[geos-commits] [SCM] GEOS branch main updated. 9f80ea6d9293db0090469070caf58ab6f34e936d
git at osgeo.org
git at osgeo.org
Mon Oct 19 13:38:51 PDT 2026
the project "GEOS".
The branch, main has been updated
via 9f80ea6d9293db0090469070caf58ab6f34e936d (commit)
from 75c538dc1841a905f0cc771230ce67e405343fb9 (commit)
revisions in full, below.
commit 9f80ea6d9293db0090469070caf58ab6f34e936d
Author: Mike Taves <mwtoews at gmail.com>
Date: Tue Oct 20 09:37:32 2026 +1300
Revise GH-1555 to remove isnan guards and skip FE_INVALID test for optimized Clang 15 or later on x86_64
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index dbbd1577f..15d360030 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -609,11 +609,6 @@ public:
bool intersects(double x, double y) const
-#if defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15)
- if(std::isnan(x) || std::isnan(maxx)) {
- return false;
-#endif /* defined(__OPTIMIZE__) && defined(__clang__) ... */
return std::islessequal(x, maxx) &&
std::isgreaterequal(x, minx) &&
std::islessequal(y, maxy) &&
@@ -664,11 +659,6 @@ public:
* @return `true` if `(x, y)` lies in the interior or on the boundary of this Envelope.
bool covers(double x, double y) const {
- if(std::isnan(x) || std::isnan(minx)) {
- return false;
return std::isgreaterequal(x, minx) &&
std::isgreaterequal(y, miny) &&
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index 55f6c0dfc..a289438bd 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -265,8 +265,8 @@ void object::test<6>
check_intersects(small, {-1, -1}, true);
check_intersects(small, {5, 5}, false);
-#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && defined(__apple_build_version__) )
-// Exclude optimized Apple Clang on x86_64 osx - raises FE_INVALID
+#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15) )
+// Exclude optimized Clang 15 or later on x86_64 - raises FE_INVALID
check_intersects(empty, {0, 0}, false);
#endif
Summary of changes:
include/geos/geom/Envelope.h | 10 ----------
tests/unit/geom/EnvelopeTest.cpp | 4 ++--
2 files changed, 2 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
