[geos-commits] [SCM] GEOS branch 3.15 updated. c991b5dfb4e7b3a14d71c34849d9e257dbff5338
git at osgeo.org
git at osgeo.org
Thu Oct 15 20:04:16 PDT 2026
the project "GEOS".
The branch, 3.15 has been updated
via c991b5dfb4e7b3a14d71c34849d9e257dbff5338 (commit)
from 86a4af483db99dc3f8914cd6a16cbfddd9961130 (commit)
revisions in full, below.
commit c991b5dfb4e7b3a14d71c34849d9e257dbff5338
Author: Mike Taves <mwtoews at gmail.com>
Date: Fri Oct 16 13:24:00 2026 +1300
Avoid raising `FE_INVALID` from Envelope (#1555)
diff --git a/NEWS.md b/NEWS.md
index e5a2885ef..579fe1ed3 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -5,6 +5,7 @@
- Fix arc noding failure with endpoint intersections (GH-1513, Dan Baston)
- Make GeometrySplitter able to split MultiSurface inputs (GH-1518, Dan Baston)
- GEOSGridIntersectionFractions: Set cells outside geometry bounding box to zero (GH-1532, Dan Baston)
+ - Avoid raising `FE_INVALID` from Envelope (GH-1555, Mike Taves)
## Changes in 3.15.0
2026-09-01
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 15d360030..dbbd1577f 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -609,6 +609,11 @@ public:
bool intersects(double x, double y) const
+#if defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15)
+ if(std::isnan(x) || std::isnan(maxx)) {
+ return false;
+#endif /* defined(__OPTIMIZE__) && defined(__clang__) ... */
return std::islessequal(x, maxx) &&
std::isgreaterequal(x, minx) &&
std::islessequal(y, maxy) &&
@@ -659,6 +664,11 @@ public:
* @return `true` if `(x, y)` lies in the interior or on the boundary of this Envelope.
bool covers(double x, double y) const {
+ if(std::isnan(x) || std::isnan(minx)) {
+ return false;
return std::isgreaterequal(x, minx) &&
std::isgreaterequal(y, miny) &&
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index 7c281aaee..55f6c0dfc 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -103,12 +103,8 @@ struct test_envelope_data {
//ensure("FE_INEXACT raised", !std::fetestexcept(FE_INEXACT));
//#endif
#ifdef FE_INVALID
- // Skip FE_INVALID check on FreeBSD and OpenBSD due to platform-specific behavior
- // See: https://github.com/libgeos/geos/issues/1206
-#if !defined(__FreeBSD__) && !defined(__OpenBSD__)
ensure("FE_INVALID raised", !std::fetestexcept(FE_INVALID));
#endif
-#endif
#ifdef FE_OVERFLOW
ensure("FE_OVERFLOW raised", !std::fetestexcept(FE_OVERFLOW));
#endif
@@ -269,7 +265,10 @@ void object::test<6>
check_intersects(small, {-1, -1}, true);
check_intersects(small, {5, 5}, false);
+#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && defined(__apple_build_version__) )
+// Exclude optimized Apple Clang on x86_64 osx - raises FE_INVALID
check_intersects(empty, {0, 0}, false);
+#endif
ensure_no_fp_except();
Summary of changes:
NEWS.md | 1 +
include/geos/geom/Envelope.h | 10 ++++++++++
tests/unit/geom/EnvelopeTest.cpp | 7 +++----
3 files changed, 14 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
