[geos-commits] [SCM] GEOS branch main updated. 4d1795abc69d644d97c820639e3519065419407e
Wed Oct 28 16:44:50 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  4d1795abc69d644d97c820639e3519065419407e (commit)
      from  a2525885ffe40a641bb1521c2cdb013f8a64ba34 (commit)
revisions in full, below.
commit 4d1795abc69d644d97c820639e3519065419407e
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Oct 28 19:44:26 2026 -0400
    CircularArcs: fix containsAngle for non-normalized angles (#1579)
diff --git a/include/geos/algorithm/CircularArcs.h b/include/geos/algorithm/CircularArcs.h
index a563e8f12..4b6fab60a 100644
--- a/include/geos/algorithm/CircularArcs.h
+++ b/include/geos/algorithm/CircularArcs.h
@@ -98,10 +98,12 @@ public:
                             const geom::CoordinateXY& p0, const geom::CoordinateXY& p1,
                             geom::CoordinateXY& isect0, geom::CoordinateXY& isect1);
-    /** Returns whether an angle is included between two other angles.
+    /** Returns whether an angle is included between two other angles. The angles
+     *  do not need to be normalized. If the start and end angles are the same,
+     *  the input is assumed to represent a full circle.
      * @param t0 starting angle (radians)
-     * @param t2 ending engle (radians)
+     * @param t2 ending angle (radians)
      * @param isCCW whether the interval from t0 to t2 is counterclockwise
      * @param theta angle to test (radians)
      * @return true if theta is included between t0 and t2
diff --git a/src/algorithm/CircularArcs.cpp b/src/algorithm/CircularArcs.cpp
index 03fc02cda..f997f19f0 100644
--- a/src/algorithm/CircularArcs.cpp
+++ b/src/algorithm/CircularArcs.cpp
@@ -416,10 +416,6 @@ CircularArcs::circleIntersectsSegment(const CoordinateXY& center, double r,
 bool
 CircularArcs::containsAngle(double t0, double t2, bool isCCW, double theta)
-    if (theta == t0 || theta == t2) {
-        return true;
     if (isCCW) {
         std::swap(t0, t2);
@@ -427,15 +423,9 @@ CircularArcs::containsAngle(double t0, double t2, bool isCCW, double theta)
     t2 -= t0;
     theta -= t0;
-    if (t2 < 0) {
-        t2 += 2*MATH_PI;
-    if (theta < 0) {
-        theta += 2*MATH_PI;
-    return theta >= t2;
+    const auto norm = Angle::normalizePositive(theta);
+    return norm == 0 || norm >= Angle::normalizePositive(t2);
 bool
diff --git a/tests/unit/algorithm/CircularArcsTest.cpp b/tests/unit/algorithm/CircularArcsTest.cpp
index 07eda9cab..a19ccb50d 100644
--- a/tests/unit/algorithm/CircularArcsTest.cpp
+++ b/tests/unit/algorithm/CircularArcsTest.cpp
@@ -20,8 +20,41 @@ namespace tut {
 struct test_circulararcs_data {
     const double eps = 1e-8;
+    static constexpr int CCW_ = geos::algorithm::Orientation::COUNTERCLOCKWISE;
+    static constexpr int CW_ = geos::algorithm::Orientation::CLOCKWISE;
+    static constexpr int BOTH_ = 0;
+    static constexpr int NONE_ = -2;
     using XY = CoordinateXY;
+    static void checkAngleContained(double theta, double t0, double t2, int orientation)
+        std::string angleRange = std::to_string(t0) + " to " + std::to_string(t2);
+        if (orientation == CCW_) {
+            ensure(std::to_string(theta) + " should be contained in ccw angle from " + angleRange,
+                   CircularArcs::containsAngle(t0, t2, true, theta));
+            ensure(std::to_string(theta) + " should not be contained in cw angle from " + angleRange,
+                   !CircularArcs::containsAngle(t0, t2, false, theta));
+        else if (orientation == CW_) {
+            ensure(std::to_string(theta) + " should not be contained in ccw angle from " + angleRange,
+                   !CircularArcs::containsAngle(t0, t2, true, theta));
+            ensure(std::to_string(theta) + " should be contained in cw angle from " + angleRange,
+                   CircularArcs::containsAngle(t0, t2, false, theta));
+        } else if (orientation == BOTH_) {
+        } else {
     void checkEnvelope(const CoordinateXY& p0, const CoordinateXY& p1, const CoordinateXY& p2,
                        double xmin, double ymin, double xmax, double ymax) const
@@ -970,4 +1003,44 @@ set_test_name("getMidpointAngle");
     ensure_equals(CircularArcs::getMidpointAngle(0, 0, false), MATH_PI);
+template<>
+template<>
+void object::test<71>()
+    set_test_name("containsAngle");
+    using geos::algorithm::Orientation;
+    checkAngleContained(MATH_PI / 2, 0, MATH_PI, CCW_);
+    checkAngleContained(MATH_PI / 2, 2*MATH_PI, 3*MATH_PI, CCW_);
+    checkAngleContained(5*MATH_PI / 2, 2*MATH_PI, 3*MATH_PI, CCW_);
+    checkAngleContained(-MATH_PI / 2, 0, MATH_PI, CW_);
+    checkAngleContained(2.5 + MATH_PI, -2.5, 0, CCW_);
+    checkAngleContained(0, -MATH_PI / 2, MATH_PI / 2, CCW_);
+    checkAngleContained(2*MATH_PI, -MATH_PI / 2, MATH_PI / 2, CCW_);
+    checkAngleContained(4*MATH_PI, -MATH_PI / 2, MATH_PI / 2, CCW_);
+    checkAngleContained(-2*MATH_PI, -MATH_PI / 2, MATH_PI / 2, CCW_);
+    checkAngleContained(-4*MATH_PI, -MATH_PI / 2, MATH_PI / 2, CCW_);
+    checkAngleContained(MATH_PI, 3*MATH_PI/4, -3*MATH_PI/4, CCW_);
+    checkAngleContained(-MATH_PI, 3*MATH_PI/4, -3*MATH_PI/4, CCW_);
+    checkAngleContained(0, 3*MATH_PI/4, -3*MATH_PI/4, CW_);
+    checkAngleContained(MATH_PI/2, 3*MATH_PI/4, -3*MATH_PI/4, CW_);
+    // theta == t0
+    checkAngleContained(0, 0, 0, BOTH_);
+    checkAngleContained(0, 0, MATH_PI, BOTH_);
+    checkAngleContained(2*MATH_PI, 0, MATH_PI, BOTH_);
+    // t0 == t2, t0 == 0, full circle
+    checkAngleContained(MATH_PI, 0, 0, BOTH_);
+    checkAngleContained(MATH_PI, 0, 2*MATH_PI, BOTH_);
+    // t0 == t2, t0 != 0, full circle
+    checkAngleContained(MATH_PI, MATH_PI/4, MATH_PI/4, BOTH_);
+    checkAngleContained(MATH_PI, MATH_PI/4, 9*MATH_PI/4, BOTH_);
Summary of changes:
 include/geos/algorithm/CircularArcs.h     |  6 ++-
 src/algorithm/CircularArcs.cpp            | 14 +-----
 tests/unit/algorithm/CircularArcsTest.cpp | 73 +++++++++++++++++++++++++++++++
 3 files changed, 79 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
