[geos-commits] [SCM] GEOS branch main updated. a8361685706776ba18266ac873d914d99f60ffad
Thu Oct 1 07:35:47 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  a8361685706776ba18266ac873d914d99f60ffad (commit)
      from  395d979c05ddcfd729ffe80b2b18e7873dbf8b29 (commit)
revisions in full, below.
commit a8361685706776ba18266ac873d914d99f60ffad
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 1 16:35:26 2026 +0200
    Properly set SRID in GEOSisSimpleWithParams
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 547e4570f..e35bc743e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1671,6 +1671,7 @@ extern "C" {
                 } else {
                     *result = extHandle->geomFactory->createMultiPoint(locations).release();
+                (*result)->setSRID(inputGeom->getSRID());
             return simple;
diff --git a/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp b/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
index f469fea99..307d53573 100644
--- a/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
+++ b/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
@@ -30,6 +30,8 @@ template<>
 template<>
 void object::test<1>()
+    set_test_name("MultiLineString containing two rings that touch at their endpoints, default params");
     input_ = GEOSGeomFromWKT("MULTILINESTRING( (0 0, -10 10,-10 -10, 0 0), (0 0,20 -10,20 10,0 0) )");
     ensure(nullptr != input_);
     ensure_equals((int)GEOSisSimpleWithParams(input_, _params, &result_), 0);
@@ -40,6 +42,8 @@ template<>
 template<>
 void object::test<2>()
+    set_test_name("MultiLineString containing two rings that touch at their endpoints, EndPoint boundary node rule");
     GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_ENDPOINT);
@@ -51,6 +55,8 @@ template<>
 template<>
 void object::test<3>()
+    set_test_name("MultiLineString containing two rings that touch at their endpoints, MultiValent boundary node rule");
     GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_MULTIVALENT_ENDPOINT);
@@ -62,6 +68,8 @@ template<>
 template<>
 void object::test<4>()
+    set_test_name("MultiLineString containing two rings that touch at their endpoints, MonoValent boundary node rule");
     GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_MONOVALENT_ENDPOINT);
@@ -73,6 +81,8 @@ template<>
 template<>
 void object::test<5>()
+    set_test_name("MultiLineString with a line intersected by two other lines, finding all locations");
     input_ = GEOSGeomFromWKT("MULTILINESTRING( (0 0,10 0),(2 -5,2 5),(4 -5, 4 5) )");
     GEOSisSimpleParams_setFindAllLocations(_params, 1);
@@ -80,4 +90,32 @@ void object::test<5>()
     ensure_equals(GEOSGetNumGeometries(result_), 2);
+template<>
+template<>
+void object::test<6>()
+    set_test_name("Non-simple line with a SRID");
+    input_ = GEOSGeomFromWKT("LINESTRING(0 0,10 0,2 -5,2 5,6 -8)");
+    GEOSSetSRID(input_, 3857);
+    ensure(nullptr != input_);
+    ensure_equals((int)GEOSisSimpleWithParams(input_, _params, &result_), 0);
+    ensure_equals(GEOSGetNumGeometries(result_), 1);
+    ensure_equals(GEOSGetSRID(result_), 3857);
+template<>
+template<>
+void object::test<7>()
+    set_test_name("Non-simple line with a SRID and finding all locations");
+    GEOSSetSRID(input_, 4326);
+    GEOSisSimpleParams_setFindAllLocations(_params, 1);
+    ensure_equals(GEOSGetNumGeometries(result_), 3);
+    ensure_equals(GEOSGetSRID(result_), 4326);
 } // namespace tut
Summary of changes:
 capi/geos_ts_c.cpp                             |  1 +
 tests/unit/capi/GEOSisSimpleWithParamsTest.cpp | 38 ++++++++++++++++++++++++++
 2 files changed, 39 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
