[geos-commits] [SCM] GEOS branch main updated. 1bd84740d81df4eec08f82d19e425c7c74cadbf0
git at osgeo.org
git at osgeo.org
Sun Nov 1 18:20:28 PST 2026
the project "GEOS".
The branch, main has been updated
via 1bd84740d81df4eec08f82d19e425c7c74cadbf0 (commit)
from 2289bad7aac673a1bffcbbdd96944fcc57405a9c (commit)
revisions in full, below.
commit 1bd84740d81df4eec08f82d19e425c7c74cadbf0
Author: Daniel Baston <dbaston at gmail.com>
Date: Sat Oct 31 16:00:34 2026 -0400
NodableArcString: Handle degenerate arcs with repeated points
Co-authored-by: Alejandro Pacheco <ale at alepacheco.dev>
diff --git a/src/noding/NodableArcString.cpp b/src/noding/NodableArcString.cpp
index 5b41a62f8..7c91634ee 100644
--- a/src/noding/NodableArcString.cpp
+++ b/src/noding/NodableArcString.cpp
@@ -268,7 +268,7 @@ public:
m_coords = std::make_unique<geom::CoordinateSequence>(0, m_constructZ, m_constructM);
- m_coords->add(seq, pos, pos + 2, false);
+ m_coords->add(seq, pos + !m_coords->isEmpty(), pos + 2, true);
m_arcs.emplace_back(*m_coords, m_coords->getSize() - 3, center, radius, orientation);
diff --git a/tests/unit/capi/GEOSNodeTest.cpp b/tests/unit/capi/GEOSNodeTest.cpp
index 10166adbc..97401d714 100644
--- a/tests/unit/capi/GEOSNodeTest.cpp
+++ b/tests/unit/capi/GEOSNodeTest.cpp
@@ -414,5 +414,28 @@ void object::test<19>()
reinterpret_cast<Geometry*>(expected_), 1e-4);
+template<>
+template<>
+void object::test<20>()
+ set_test_name("CircularString with repeated points");
+ input_ = fromWKT("MULTICURVE (CIRCULARSTRING (0 0, 0 0, 2 0, 3 1, 4 0), LINESTRING (3 0, 3 2))");
+ result_ = GEOSNode(input_);
+ ensure(result_);
+ ensure_equals(GEOSGetNumGeometries(result_), 4);
+ expected_ = fromWKT("MULTICURVE ("
+ "CIRCULARSTRING (0 0, 0 0, 2 0, 2.2928932188 0.7071067812, 3 1),"
+ "CIRCULARSTRING (3 1, 3.7071067812 0.7071067812, 4 0),"
+ "(3 0, 3 1),"
+ "(3 1, 3 2))");
+ ensure_equals_exact_geometry_xyzm(reinterpret_cast<Geometry*>(result_),
+ reinterpret_cast<Geometry*>(expected_), 1e-4);
} // namespace tut
diff --git a/tests/unit/noding/NodableArcStringTest.cpp b/tests/unit/noding/NodableArcStringTest.cpp
index c1f1c02ce..31b8b9832 100644
--- a/tests/unit/noding/NodableArcStringTest.cpp
+++ b/tests/unit/noding/NodableArcStringTest.cpp
@@ -12,6 +12,7 @@ using geos::geom::CoordinateXY;
using geos::geom::CoordinateXYZM;
using geos::noding::ArcString;
using geos::noding::NodableArcString;
+using namespace std::string_literals;
namespace tut {
@@ -223,4 +224,72 @@ void object::test<5>()
\ No newline at end of file
+template<>
+template<>
+void object::test<6>()
+ set_test_name("getNoded keeps all three points of arcs with repeated points");
+ for (const char* wkt : {
+ "CIRCULARSTRING (0 0, 0 0, 0 0)", // 0 == 1 == 2
+ "CIRCULARSTRING (0 0, 0 0, 2 0, 3 1, 4 0)", // 0 == 1
+ "CIRCULARSTRING (0 0, 1 1, 1 1, 3 1, 4 0)", // 1 == 2
+ "CIRCULARSTRING (0 0, 1 1, 2 0, 2 0, 4 0)", // 2 == 3
+ "CIRCULARSTRING (0 0, 1 1, 2 0, 3 1, 3 1)" // 3 == 4
+ const auto g = reader_.read<CircularString>(wkt);
+ NodableArcString nas(g->getArcs(), g->getSharedCoordinates(), false, false, nullptr);
+ std::vector<std::unique_ptr<ArcString>> noded;
+ nas.getNoded(noded);
+ ensure_equals("noded.size(): "s + wkt, noded.size(), 1u);
+ ensure_equals("noded[0]->getSize(): "s + wkt, noded[0]->getSize(), g->getArcs().size());
+ ensure("noded[0]->getCoordinates(): "s + wkt, noded[0]->getCoordinates()->equalsIdentical(*g->getCoordinatesRO()));
+ for (std::size_t i = 0; i < noded[0]->getSize(); i++) {
+ ensure_equals(wkt, noded[0]->getArc(i).getCoordinatePosition(), 2*i);
+template<>
+template<>
+void object::test<7>()
+ set_test_name("getNoded keeps arc with repeated points before a split arc");
+ const auto g = reader_.read<CircularString>("CIRCULARSTRING (0 0, 0 0, 2 0, 3 1, 4 0)");
+ nas.addIntersection(CoordinateXY{3, 1}, 1);
+ ensure_equals(noded.size(), 2u);
+ const auto& seq = *noded[0]->getCoordinates();
+ ensure_equals(noded[0]->getSize(), 2u);
+ ensure_equals(seq.size(), 5u);
+ const CircularArc& arc0 = noded[0]->getArc(0);
+ ensure_equals(arc0.getCoordinatePosition(), 0u);
+ ensure_equals(arc0.p0(), XY{0, 0});
+ ensure_equals(arc0.p1(), XY{0, 0});
+ ensure_equals(arc0.p2(), XY{2, 0});
+ const CircularArc& arc1 = noded[0]->getArc(1);
+ ensure_equals(arc1.getCoordinatePosition(), 2u);
+ ensure_equals(arc1.p0(), XY{2, 0});
+ ensure_equals(arc1.p2(), XY{3, 1});
+ ensure_equals(noded[1]->getSize(), 1u);
+ ensure_equals(noded[1]->getCoordinates()->size(), 3u);
+ const CircularArc& arc2 = noded[1]->getArc(0);
+ ensure_arc_equals(arc2, CircularArc::create(XY{3, 1}, XY{4, 0}, XY{3, 0}, 1, Orientation::CLOCKWISE), 1e-8);
+ ensure_equals(arc2.p2(), XY{4, 0});
+} // namespace tut
Summary of changes:
src/noding/NodableArcString.cpp | 2 +-
tests/unit/capi/GEOSNodeTest.cpp | 23 ++++++++++
tests/unit/noding/NodableArcStringTest.cpp | 71 +++++++++++++++++++++++++++++-
3 files changed, 94 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
