[geos-commits] [SCM] GEOS branch main updated. 2c8e04faf8235456b417979bcf23271ef34148a7
Thu Nov 5 06:11:15 PST 2026
the project "GEOS".
The branch, main has been updated
       via  2c8e04faf8235456b417979bcf23271ef34148a7 (commit)
      from  fc3eca9063096a665700651d6523f56de4dae415 (commit)
revisions in full, below.
commit 2c8e04faf8235456b417979bcf23271ef34148a7
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Nov 5 09:10:33 2026 -0500
    AdjacentEdgeLocator: Avoid checking empty rings (#1590)
    Resolves https://github.com/libgeos/geos/issues/1585
diff --git a/src/operation/relateng/AdjacentEdgeLocator.cpp b/src/operation/relateng/AdjacentEdgeLocator.cpp
index aeb5f8084..fa63f4fc9 100644
--- a/src/operation/relateng/AdjacentEdgeLocator.cpp
+++ b/src/operation/relateng/AdjacentEdgeLocator.cpp
@@ -133,6 +133,10 @@ AdjacentEdgeLocator::addRings(const Geometry* geom)
 void
 AdjacentEdgeLocator::addRing(const LinearRing* ring, bool requireCW)
+    if (ring->isEmpty()) {
+        return;
     //TODO: remove repeated points?
     const CoordinateSequence* pts = ring->getCoordinatesRO();
     bool isFlipped = requireCW == Orientation::isCCW(pts);
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index ee8d3a841..8c7860577 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -925,5 +925,17 @@ void object::test<64> ()
     checkRelate(b, a, "102F01FF2");
+template<>
+template<>
+void object::test<65>()
+    set_test_name("GeometryCollection with empty polygon");
-} // namespace tut
+    std::string a = "POINT (1 0.5)";
+    std::string b = "GEOMETRYCOLLECTION (POLYGON ((1 0, 1 1, 0 1, 0 0, 1 0)), POLYGON ((2 0, 2 1, 1 1, 1 0, 2 0)), POLYGON EMPTY)";
+    checkIntersectsDisjoint(a, b, true);
+} // namespace tut
\ No newline at end of file
Summary of changes:
 src/operation/relateng/AdjacentEdgeLocator.cpp |  4 ++++
 tests/unit/operation/relateng/RelateNGTest.cpp | 14 +++++++++++++-
 2 files changed, 17 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
