[geos-commits] [SCM] GEOS branch 3.15 updated. 5e34781c76282e949dde1498fc89a3f8f42d2e20
Fri Nov 6 10:09:10 PST 2026
the project "GEOS".
The branch, 3.15 has been updated
       via  5e34781c76282e949dde1498fc89a3f8f42d2e20 (commit)
       via  a38377342a9c1786c425b9a33270eec64900866a (commit)
       via  a6f1f8227fd45b5e16cb21f0f03a26b6cf61f54d (commit)
      from  3ee1c785707005880df0899d9ba153093b4e8a85 (commit)
revisions in full, below.
commit 5e34781c76282e949dde1498fc89a3f8f42d2e20
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Nov 6 11:32:00 2026 -0500
    NEWS updates
diff --git a/NEWS.md b/NEWS.md
index 05d6eecaf..e836ba19d 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -6,6 +6,7 @@
   - Arc noding: handle degenerate arcs with repeated points (GH-1584, Alejandro Pacheco and Dan Baston)
   - Make GeometrySplitter able to split MultiSurface inputs (GH-1518, Dan Baston)
   - GEOSGridIntersectionFractions: Set cells outside geometry bounding box to zero (GH-1532, Dan Baston)
+  - GEOSGridIntersectionFractions: Improve robustness (GH-1589, Dan Baston, Alejandro Pacheco)
   - Skip testing FE_INVALID from unit-geom-Envelope for some Clang builds (GH-1555, Mike Taves)
   - Polygonize / LineMerge: Copy Z/M values at shared endpoints of mixed-dimension inputs (GH-1545, Dan Baston)
   - CircularArcIntersector: Use Orient2D to check for arc control points on line (GH-1546, Dan Baston)
@@ -20,6 +21,7 @@
   - Envelope: improve robustness of distanceSquared (GH-1576, Jeroen Bloemscheer)
   - Distance: avoid erroneously large distance between arc and segment (GH-1577, Dan Baston and Jeroen Bloemscheer)
   - GeometryFactory: fix return type from buildGeometry with collection inputs (GH-1580, Alejandro Pacheco)
+  - RelateNG: fix crash with on GeometryCollection with empty Polygon (GH-1590, Dan Baston)
 ## Changes in 3.15.0
 2026-09-01
commit a38377342a9c1786c425b9a33270eec64900866a
Date:   Thu Nov 5 09:10:33 2026 -0500
    AdjacentEdgeLocator: Avoid checking empty rings (#1590)
    Resolves https://github.com/libgeos/geos/issues/1585
diff --git a/src/operation/relateng/AdjacentEdgeLocator.cpp b/src/operation/relateng/AdjacentEdgeLocator.cpp
index aeb5f8084..fa63f4fc9 100644
--- a/src/operation/relateng/AdjacentEdgeLocator.cpp
+++ b/src/operation/relateng/AdjacentEdgeLocator.cpp
@@ -133,6 +133,10 @@ AdjacentEdgeLocator::addRings(const Geometry* geom)
 void
 AdjacentEdgeLocator::addRing(const LinearRing* ring, bool requireCW)
+    if (ring->isEmpty()) {
+        return;
     //TODO: remove repeated points?
     const CoordinateSequence* pts = ring->getCoordinatesRO();
     bool isFlipped = requireCW == Orientation::isCCW(pts);
diff --git a/tests/unit/operation/relateng/RelateNGTest.cpp b/tests/unit/operation/relateng/RelateNGTest.cpp
index ee8d3a841..8c7860577 100644
--- a/tests/unit/operation/relateng/RelateNGTest.cpp
+++ b/tests/unit/operation/relateng/RelateNGTest.cpp
@@ -925,5 +925,17 @@ void object::test<64> ()
     checkRelate(b, a, "102F01FF2");
+template<>
+template<>
+void object::test<65>()
+    set_test_name("GeometryCollection with empty polygon");
-} // namespace tut
+    std::string a = "POINT (1 0.5)";
+    std::string b = "GEOMETRYCOLLECTION (POLYGON ((1 0, 1 1, 0 1, 0 0, 1 0)), POLYGON ((2 0, 2 1, 1 1, 1 0, 2 0)), POLYGON EMPTY)";
+    checkIntersectsDisjoint(a, b, true);
+} // namespace tut
\ No newline at end of file
commit a6f1f8227fd45b5e16cb21f0f03a26b6cf61f54d
Date:   Thu Nov 5 09:10:08 2026 -0500
    GridIntersection: robustness fixes (#1589)
    Co-authored-by: Alejandro Pacheco <ale at alepacheco.dev>
diff --git a/include/geos/operation/grid/Grid.h b/include/geos/operation/grid/Grid.h
index d94d80916..e56d7dd84 100644
--- a/include/geos/operation/grid/Grid.h
+++ b/include/geos/operation/grid/Grid.h
@@ -19,6 +19,7 @@
 #include <vector>
 #include <geos/geom/Envelope.h>
+#include <geos/util/IllegalArgumentException.h>
 namespace geos::operation::grid {
 struct infinite_extent
@@ -69,6 +70,12 @@ class GEOS_DLL Grid
       , m_num_cols{ 2 * extent_tag::padding + (extent.getMaxX() > extent.getMinX() ? static_cast<size_t>(std::round(extent.getWidth() / dx)) : 0) }
         static_assert(std::is_same_v<extent_tag, infinite_extent>);
+        if (!isEmpty()) {
+            if (m_domain.getMinX() >= m_extent.getMinX() || m_domain.getMaxX() <= m_extent.getMaxX() ||
+                m_domain.getMinY() >= m_extent.getMinY() || m_domain.getMaxY() <= m_extent.getMaxY()) {
+                throw geos::util::IllegalArgumentException("Domain of infinite grid must be larger than extent");
diff --git a/src/operation/grid/Grid.cpp b/src/operation/grid/Grid.cpp
index d4db6659b..bd63dff71 100644
--- a/src/operation/grid/Grid.cpp
+++ b/src/operation/grid/Grid.cpp
@@ -41,11 +41,9 @@ Grid<infinite_extent>::getCellEnvelope(size_t row, size_t col) const
     double cell_xmin, cell_xmax, cell_ymin, cell_ymax;
-    constexpr double PADDED_CELL_SIZE = 1.0;
     if (col == 0) {
         // Left-side padding
-        cell_xmin = std::min(xmin() - PADDED_CELL_SIZE, m_domain.getMinX());
+        cell_xmin = m_domain.getMinX();
     } else if (col == getNumCols() - 1) {
         // Right-side padding
         cell_xmin = xmax(); // because rightmost col of regular may have different width from others
@@ -57,7 +55,7 @@ Grid<infinite_extent>::getCellEnvelope(size_t row, size_t col) const
     switch (getNumCols() - col) {
         case 1:
-            cell_xmax = std::max(xmax() + PADDED_CELL_SIZE, m_domain.getMaxX());
+            cell_xmax = m_domain.getMaxX();
             break;
         case 2:
             // Rightmost internal cell
@@ -69,7 +67,7 @@ Grid<infinite_extent>::getCellEnvelope(size_t row, size_t col) const
     if (row == 0) {
         // Top row padding
-        cell_ymax = std::max(ymax() + PADDED_CELL_SIZE, m_domain.getMaxY());
+        cell_ymax = m_domain.getMaxY();
     } else if (row == getNumRows() - 1) {
         // Bottom row padding
         cell_ymax = ymin(); // because bottom row of regular may have different height from others
@@ -80,7 +78,7 @@ Grid<infinite_extent>::getCellEnvelope(size_t row, size_t col) const
     switch (getNumRows() - row) {
         case 1:
-            cell_ymin = std::min(xmin() - PADDED_CELL_SIZE, m_domain.getMinY());
+            cell_ymin = m_domain.getMinY();
             break;
         case 2:
             // Bottom-most internal row
diff --git a/src/operation/grid/GridIntersection.cpp b/src/operation/grid/GridIntersection.cpp
index c60c3aaec..ef94ce5ad 100644
--- a/src/operation/grid/GridIntersection.cpp
+++ b/src/operation/grid/GridIntersection.cpp
@@ -34,6 +34,24 @@ using geos::geom::CoordinateXY;
+static Envelope
+getDomain(const Envelope& gridExtent, const Envelope& geomExtent)
+    constexpr double PADDED_CELL_SIZE = 1.0;
+    constexpr double PADDED_CELL_RELATIVE_SIZE = 1e-12;
+    Envelope padded(gridExtent);
+    padded.expandToInclude(geomExtent);
+    const double xmag = std::max(std::abs(padded.getMinX()), std::abs(padded.getMaxX()));
+    const double ymag = std::max(std::abs(padded.getMinY()), std::abs(padded.getMaxY()));
+    padded.expandBy(std::max(PADDED_CELL_SIZE, PADDED_CELL_RELATIVE_SIZE * xmag),
+                    std::max(PADDED_CELL_SIZE, PADDED_CELL_RELATIVE_SIZE * ymag));
+    return padded;
 std::shared_ptr<Matrix<float>>
 GridIntersection::getIntersectionFractions(const Grid<bounded_extent>& raster_grid, const Geometry& g)
@@ -111,7 +129,7 @@ GridIntersection::processingRegion(const Envelope& raster_extent, const Geometry
 GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, const Geometry& g, const std::shared_ptr<Matrix<float>>& cov)
-  : m_geometry_grid{ make_infinite(raster_grid, *g.getEnvelopeInternal()) }
+  : m_geometry_grid{ make_infinite(raster_grid, getDomain(raster_grid.getExtent(), *g.getEnvelopeInternal())) }
   , m_results{ cov ? cov : std::make_shared<Matrix<float>>(raster_grid.getNumRows(), raster_grid.getNumCols()) }
   , m_first_geom{ true }
   , m_areal{ false }
@@ -130,7 +148,7 @@ GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, cons
 GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, const Envelope& box, const std::shared_ptr<Matrix<float>>& cov)
-  : m_geometry_grid{ make_infinite(raster_grid, box) }
+  : m_geometry_grid{ make_infinite(raster_grid, getDomain(raster_grid.getExtent(), box)) }
   , m_first_geom { true }
   , m_areal{ false }
@@ -182,6 +200,10 @@ GridIntersection::processRectangularRing(const Envelope& box, bool exterior_ring
     auto ring_grid = getSubgrid(box, m_geometry_grid);
+    if (ring_grid.isEmpty()) {
+        return;
     auto row_min = ring_grid.getRow(box.getMaxY());
     auto row_max = ring_grid.getRow(box.getMinY());
     auto col_min = ring_grid.getColumn(box.getMinX());
@@ -590,8 +612,7 @@ GridIntersection::subdividePolygon(const Grid<bounded_extent>& p_grid, const Geo
     const auto cropped_grid = p_grid.shrinkToFit(p_grid.getExtent().intersection(*g.getEnvelopeInternal()), false);
-    geom::Envelope gridExtent = *g.getEnvelopeInternal();
-    gridExtent.expandBy(1);
+    geom::Envelope gridExtent = getDomain(cropped_grid.getExtent(), *g.getEnvelopeInternal());
     const Grid<infinite_extent> cell_grid = make_infinite(cropped_grid, gridExtent);
     Matrix<std::unique_ptr<Cell>> cells(cell_grid.getNumRows(), cell_grid.getNumCols());
diff --git a/tests/unit/operation/grid/GridIntersectionTest.cpp b/tests/unit/operation/grid/GridIntersectionTest.cpp
index 2c5cb8a01..940d54f3a 100644
--- a/tests/unit/operation/grid/GridIntersectionTest.cpp
+++ b/tests/unit/operation/grid/GridIntersectionTest.cpp
@@ -998,4 +998,98 @@ void object::test<53>() {
     ensure(subd->getGeometryN(1)->equals(outside.get()));
+template<>
+template<>
+void object::test<54>()
+    Envelope e(0, 10, 0, 10);
+    Grid<bounded_extent> ext(e, 0.1, 0.1);
+    auto g = wkt_reader_.read("POLYGON ((0.3 0.3, 4.7 0.3, 2.5 6.2, 0.3 0.3))");
+    auto fracs = GridIntersection::getIntersectionFractions(ext, *g);
+    auto tot = std::accumulate(fracs->begin(), fracs->end(), 0.0);
+    ensure_equals("check area", tot/100, g->getArea(), 1e-6);
+template<>
+template<>
+void object::test<55>()
+    set_test_name("getIntersectionFractions: traversal stays in grid when a vertex is the top corner of the geometry envelope");
+    // The vertex at (-259.05369950585896 811.4225290921494) is the upper-left corner of the polygon envelope
+    // and lies on a cell boundary, to within rounding.
+    Envelope e(-300.91149168825694, -175.33811514106293, 225.41343853857734, 602.13356818015927);
+    Grid<bounded_extent> ext(e, e.getWidth() / 6, e.getHeight() / 18);
+    auto g = wkt_reader_.read("POLYGON ((-70.69363468506793 685.8491525449554, -133.48032295866494 748.6358408185523, -175.33811514106293 790.4936330009504, -259.05369950585896 811.4225290921494, -238.12480341465994 706.7780486361544, -259.05369950585896 664.9202564537563, -259.05369950585896 581.2046720889604, -196.26701123226195 643.9913603625573, -112.55142686746595 623.0624642713583, -70.69363468506793 685.8491525449554))");
+    auto inside = g->intersection(g->getFactory()->toGeometry(&e).get());
+    check_area(*fracs, ext, *inside);
+template<>
+template<>
+void object::test<56>()
+    set_test_name("getIntersectionFractions: traversal stays in grid when a vertex is the bottom corner of the geometry envelope");
+    // The vertex at (68.44482903503193 -90.56515438144179) is the lower-right corner of the polygon envelope
+    Envelope e(-10.004484448704343, 152.12409675101728, 35.385086543444757, 73.717768564062396);
+    Grid<bounded_extent> ext(e, e.getWidth() / 31, e.getHeight() / 14);
+    auto g = wkt_reader_.read("POLYGON ((173.04391368001362 60.02752498527039, 78.9047374995301 109.31240186892164, 89.36464596402827 257.1670325198754, -25.694347145451598 213.35825306774097, -93.68375216468971 161.3353274683313, -104.14366062918788 90.14606085861283, -119.83352332593513 24.432891680411146, -51.84411830669703 5.266550670102323, -20.464392913202513 -52.23247236082415, 68.44482903503193 -90.56515438144179, 173.04391368001362 -54.97052107658256, 173.04391368001362 60.02752498527039))");
+template<>
+template<>
+void object::test<57>()
+    set_test_name("subdividePolygon: traversal stays in grid when padding is lost to rounding at large coordinates");
+    // At 1e22, adding a fixed padding of 1 to the geometry envelope has no effect,
+    // so the vertex at (1e22 0.9) would lie on the outer edge of a padding cell.
+    Envelope e(-0.375, 2.1875, -0.375, 2.1875);
+    Grid<bounded_extent> ext(e, e.getWidth() / 64, e.getHeight() / 2);
+    auto g = wkt_reader_.read("POLYGON ((0.1 0.1, 0.1 0.2, 0.95 0.95, 1e22 0.9, 0.1 0.1))");
+    auto subd = GridIntersection::subdividePolygon(ext, *g, false);
+    check_subdivided_polygon(*inside, *subd);
+template<>
+template<>
+void object::test<58>()
+    set_test_name("getIntersectionFractions: box sharing an edge with the grid");
+    Grid<bounded_extent> ext(e, 1, 1);
+    for (const auto& box : {
+        Envelope(10, 20, 0, 10),
+        Envelope(0, 10, 10, 20),
+        Envelope(-10, 0, -10, 0) })
+        auto fracs = GridIntersection::getIntersectionFractions(ext, box);
+        ensure_equals(tot, 0.0);
diff --git a/tests/unit/operation/grid/GridTest.cpp b/tests/unit/operation/grid/GridTest.cpp
index 0df5ea8a7..c142c4911 100644
--- a/tests/unit/operation/grid/GridTest.cpp
+++ b/tests/unit/operation/grid/GridTest.cpp
@@ -314,8 +314,10 @@ void object::test<17>()
     set_test_name("Crop infinite grid while calculating cell boundaries relative to parent");
     double res = 1.0/3601;
+    Envelope domain = global;
+    domain.expandBy(1);
-    Grid<infinite_extent> grid{global, res, res, global};
+    Grid<infinite_extent> grid{global, res, res, domain};
     const auto env0 = grid.getCellEnvelope(30, 30);
Summary of changes:
 NEWS.md                                            |  2 +
 include/geos/operation/grid/Grid.h                 |  7 ++
 src/operation/grid/Grid.cpp                        | 10 +--
 src/operation/grid/GridIntersection.cpp            | 29 ++++++-
 src/operation/relateng/AdjacentEdgeLocator.cpp     |  4 +
 tests/unit/operation/grid/GridIntersectionTest.cpp | 94 ++++++++++++++++++++++
 tests/unit/operation/grid/GridTest.cpp             |  4 +-
 tests/unit/operation/relateng/RelateNGTest.cpp     | 14 +++-
 8 files changed, 152 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
