[geos-commits] [SCM] GEOS branch main updated. 395d979c05ddcfd729ffe80b2b18e7873dbf8b29
Thu Oct 1 07:24:39 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  395d979c05ddcfd729ffe80b2b18e7873dbf8b29 (commit)
      from  7e7c2689257fa53ee3252c44264a776bc74c9c9f (commit)
revisions in full, below.
commit 395d979c05ddcfd729ffe80b2b18e7873dbf8b29
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 1 16:24:18 2026 +0200
    Use IllegalArgumentException when given invalid boundaryNodeRule
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index ae9d7c384..2635099fd 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3721,7 +3721,7 @@ extern char GEOS_DLL GEOSisSimpleDetail(
 * Create a GEOSisSimpleParams to hold the desired parameters
 * to control the algorithm and behavior of the simplicity check process.
-* \return a parameter object configured to find all intersection
+* \return a parameter object configured to find all intersections
 *                            and use Mod2 boundary node rule
 * \see GEOSisSimpleWithParams
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 1f05db1ff..547e4570f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1035,6 +1035,7 @@ extern "C" {
         using geos::operation::relate::RelateOp;
         using geos::geom::IntersectionMatrix;
         using geos::algorithm::BoundaryNodeRule;
+        using geos::util::IllegalArgumentException;
         return execute(extHandle, [&]() -> char* {
             std::unique_ptr<IntersectionMatrix> im;
@@ -1061,7 +1062,7 @@ extern "C" {
                 default:
                     std::ostringstream ss;
                     ss << "Invalid boundary node rule " << bnr;
-                    throw std::runtime_error(ss.str());
+                    throw IllegalArgumentException(ss.str());
             if(!im) {
@@ -1633,6 +1634,7 @@ extern "C" {
         using geos::operation::valid::IsSimpleOp;
         return execute(extHandle, 2, [&]() {
             const auto inputGeom = convertToLineIfNeeded(extHandle, g1);
@@ -1654,7 +1656,7 @@ extern "C" {
                 default:
                     ss << "Invalid boundary node rule " << params->boundaryNodeRule;
             op->setFindAllLocations( params->findAllLocations );
Summary of changes:
 capi/geos_c.h.in   | 2 +-
 capi/geos_ts_c.cpp | 6 ++++--
 2 files changed, 5 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
