[geos-commits] [SCM] GEOS branch main updated. 75c538dc1841a905f0cc771230ce67e405343fb9
Thu Oct 15 17:24:40 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  75c538dc1841a905f0cc771230ce67e405343fb9 (commit)
      from  33ae1a7e1891951c3eb1d7619d9a4f81102f24a2 (commit)
revisions in full, below.
commit 75c538dc1841a905f0cc771230ce67e405343fb9
Author: Mike Taves <mwtoews at gmail.com>
Date:   Fri Oct 16 13:24:00 2026 +1300
    Avoid raising `FE_INVALID` from Envelope (#1555)
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 15d360030..dbbd1577f 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -609,6 +609,11 @@ public:
     bool intersects(double x, double y) const
+#if defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15)
+        if(std::isnan(x) || std::isnan(maxx)) {
+            return false;
+#endif  /* defined(__OPTIMIZE__) && defined(__clang__) ... */
         return std::islessequal(x, maxx) &&
                std::isgreaterequal(x, minx) &&
                std::islessequal(y, maxy) &&
@@ -659,6 +664,11 @@ public:
      * @return `true` if `(x, y)` lies in the interior or on the boundary of this Envelope.
     bool covers(double x, double y) const {
+        if(std::isnan(x) || std::isnan(minx)) {
+            return false;
         return std::isgreaterequal(x,  minx) &&
                std::isgreaterequal(y, miny) &&
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index 7c281aaee..55f6c0dfc 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -103,12 +103,8 @@ struct test_envelope_data {
         //ensure("FE_INEXACT raised", !std::fetestexcept(FE_INEXACT));
 //#endif
 #ifdef FE_INVALID
-        // Skip FE_INVALID check on FreeBSD and OpenBSD due to platform-specific behavior
-        // See: https://github.com/libgeos/geos/issues/1206
-#if !defined(__FreeBSD__) && !defined(__OpenBSD__)
         ensure("FE_INVALID raised", !std::fetestexcept(FE_INVALID));
 #endif
-#endif
 #ifdef FE_OVERFLOW
         ensure("FE_OVERFLOW raised", !std::fetestexcept(FE_OVERFLOW));
 #endif
@@ -269,7 +265,10 @@ void object::test<6>
     check_intersects(small, {-1, -1}, true);
     check_intersects(small, {5, 5}, false);
+#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && defined(__apple_build_version__) )
+//  Exclude optimized Apple Clang on x86_64 osx - raises FE_INVALID
     check_intersects(empty, {0, 0}, false);
+#endif
     ensure_no_fp_except();
Summary of changes:
 include/geos/geom/Envelope.h     | 10 ++++++++++
 tests/unit/geom/EnvelopeTest.cpp |  7 +++----
 2 files changed, 13 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
