[geos-commits] [SCM] GEOS branch 3.15 updated. 5b3950ef9058283c39e18b7927704054f1cafd7f
Mon Oct 19 14:14:43 PDT 2026
the project "GEOS".
The branch, 3.15 has been updated
       via  5b3950ef9058283c39e18b7927704054f1cafd7f (commit)
      from  5240ae533bd5c64206557e461add548d14add7f0 (commit)
revisions in full, below.
commit 5b3950ef9058283c39e18b7927704054f1cafd7f
Author: Mike Taves <mwtoews at gmail.com>
Date:   Tue Oct 20 09:37:32 2026 +1300
    Revise GH-1555 to remove isnan guards and skip FE_INVALID test for optimized Clang 15 or later on x86_64
diff --git a/NEWS.md b/NEWS.md
index d049da6fb..1ba0b572e 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -5,7 +5,7 @@
   - Fix arc noding failure with endpoint intersections (GH-1513, Dan Baston)
   - Make GeometrySplitter able to split MultiSurface inputs (GH-1518, Dan Baston)
   - GEOSGridIntersectionFractions: Set cells outside geometry bounding box to zero (GH-1532, Dan Baston)
-  - Avoid raising `FE_INVALID` from Envelope (GH-1555, Mike Taves)
+  - Skip testing FE_INVALID from unit-geom-Envelope for some Clang builds (GH-1555, Mike Taves)
   - Polygonize / LineMerge: Copy Z/M values at shared endpoints of mixed-dimension inputs (GH-1545, Dan Baston)
   - CircularArcIntersector: Use Orient2D to check for arc control points on line (GH-1546, Dan Baston)
   - CircularArcIntersector: Avoid incorrectly classifying intersections as cocircular (GH-1549, Dan Baston)
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index dbbd1577f..15d360030 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -609,11 +609,6 @@ public:
     bool intersects(double x, double y) const
-#if defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15)
-        if(std::isnan(x) || std::isnan(maxx)) {
-            return false;
-#endif  /* defined(__OPTIMIZE__) && defined(__clang__) ... */
         return std::islessequal(x, maxx) &&
                std::isgreaterequal(x, minx) &&
                std::islessequal(y, maxy) &&
@@ -664,11 +659,6 @@ public:
      * @return `true` if `(x, y)` lies in the interior or on the boundary of this Envelope.
     bool covers(double x, double y) const {
-        if(std::isnan(x) || std::isnan(minx)) {
-            return false;
         return std::isgreaterequal(x,  minx) &&
                std::isgreaterequal(y, miny) &&
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index 55f6c0dfc..a289438bd 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -265,8 +265,8 @@ void object::test<6>
     check_intersects(small, {-1, -1}, true);
     check_intersects(small, {5, 5}, false);
-#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && defined(__apple_build_version__) )
-//  Exclude optimized Apple Clang on x86_64 osx - raises FE_INVALID
+#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15) )
+//  Exclude optimized Clang 15 or later on x86_64 - raises FE_INVALID
     check_intersects(empty, {0, 0}, false);
 #endif
Summary of changes:
 NEWS.md                          |  2 +-
 include/geos/geom/Envelope.h     | 10 ----------
 tests/unit/geom/EnvelopeTest.cpp |  4 ++--
 3 files changed, 3 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
