[geos-commits] [SCM] GEOS branch main updated. a2525885ffe40a641bb1521c2cdb013f8a64ba34
Wed Oct 28 08:41:39 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  a2525885ffe40a641bb1521c2cdb013f8a64ba34 (commit)
      from  a9752091be7ca35f0ffd94c37ef77530ff3dc194 (commit)
revisions in full, below.
commit a2525885ffe40a641bb1521c2cdb013f8a64ba34
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Oct 28 11:39:25 2026 -0400
    WKBWriter: preserve includeSRID setting after failed write (#1578)
    Resolves https://github.com/libgeos/geos/issues/1567
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index 95c64b044..c71fd1031 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -186,9 +186,14 @@ WKBWriter::writeCompoundCurve(const CompoundCurve& g)
     auto orig_includeSRID = includeSRID;
     includeSRID = false;
-    for (std::size_t i = 0; i < g.getNumCurves(); i++) {
-        const SimpleCurve& section = *g.getCurveN(i);
-        writeSimpleCurve(section);
+    try {
+        for (std::size_t i = 0; i < g.getNumCurves(); i++) {
+            const SimpleCurve& section = *g.getCurveN(i);
+            writeSimpleCurve(section);
+    } catch (...) {
+        includeSRID = orig_includeSRID;
+        throw;
@@ -273,12 +278,19 @@ WKBWriter::writeGeometryCollection(const GeometryCollection& g)
     assert(outStream);
-    for(std::size_t i = 0; i < ngeoms; i++) {
-        const Geometry* elem = g.getGeometryN(i);
-        assert(elem);
-        write(*elem, *outStream);
+    try {
+        for(std::size_t i = 0; i < ngeoms; i++) {
+            const Geometry* elem = g.getGeometryN(i);
+            assert(elem);
+            write(*elem, *outStream);
+    } catch (...) {
+        throw;
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index 21387fe6c..71ef08ac3 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -3,6 +3,7 @@
 // tut
 #include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
 // geos
 #include <geos/io/WKBReader.h>
 #include <geos/io/WKBWriter.h>
@@ -478,6 +479,39 @@ void object::test<19>
                            "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");
+// includeSRID is kept when writing a collection or a compound curve fails
+// because the output stream throws
+template<>
+template<>
+void object::test<20>
+    // accepts 20 bytes, then fails
+    struct FixedBuf : std::streambuf {
+        char data[20]{};
+        FixedBuf() { setp(data, data + sizeof data); }
+    geos::io::WKBWriter writer(2, geos::io::ByteOrderValues::ENDIAN_LITTLE, true);
+    auto point = wktreader.read("POINT (1 2)");
+    point->setSRID(4326);
+    for (const char *wkt: {
+             "GEOMETRYCOLLECTION (POINT (1 2), LINESTRING (0 0, 1 1))",
+             "COMPOUNDCURVE (CIRCULARSTRING (0 0, 1 1, 2 0), (2 0, 3 0))"
+        auto geom = wktreader.read(wkt);
+        geom->setSRID(3857);
+        FixedBuf buf;
+        std::ostream os(&buf);
+        os.exceptions(std::ios::badbit | std::ios::failbit);
+        ensure_THROW(writer.write(*geom, os), std::ios_base::failure);
+        ensure("getIncludeSRID() should be set after writing " + std::string(wkt), writer.getIncludeSRID());
+        std::stringstream out;
+        writer.writeHEX(*point, out);
+        ensure_equals(wkt, out.str(), "0101000020E6100000000000000000F03F0000000000000040");
 } // namespace tut
Summary of changes:
 src/io/WKBWriter.cpp            | 26 +++++++++++++++++++-------
 tests/unit/io/WKBWriterTest.cpp | 34 ++++++++++++++++++++++++++++++++++
 2 files changed, 53 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
