action).
    Updates `vmactions/freebsd-vm` from 1.5.7 to 1.5.9
    - [Release notes](https://github.com/vmactions/freebsd-vm/releases)
    - [Commits](https://github.com/vmactions/freebsd-vm/compare/v1.5.7...v1.5.9)
    Updates `github/codeql-action` from 4.38.2 to 4.39.1
    - [Release notes](https://github.com/github/codeql-action/releases)
    - [Changelog](https://github.com/github/codeql-action/blob/main/CHANGELOG.md)
    - [Commits](https://github.com/github/codeql-action/compare/v4.38.2...v4.39.1)
    Updates `docker/login-action` from 4.6.0 to 4.7.0
    - [Release notes](https://github.com/docker/login-action/releases)
    - [Commits](https://github.com/docker/login-action/compare/v4.6.0...v4.7.0)
    updated-dependencies:
    - dependency-name: vmactions/freebsd-vm
      dependency-version: 1.5.9
      dependency-type: direct:production
      update-type: version-update:semver-patch
      dependency-group: all-actions
    - dependency-name: github/codeql-action
      dependency-version: 4.39.1
      update-type: version-update:semver-minor
    - dependency-name: docker/login-action
      dependency-version: 4.7.0
    Signed-off-by: dependabot[bot] <support at github.com>
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 96ccada6e..4148575ba 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -556,7 +556,7 @@ jobs:
         restore-keys: freebsd
     - name: Build, test, install
-      uses: vmactions/freebsd-vm at v1.5.7
+      uses: vmactions/freebsd-vm at v1.5.9
       with:
         release: "15.0"
         envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 5c5d0ec71..c19fed357 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -40,7 +40,7 @@ jobs:
     # Initializes the CodeQL tools for scanning.
     - name: Initialize CodeQL
-      uses: github/codeql-action/init at v4.38.2
+      uses: github/codeql-action/init at v4.39.1
       with:
         languages: ${{ matrix.language }}
         # If you wish to specify custom queries, you can do so here or in a config file.
@@ -63,6 +63,6 @@ jobs:
           make -j$(nproc)
     - name: Perform CodeQL Analysis
-      uses: github/codeql-action/analyze at v4.38.2
+      uses: github/codeql-action/analyze at v4.39.1
       with:
         category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 79e6d1c09..73fc993c5 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
           type=sha,prefix=
     - name: Login to GitHub Container Registry
-      uses: docker/login-action at v4.6.0
+      uses: docker/login-action at v4.7.0
       with:
         registry: ghcr.io
         username: ${{ github.repository_owner }}
hooks/post-receive
More information about the geos-commits mailing list
