[geos-commits] [SCM] GEOS branch main updated. 5885024d0f7f58085c8ca5260be58863c24410e5
Thu Oct 1 07:45:49 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  5885024d0f7f58085c8ca5260be58863c24410e5 (commit)
       via  c24beb890360ba4a3afb987f332f9a094cd856f0 (commit)
      from  a8361685706776ba18266ac873d914d99f60ffad (commit)
revisions in full, below.
commit 5885024d0f7f58085c8ca5260be58863c24410e5
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 1 16:45:27 2026 +0200
    Allow passign null as locations to GEOSisSimpleWithParams
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 906fb311e..8121af536 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -3708,7 +3708,8 @@ extern char GEOS_DLL GEOSisSimple(const GEOSGeometry* g);
 * \param g The geometry to test
 * \param findAllLocations Whether to return all self-intersection locations, or just one
-* \param locations A pointer in which the location GEOSGeometry will be placed
+* \param locations A pointer in which the location GEOSGeometry will be placed, if any.
+*                  Pass null if you don't want locations.
 * \return 1 when simple, 0 when non-simple, 2 on exception
 * \since 3.14
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e35bc743e..a21c00528 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1661,17 +1661,19 @@ extern "C" {
             op->setFindAllLocations( params->findAllLocations );
-            *result = nullptr;
             bool simple = op->isSimple();
-            if (!simple) {
-                auto locations = op->getNonSimpleLocations();
-                if (locations.size() == 1 || ! params->findAllLocations ) {
-                    *result = extHandle->geomFactory->createPoint(locations.front()).release();
-                } else {
-                    *result = extHandle->geomFactory->createMultiPoint(locations).release();
+            if ( result ) {
+                *result = nullptr;
+                if (!simple) {
+                    auto locations = op->getNonSimpleLocations();
+                    if (locations.size() == 1 || ! params->findAllLocations ) {
+                        *result = extHandle->geomFactory->createPoint(locations.front()).release();
+                    } else {
+                        *result = extHandle->geomFactory->createMultiPoint(locations).release();
+                    (*result)->setSRID(inputGeom->getSRID());
-                (*result)->setSRID(inputGeom->getSRID());
             return simple;
diff --git a/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp b/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
index 307d53573..6bb1b718e 100644
--- a/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
+++ b/tests/unit/capi/GEOSisSimpleWithParamsTest.cpp
@@ -32,8 +32,7 @@ void object::test<1>()
     set_test_name("MultiLineString containing two rings that touch at their endpoints, default params");
-    input_ = GEOSGeomFromWKT("MULTILINESTRING( (0 0, -10 10,-10 -10, 0 0), (0 0,20 -10,20 10,0 0) )");
-    ensure(nullptr != input_);
+    input_ = fromWKT("MULTILINESTRING( (0 0, -10 10,-10 -10, 0 0), (0 0,20 -10,20 10,0 0) )");
     ensure_equals((int)GEOSisSimpleWithParams(input_, _params, &result_), 0);
     ensure_geometry_equals(result_, "POINT (0 0)");
@@ -44,8 +43,7 @@ void object::test<2>()
     set_test_name("MultiLineString containing two rings that touch at their endpoints, EndPoint boundary node rule");
     GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_ENDPOINT);
     ensure_equals((int)GEOSisSimpleWithParams(input_, _params, &result_), 1);
     ensure(result_ == nullptr);
@@ -57,8 +55,7 @@ void object::test<3>()
     set_test_name("MultiLineString containing two rings that touch at their endpoints, MultiValent boundary node rule");
     GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_MULTIVALENT_ENDPOINT);
@@ -70,8 +67,7 @@ void object::test<4>()
     set_test_name("MultiLineString containing two rings that touch at their endpoints, MonoValent boundary node rule");
     GEOSisSimpleParams_setBoundaryNodeRule(_params, GEOSRELATE_BNR_MONOVALENT_ENDPOINT);
@@ -83,8 +79,7 @@ void object::test<5>()
     set_test_name("MultiLineString with a line intersected by two other lines, finding all locations");
-    input_ = GEOSGeomFromWKT("MULTILINESTRING( (0 0,10 0),(2 -5,2 5),(4 -5, 4 5) )");
+    input_ = fromWKT("MULTILINESTRING( (0 0,10 0),(2 -5,2 5),(4 -5, 4 5) )");
     GEOSisSimpleParams_setFindAllLocations(_params, 1);
     ensure_equals(GEOSGetNumGeometries(result_), 2);
@@ -96,9 +91,8 @@ void object::test<6>()
     set_test_name("Non-simple line with a SRID");
-    input_ = GEOSGeomFromWKT("LINESTRING(0 0,10 0,2 -5,2 5,6 -8)");
+    input_ = fromWKT("LINESTRING(0 0,10 0,2 -5,2 5,6 -8)");
     GEOSSetSRID(input_, 3857);
     ensure_equals(GEOSGetNumGeometries(result_), 1);
     ensure_equals(GEOSGetSRID(result_), 3857);
@@ -110,12 +104,24 @@ void object::test<7>()
     set_test_name("Non-simple line with a SRID and finding all locations");
     GEOSSetSRID(input_, 4326);
     ensure_equals(GEOSGetNumGeometries(result_), 3);
     ensure_equals(GEOSGetSRID(result_), 4326);
+template<>
+template<>
+void object::test<8>()
+    set_test_name("Passing NULL as locations for non-simple line");
+    GEOSSetSRID(input_, 4326);
+    GEOSisSimpleParams_setFindAllLocations(_params, 1);
+    ensure_equals((int)GEOSisSimpleWithParams(input_, _params, NULL), 0);
 } // namespace tut
commit c24beb890360ba4a3afb987f332f9a094cd856f0
Date:   Thu Oct 1 16:36:09 2026 +0200
    Fix capitalization
index 2635099fd..906fb311e 100644
@@ -1686,12 +1686,12 @@ extern char GEOS_DLL GEOSisSimple_r(
     GEOSContextHandle_t handle,
-/** \see GEOSIsSimpleParams_create */
+/** \see GEOSisSimpleParams_create */
 extern GEOSisSimpleParams GEOS_DLL *
 GEOSisSimpleParams_create_r(
     GEOSContextHandle_t handle);
-/** \see GEOSIsSimpleParams_destroy */
+/** \see GEOSisSimpleParams_destroy */
 extern void GEOS_DLL
 GEOSisSimpleParams_destroy_r(
Summary of changes:
 capi/geos_c.h.in                               |  7 +++---
 capi/geos_ts_c.cpp                             | 18 ++++++++------
 tests/unit/capi/GEOSisSimpleWithParamsTest.cpp | 34 +++++++++++++++-----------
 3 files changed, 34 insertions(+), 25 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
