[geos-commits] [SCM] GEOS branch main updated. cd6b251809cc60f1d05684b324eaac1635ab04d9
Thu Oct 1 06:05:33 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  cd6b251809cc60f1d05684b324eaac1635ab04d9 (commit)
      from  2e9e1b5bdeb2af6cd4b4e0161bc810e5e273235e (commit)
revisions in full, below.
commit cd6b251809cc60f1d05684b324eaac1635ab04d9
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Oct 1 09:05:15 2026 -0400
    TopologyPreservingSimplifier: Avoid stack overflow (#1519)
    References https://github.com/libgeos/geos/issues/1515
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index 842710ae8..69e88f904 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -89,101 +89,112 @@ TaggedLineStringSimplifier::simplify(TaggedLineString* nLine, double distanceTol
+struct Section {
+std::size_t i;
+std::size_t j;
+std::size_t depth;
 /*private*/
 void
-TaggedLineStringSimplifier::simplifySection(std::size_t i,
-        std::size_t j, std::size_t depth, double distanceTolerance)
+TaggedLineStringSimplifier::simplifySection(std::size_t init_i,
+        std::size_t init_j, std::size_t init_depth, double distanceTolerance)
-    depth += 1;
+    std::stack<Section> stack;
+    stack.push({init_i, init_j, init_depth + 1});
-#if GEOS_DEBUG
-    std::cerr << "TaggedLineStringSimplifier[" << this << "] "
-              << " simplifying section " << i << "-" << j
-              << std::endl;
-#endif
+    while (!stack.empty()) {
+        const auto [i, j, depth] = stack.top();
+        stack.pop();
-    if((i + 1) == j) {
-#if GEOS_DEBUG
-        std::cerr << "single segment, no flattening"
+    #if GEOS_DEBUG
+        std::cerr << "TaggedLineStringSimplifier[" << this << "] "
+                  << " simplifying section " << i << "-" << j
                   << std::endl;
-#endif
-        std::unique_ptr<TaggedLineSegment> newSeg(new
-                                             TaggedLineSegment(*(line->getSegment(i))));
+    #endif
-        line->addToResult(std::move(newSeg));
-        // leave this segment in the input index, for efficiency
-        return;
+        if((i + 1) == j) {
-    bool isValidToSimplify = true;
+    #if GEOS_DEBUG
+            std::cerr << "single segment, no flattening"
+                      << std::endl;
+    #endif
+            auto newSeg = std::make_unique<TaggedLineSegment>(*(line->getSegment(i)));
-     * Following logic ensures that there is enough points in the
-     * output line.
-     * If there is already more points than the minimum, there's
-     * nothing to check.
-     * Otherwise, if in the worst case there wouldn't be enough points,
-     * don't flatten this segment (which avoids the worst case scenario)
-    if(line->getResultSize() < line->getMinimumSize()) {
-        std::size_t worstCaseSize = depth + 1;
-        if(worstCaseSize < line->getMinimumSize()) {
+            line->addToResult(std::move(newSeg));
+            // leave this segment in the input index, for efficiency
+            continue;
+        bool isValidToSimplify = true;
+         * Following logic ensures that there is enough points in the
+         * output line.
+         * If there is already more points than the minimum, there's
+         * nothing to check.
+         * Otherwise, if in the worst case there wouldn't be enough points,
+         * don't flatten this segment (which avoids the worst case scenario)
+        if(line->getResultSize() < line->getMinimumSize()) {
+            std::size_t worstCaseSize = depth + 1;
+            if(worstCaseSize < line->getMinimumSize()) {
+                isValidToSimplify = false;
+        double distance;
+        // pass distance by ref
+        std::size_t furthestPtIndex = findFurthestPoint(linePts, i, j, distance);
+    #if GEOS_DEBUG
+        std::cerr << "furthest point " << furthestPtIndex
+                  << " at distance " << distance
+                  << std::endl;
+    #endif
+        if (distance < 0) {
+            // negative distance indicates that we could not compute distance to the
+            // farthest point, probably because of infinite or large-magnitude coordinates.
+            // avoid trying to simplify this section.
+            for (std::size_t k = i; k < j; k++) {
+                auto newSeg = std::make_unique<TaggedLineSegment>(*(line->getSegment(k)));
+            continue;
+        // flattening must be less than distanceTolerance
+        if(distance > distanceTolerance) {
-    double distance;
-    // pass distance by ref
-    std::size_t furthestPtIndex = findFurthestPoint(linePts, i, j, distance);
-#if GEOS_DEBUG
-    std::cerr << "furthest point " << furthestPtIndex
-              << " at distance " << distance
-              << std::endl;
-#endif
-    if (distance < 0) {
-        // negative distance indicates that we could not compute distance to the
-        // farthest point, probably because of infinite or large-magnitude coordinates.
-        // avoid trying to simplify this section.
-        for (std::size_t k = i; k < j; k++) {
-            auto newSeg = std::make_unique<TaggedLineSegment>(*(line->getSegment(k)));
+        if (isValidToSimplify) {
+            // test if flattened section would cause intersection or jump
+            LineSegment flatSeg(linePts->getAt(i), linePts->getAt(j));
+            isValidToSimplify = isTopologyValid(line, i, j, flatSeg);
-        return;
+        if(isValidToSimplify) {
+            std::unique_ptr<TaggedLineSegment> newSeg = flatten(i, j);
+    #if GEOS_DEBUG
+            std::cerr << "isValidToSimplify, adding seg "
+                      << newSeg->p0 << ", " << newSeg->p1
+                      << " to TaggedLineSegment[" << line << "] result "
+                      << std::endl;
+    #endif
+            continue;
+        stack.push({furthestPtIndex, j, depth+1});
+        stack.push({i, furthestPtIndex, depth+1});
-    // flattening must be less than distanceTolerance
-    if(distance > distanceTolerance) {
-        isValidToSimplify = false;
-    if (isValidToSimplify) {
-        // test if flattened section would cause intersection or jump
-        LineSegment flatSeg(linePts->getAt(i), linePts->getAt(j));
-        isValidToSimplify = isTopologyValid(line, i, j, flatSeg);
-    if(isValidToSimplify) {
-        std::unique_ptr<TaggedLineSegment> newSeg = flatten(i, j);
-#if GEOS_DEBUG
-        std::cerr << "isValidToSimplify, adding seg "
-                  << newSeg->p0 << ", " << newSeg->p1
-                  << " to TaggedLineSegment[" << line << "] result "
-                  << std::endl;
-#endif
-        return;
-    simplifySection(i, furthestPtIndex, depth, distanceTolerance);
-    simplifySection(furthestPtIndex, j, depth, distanceTolerance);
 /*private*/
diff --git a/src/simplify/TopologyPreservingSimplifier.cpp b/src/simplify/TopologyPreservingSimplifier.cpp
index b796610e0..e798a47f1 100644
--- a/src/simplify/TopologyPreservingSimplifier.cpp
+++ b/src/simplify/TopologyPreservingSimplifier.cpp
@@ -186,14 +186,13 @@ LineStringMapBuilderFilter::filter_ro(const Geometry* geom)
     auto ls = static_cast<const LineString*>(geom);
     std::size_t minSize = ls->isClosed() ? 4 : 2;
-    TaggedLineString* taggedLine = new TaggedLineString(ls, minSize, isRing);
+    auto taggedLine = std::make_unique<TaggedLineString>(ls, minSize, isRing);
     // Duplicated Geometry pointers shouldn't happen
-    if(! linestringMap.insert(std::make_pair(geom, taggedLine)).second) {
-        delete taggedLine;
+    if(! linestringMap.insert(std::make_pair(geom, taggedLine.get())).second) {
         throw util::GEOSException("Duplicated Geometry components detected");
-    tlsVector.push_back(taggedLine);
+    tlsVector.push_back(taggedLine.release());
diff --git a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
index 651627b05..48a178ce5 100644
--- a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
+++ b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
@@ -473,4 +473,23 @@ void object::test<36>()
+template<>
+template<>
+void object::test<37>()
+    set_test_name("no stack overflow with large number of repeated vertices");
+    const std::size_t n = 10000;
+    auto seq = std::make_shared<CoordinateSequence>(n, false, false);
+    for (std::size_t i = 0; i < n; i++) {
+        seq->setAt(geos::geom::CoordinateXY{1, 1}, i);
+    auto input = gf->createLineString(seq);
+    auto simplified = TopologyPreservingSimplifier::simplify(input.get(), 1e-3);
+    // No crash
 } // namespace tut
Summary of changes:
 src/simplify/TaggedLineStringSimplifier.cpp        | 157 +++++++++++----------
 src/simplify/TopologyPreservingSimplifier.cpp      |   7 +-
 .../simplify/TopologyPreservingSimplifierTest.cpp  |  19 +++
 3 files changed, 106 insertions(+), 77 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
