[geos-commits] [SCM] GEOS branch main updated. 7e7c2689257fa53ee3252c44264a776bc74c9c9f
Thu Oct 1 07:11:19 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  7e7c2689257fa53ee3252c44264a776bc74c9c9f (commit)
      from  cd6b251809cc60f1d05684b324eaac1635ab04d9 (commit)
revisions in full, below.
commit 7e7c2689257fa53ee3252c44264a776bc74c9c9f
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Sep 30 16:45:35 2026 +0200
    Add IsSimpleWithParams with params create/destroy/setters
    Closes GH-1543
    Includes unit test for the new CAPI signatures
diff --git a/NEWS.md b/NEWS.md
index 10451996e..ccf7bf58a 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -9,6 +9,7 @@
 - New things:
   - Expose code revision: GEOS_REVISION, GEOSrevision, geos-config --revision
     (GH-1446 Sandro Santilli)
+  - GEOSisSimpleWithParams (GH-1543 Sandro Santilli)
 ## Changes in 3.15.0
 2026-09-01
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 568f1c0b4..b2918e466 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -69,6 +69,11 @@ typedef struct {
     int keepCollapsed;
 } GEOSMakeValidParams;
+// Implementation struct for the GEOSisSimpleParams object
+typedef struct {
+    bool findAllLocations;
+    int boundaryNodeRule;
+} GEOSisSimpleParams;
 #include "geos_c.h"
@@ -546,6 +551,36 @@ extern "C" {
         return GEOSisSimpleDetail_r(handle, g, returnAllPoints, result);
+    GEOSisSimpleParams*
+    GEOSisSimpleParams_create(void)
+        return GEOSisSimpleParams_create_r(handle);
+    void
+    GEOSisSimpleParams_destroy(GEOSisSimpleParams* parms)
+        return GEOSisSimpleParams_destroy_r(handle, parms);
+    void
+    GEOSisSimpleParams_setFindAllLocations(GEOSisSimpleParams* params, int val)
+        return GEOSisSimpleParams_setFindAllLocations_r(handle, params, val);
+    void
+    GEOSisSimpleParams_setBoundaryNodeRule(GEOSisSimpleParams* params, int bnr)
+        return GEOSisSimpleParams_setBoundaryNodeRule_r(handle, params, bnr);
+    char
+    GEOSisSimpleWithParams(const Geometry *g, const GEOSisSimpleParams* params, Geometry** result)
+        return GEOSisSimpleWithParams_r(handle, g, params, result);
     char
     GEOSisRing(const Geometry* g)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 19ec83cd0..ae9d7c384 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -220,7 +220,15 @@ typedef struct GEOSCurveToLineParams_t GEOSCurveToLineParams;
 typedef struct GEOSLineToCurveParams_t GEOSLineToCurveParams;
-#endif
+* Parameter object for simplicity check.
+* \see GEOSisSimpleParams_create()
+* \see GEOSisSimpleParams_destroy()
+typedef struct GEOSisSimpleParams_t GEOSisSimpleParams;
+#endif /* ndef GEOSGeometry */
 /** \cond */
@@ -1678,6 +1686,36 @@ extern char GEOS_DLL GEOSisSimple_r(
     GEOSContextHandle_t handle,
     const GEOSGeometry* g);
+/** \see GEOSIsSimpleParams_create */
+extern GEOSisSimpleParams GEOS_DLL *
+GEOSisSimpleParams_create_r(
+    GEOSContextHandle_t handle);
+/** \see GEOSIsSimpleParams_destroy */
+extern void GEOS_DLL
+GEOSisSimpleParams_destroy_r(
+    GEOSContextHandle_t handle,
+    GEOSisSimpleParams* params);
+/** \see GEOSisSimpleParams_setFindAllLocations */
+extern void GEOS_DLL GEOSisSimpleParams_setFindAllLocations_r(
+    GEOSisSimpleParams* params,
+    int findAllLocations);
+/** \see GEOSisSimpleParams_setBoundaryNodeRule */
+extern void GEOS_DLL GEOSisSimpleParams_setBoundaryNodeRule_r(
+    int bnr);
+/** \see GEOSisSimpleWithParams */
+extern char GEOS_DLL GEOSisSimpleWithParams_r(
+    const GEOSGeometry* g,
+    const GEOSisSimpleParams* params,
+    GEOSGeometry** location);
 /** \see GEOSisRing */
 extern char GEOS_DLL GEOSisRing_r(
@@ -3680,6 +3718,71 @@ extern char GEOS_DLL GEOSisSimpleDetail(
     int findAllLocations,
     GEOSGeometry** locations);
+* Create a GEOSisSimpleParams to hold the desired parameters
+* to control the algorithm and behavior of the simplicity check process.
+* \return a parameter object configured to find all intersection
+*                            and use Mod2 boundary node rule
+* \see GEOSisSimpleWithParams
+* \since 3.16
+extern GEOSisSimpleParams GEOS_DLL *GEOSisSimpleParams_create(void);
+* Destroy a GEOSisSimpleParams.
+* \param params the object to destroy
+* \since 3.16
+extern void GEOS_DLL GEOSisSimpleParams_destroy(GEOSisSimpleParams* params);
+* Set whether to return all self-intersection locations or just one
+* \param params the object to modify
+* \param findAllLocations Whether to return all self-intersection locations, or just one
+* \since 3.16
+extern void GEOS_DLL GEOSisSimpleParams_setFindAllLocations(
+* Set BoundaryNodeRule to use with the simplicity check
+* \param bnr A member of the \ref GEOSRelateBoundaryNodeRules enum
+* \since 3.16
+extern void GEOS_DLL GEOSisSimpleParams_setBoundaryNodeRule(
+    int bnr);
+* In one step, calculate and return whether a geometry is simple
+* and one more more points at which the geometry self-intersects
+* at interior points.
+* Caller has the responsibility to destroy 'location' with
+* GEOSGeom_destroy()
+* @INPUT_CURVES_CONVERTED_TO_LINES@
+* \param g The geometry to test
+* \param params various parameters for the operation
+* \param locations A pointer in which the location GEOSGeometry will be placed
+* \return 1 when simple, 0 when non-simple, 2 on exception
+* \since 3.16
+extern char GEOS_DLL GEOSisSimpleWithParams(
+    GEOSGeometry** locations);
 * Check the validity of the provided geometry.
 * - All points are valid.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e118726e7..1f05db1ff 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -177,6 +177,12 @@ typedef struct {
     int keepCollapsed;
+typedef struct {
 #include "geos_c.h"
 // Intentional, to allow non-standard C elements like C99 functions to be
@@ -1550,6 +1556,10 @@ extern "C" {
+ * IsSimpleOp {
     char
     GEOSisSimple_r(GEOSContextHandle_t extHandle, const Geometry* g1)
@@ -1583,6 +1593,92 @@ extern "C" {
+    GEOSisSimpleParams_create_r(GEOSContextHandle_t extHandle)
+        using geos::algorithm::BoundaryNodeRule;
+        return execute(extHandle, [&]() {
+            GEOSisSimpleParams* p = new GEOSisSimpleParams();
+            p->findAllLocations = false;
+            p->boundaryNodeRule = GEOSRELATE_BNR_MOD2;
+            return p;
+    void
+    GEOSisSimpleParams_destroy_r(GEOSContextHandle_t extHandle, GEOSisSimpleParams* parms)
+        (void)extHandle;
+        delete parms;
+    void
+    GEOSisSimpleParams_setFindAllLocations_r(GEOSContextHandle_t extHandle, GEOSisSimpleParams* params, int val)
+        (void)extHandle;
+        params->findAllLocations = val;
+    void
+    GEOSisSimpleParams_setBoundaryNodeRule_r(GEOSContextHandle_t extHandle, GEOSisSimpleParams* params, int bnr)
+        (void)extHandle;
+        params->boundaryNodeRule = bnr;
+    char
+    GEOSisSimpleWithParams_r(GEOSContextHandle_t extHandle, const Geometry* g1, const GEOSisSimpleParams* params, Geometry** result)
+        using geos::operation::valid::IsSimpleOp;
+        return execute(extHandle, 2, [&]() {
+            const auto inputGeom = convertToLineIfNeeded(extHandle, g1);
+            std::unique_ptr<IsSimpleOp> op;
+            switch ( params->boundaryNodeRule ) {
+                case GEOSRELATE_BNR_MOD2: /* same as OGC */
+                    op = std::make_unique<IsSimpleOp>(*inputGeom, BoundaryNodeRule::getBoundaryRuleMod2());
+                    break;
+                case GEOSRELATE_BNR_ENDPOINT:
+                    op = std::make_unique<IsSimpleOp>(*inputGeom, BoundaryNodeRule::getBoundaryEndPoint());
+                    break;
+                case GEOSRELATE_BNR_MULTIVALENT_ENDPOINT:
+                    op = std::make_unique<IsSimpleOp>(*inputGeom, BoundaryNodeRule::getBoundaryMultivalentEndPoint());
+                    break;
+                case GEOSRELATE_BNR_MONOVALENT_ENDPOINT:
+                    op = std::make_unique<IsSimpleOp>(*inputGeom, BoundaryNodeRule::getBoundaryMonovalentEndPoint());
+                    break;
+                default:
+                    std::ostringstream ss;
+                    ss << "Invalid boundary node rule " << params->boundaryNodeRule;
+                    throw std::runtime_error(ss.str());
+            op->setFindAllLocations( params->findAllLocations );
+            *result = nullptr;
+            bool simple = op->isSimple();
+            if (!simple) {
+                auto locations = op->getNonSimpleLocations();
+                if (locations.size() == 1 || ! params->findAllLocations ) {
+                    *result = extHandle->geomFactory->createPoint(locations.front()).release();
+                } else {
+                    *result = extHandle->geomFactory->createMultiPoint(locations).release();
+            return simple;
+ * IsSimpleOp }
     char
     GEOSisRing_r(GEOSContextHandle_t extHandle, const Geometry* g)
diff --git a/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp b/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
new file mode 100644
index 000000000..f469fea99
--- /dev/null
+++ b/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
@@ -0,0 +1,83 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+struct test_geosissimplewithparams_data : public capitest::utility {
+    GEOSisSimpleParams* _params;
+    test_geosissimplewithparams_data()
+        _params = GEOSisSimpleParams_create();
+    ~test_geosissimplewithparams_data()
+        GEOSisSimpleParams_destroy( _params );
+typedef test_group<test_geosissimplewithparams_data> group;
+typedef group::object object;
+group test_geosissimplewithparams("capi::GEOSisSimpleWithParams");
+template<>
+template<>
+void object::test<1>()
+    input_ = GEOSGeomFromWKT("MULTILINESTRING( (0 0, -10 10,-10 -10, 0 0), (0 0,20 -10,20 10,0 0) )");
+    ensure(nullptr != input_);
+    ensure_equals((int)GEOSisSimpleWithParams(input_, _params, &result_), 0);
+    ensure_geometry_equals(result_, "POINT (0 0)");
+template<>
+template<>
+void object::test<2>()
+    GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_ENDPOINT);
+    ensure_equals((int)GEOSisSimpleWithParams(input_, _params, &result_), 1);
+    ensure(result_ == nullptr);
+template<>
+template<>
+void object::test<3>()
+    GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_MULTIVALENT_ENDPOINT);
+template<>
+template<>
+void object::test<4>()
+    GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_MONOVALENT_ENDPOINT);
+template<>
+template<>
+void object::test<5>()
+    input_ = GEOSGeomFromWKT("MULTILINESTRING( (0 0,10 0),(2 -5,2 5),(4 -5, 4 5) )");
+    GEOSisSimpleParams_setFindAllLocations(_params, 1);
+    ensure_equals(GEOSGetNumGeometries(result_), 2);
+} // namespace tut
Summary of changes:
 NEWS.md                                        |   1 +
 capi/geos_c.cpp                                |  35 +++++++++
 capi/geos_c.h.in                               | 105 ++++++++++++++++++++++++-
 capi/geos_ts_c.cpp                             |  96 ++++++++++++++++++++++
 tests/unit/capi/GEOSisSimpleWithParamsTest.cpp |  83 +++++++++++++++++++
 5 files changed, 319 insertions(+), 1 deletion(-)
 create mode 100644 tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
