[geos-commits] [SCM] GEOS branch main updated. a9752091be7ca35f0ffd94c37ef77530ff3dc194
git at osgeo.org
git at osgeo.org
Mon Oct 26 13:08:04 PDT 2026
the project "GEOS".
The branch, main has been updated
via a9752091be7ca35f0ffd94c37ef77530ff3dc194 (commit)
from 283e82726fbd5ecc45397f182e12e056a65b2dd7 (commit)
revisions in full, below.
commit a9752091be7ca35f0ffd94c37ef77530ff3dc194
Author: Jeroen Bloemscheer <jbloemscheer at gmail.com>
Date: Mon Oct 26 21:07:40 2026 +0100
Envelope: Return zero distance between touching envelopes (#1576)
distanceSquared computed each gap as a combined span minus two widths,
which cancels: envelopes touching along y = -48 came out 7e-15 apart, so
GEOSDistanceWithin(a, b, 0) was false for lines sharing an endpoint.
Compute each gap as a single difference between facing sides.
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 15d360030..654edbc2f 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -742,12 +742,8 @@ public:
double distanceSquared(const Envelope& env) const
- double dx = std::max(0.0,
- std::max(maxx, env.maxx) - std::min(minx, env.minx) - (maxx - minx) -
- (env.maxx - env.minx));
- double dy = std::max(0.0,
- std::max(maxy, env.maxy) - std::min(miny, env.miny) - (maxy - miny) -
- (env.maxy - env.miny));
+ double dx = std::max(0.0, std::max(minx - env.maxx, env.minx - maxx));
+ double dy = std::max(0.0, std::max(miny - env.maxy, env.miny - maxy));
return dx * dx + dy * dy;
diff --git a/tests/unit/capi/GEOSDistanceWithinTest.cpp b/tests/unit/capi/GEOSDistanceWithinTest.cpp
index 0b164d199..044598918 100644
--- a/tests/unit/capi/GEOSDistanceWithinTest.cpp
+++ b/tests/unit/capi/GEOSDistanceWithinTest.cpp
@@ -437,4 +437,18 @@ void object::test<33>()
+template<>
+template<>
+void object::test<34>() {
+ set_test_name("lines touching at endpoint");
+ testGEOSDistanceWithin(
+ "LINESTRING (0 -80, 64 -48)",
+ "LINESTRING (64 -48, 0 -0.1)",
+ 0.0,
+ 1
} // namespace tut
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index a289438bd..f4f95ff84 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -692,4 +692,18 @@ void object::test<21>()
ensure(env.containsProperly({3.0000001, 8}));
+template<>
+template<>
+void object::test<22>()
+ set_test_name("distance between touching envelopes is zero");
+ Envelope a(0, 64, -80, -48);
+ Envelope b(0, 64, -48, -0.1);
+ ensure_equals(a.distance(b), 0.0);
+ ensure_equals(b.distance(a), 0.0);
Summary of changes:
include/geos/geom/Envelope.h | 8 ++------
tests/unit/capi/GEOSDistanceWithinTest.cpp | 14 ++++++++++++++
tests/unit/geom/EnvelopeTest.cpp | 14 ++++++++++++++
3 files changed, 30 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
