[geos-commits] [SCM] GEOS branch main updated. 06da4f3a7808288b3aef036aed02c866038985ad
git at osgeo.org
git at osgeo.org
Sun Nov 8 09:16:36 PST 2026
the project "GEOS".
The branch, main has been updated
via 06da4f3a7808288b3aef036aed02c866038985ad (commit)
from 2c8e04faf8235456b417979bcf23271ef34148a7 (commit)
revisions in full, below.
commit 06da4f3a7808288b3aef036aed02c866038985ad
Author: Alejandro <ale at alepacheco.dev>
Date: Mon Nov 9 00:16:01 2026 +0700
GridIntersection: keep traversal on the grid when a segment's slope underflows (#1593)
* GridIntersection: keep traversal on the grid when a segment's slope underflows
crossing() picked the side through which a segment leaves a cell using
the segment's slope dy/dx. For a nearly horizontal segment the slope
underflows to zero (e.g. 2e-30 / 1e300), and for a nearly vertical one
it overflows to infinity, so the wrong side can be chosen. In a padding
cell this sends traverseCells() outside the cell matrix, where
get_cell() only asserts.
- crossing(): interpolate using the fraction of the segment's extent in
x or y instead of its slope. The coordinate is still computed from
the same endpoint, so a segment gives the same result in either
orientation.
- get_cell(): throw instead of asserting when the traversal leaves the
grid.
* Edit comments
Co-authored-by: Dan Baston <dbaston at gmail.com>
diff --git a/src/operation/grid/Cell.cpp b/src/operation/grid/Cell.cpp
index 45b652d7c..f48f728ae 100644
--- a/src/operation/grid/Cell.cpp
+++ b/src/operation/grid/Cell.cpp
@@ -64,7 +64,10 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
- const double m = std::abs((c2.y - c1.y) / (c2.x - c1.x));
+ // Interpolate with the fraction of the segment's extent in x or y rather than with its slope, which
+ // underflows to zero or overflows to infinity when the segment is nearly horizontal or vertical.
+ const double dx = std::abs(c2.x - c1.x);
+ const double dy = std::abs(c2.y - c1.y);
const bool up = c2.y > c1.y;
const bool right = c2.x > c1.x;
@@ -73,22 +76,22 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
if (right) {
// 1st quadrant
- const double y2 = c1.y + m * (e.getMaxX() - c1.x);
+ const double y2 = c1.y + dy * ((e.getMaxX() - c1.x) / dx);
if (y2 < e.getMaxY()) {
return Crossing{ Side::RIGHT, e.getMaxX(), std::clamp(y2, e.getMinY(), e.getMaxY()) };
} else {
- double x2 = c1.x + (e.getMaxY() - c1.y) / m;
+ double x2 = c1.x + dx * ((e.getMaxY() - c1.y) / dy);
return Crossing{ Side::TOP, std::clamp(x2, e.getMinX(), e.getMaxX()), e.getMaxY() };
} else {
// 2nd quadrant
- const double y2 = c1.y + m * (c1.x - e.getMinX());
+ const double y2 = c1.y + dy * ((c1.x - e.getMinX()) / dx);
return Crossing{ Side::LEFT, e.getMinX(), std::clamp(y2, e.getMinY(), e.getMaxY()) };
} else {
- double x2 = c1.x - (e.getMaxY() - c1.y) / m;
+ double x2 = c1.x - dx * ((e.getMaxY() - c1.y) / dy);
@@ -100,22 +103,22 @@ crossing(const geom::Envelope& e, const CoordinateXY& c1, const CoordinateXY& c2
if (right) {
// 4th quadrant
- const double y2 = c2.y + m * (c2.x - e.getMaxX());
+ const double y2 = c2.y + dy * ((c2.x - e.getMaxX()) / dx);
if (y2 > e.getMinY()) {
} else {
- double x2 = c2.x - (e.getMinY() - c2.y) / m;
+ double x2 = c2.x - dx * ((e.getMinY() - c2.y) / dy);
return Crossing{ Side::BOTTOM, std::clamp(x2, e.getMinX(), e.getMaxX()), e.getMinY() };
} else {
// 3rd quadrant
- const double y2 = c2.y + m * (e.getMinX() - c2.x);
+ const double y2 = c2.y + dy * ((e.getMinX() - c2.x) / dx);
} else {
- double x2 = c2.x + (e.getMinY() - c2.y) / m;
+ double x2 = c2.x + dx * ((e.getMinY() - c2.y) / dy);
diff --git a/src/operation/grid/GridIntersection.cpp b/src/operation/grid/GridIntersection.cpp
index ef94ce5ad..8440b84fd 100644
--- a/src/operation/grid/GridIntersection.cpp
+++ b/src/operation/grid/GridIntersection.cpp
@@ -69,8 +69,12 @@ GridIntersection::getIntersectionFractions(const Grid<bounded_extent>& raster_gr
static Cell*
get_cell(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& ex, size_t row, size_t col)
- assert(row < cells.getNumRows());
- assert(col < cells.getNumCols());
+ // A traversal that leaves the grid through its first row or column
+ // wraps around to SIZE_MAX, so one comparison covers both directions.
+ if (row >= cells.getNumRows() || col >= cells.getNumCols()) {
+ throw util::GEOSException("Grid traversal left the grid.");
if (cells(row, col) == nullptr) {
cells(row, col) = std::make_unique<Cell>(ex.getCellEnvelope(row, col));
diff --git a/tests/unit/operation/grid/GridIntersectionTest.cpp b/tests/unit/operation/grid/GridIntersectionTest.cpp
index 940d54f3a..d1ce00c99 100644
--- a/tests/unit/operation/grid/GridIntersectionTest.cpp
+++ b/tests/unit/operation/grid/GridIntersectionTest.cpp
@@ -1092,4 +1092,66 @@ void object::test<58>()
+template<>
+template<>
+void object::test<59>()
+ set_test_name("subdividePolygon: traversal stays in grid when the slope of a segment underflows");
+ // The first edge crosses y = 0 far to the right of the grid, so it leaves the right
+ // padding cell through its top. Its slope (2e-30 / 1e300) underflows to zero.
+ Envelope e(0, 10, -5, 5);
+ Grid<bounded_extent> ext(e, 1, 5);
+ auto g = wkt_reader_.read("POLYGON ((2 -1e-30, 1e300 1e-30, 1e300 1, 2 1, 2 -1e-30))");
+ auto subd = GridIntersection::subdividePolygon(ext, *g, false);
+ // Part of the polygon inside the grid extent
+ // input manually because g->getFactory()->toGeometry(&e)->intersection(g.get()) gives POLYGON EMPTY
+ auto inside = wkt_reader_.read("POLYGON ((2 0, 10 0, 10 1, 2 1, 2 0))");
+ check_subdivided_polygon(*inside, *subd);
+template<>
+template<>
+void object::test<60>()
+ set_test_name("getIntersectionFractions: traversal stays in grid when the slope of a segment underflows");
+ // Same as the previous test, with an extra vertex so that the ring is not processed as a rectangle.
+ auto g = wkt_reader_.read("POLYGON ((2 -1e-30, 1e300 1e-30, 1e300 1, 5 1, 2 1, 2 -1e-30))");
+ auto fracs = GridIntersection::getIntersectionFractions(ext, *g);
+ check_area(*fracs, ext, *inside);
+template<>
+template<>
+void object::test<61>()
+ set_test_name("subdividePolygon: traversal stays in grid when the slope of a segment overflows");
+ // The first edge crosses x = 0 far below the grid, so it leaves the bottom padding
+ // cell through its left side. Its slope (1e300 / 2e-30) overflows to infinity.
+ Envelope e(-5, 5, -10, 0);
+ Grid<bounded_extent> ext(e, 5, 1);
+ auto g = wkt_reader_.read("POLYGON ((1e-30 -2.5, -1e-30 -1e300, -1 -1e300, -1 -2.5, 1e-30 -2.5))");
+ // input manually because g->getFactory()->toGeometry(&e)->intersection(g.get()) gives a LINESTRING
+ auto inside = wkt_reader_.read("POLYGON ((-1 -10, 0 -10, 0 -2.5, -1 -2.5, -1 -10))");
Summary of changes:
src/operation/grid/Cell.cpp | 21 ++++----
src/operation/grid/GridIntersection.cpp | 8 ++-
tests/unit/operation/grid/GridIntersectionTest.cpp | 62 ++++++++++++++++++++++
3 files changed, 80 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits
