[geos-commits] [SCM] GEOS branch main updated. 4b364c0312ab3b396377afc3bba0a7fd70cf2f51
Thu Oct 29 07:28:30 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  4b364c0312ab3b396377afc3bba0a7fd70cf2f51 (commit)
      from  4d1795abc69d644d97c820639e3519065419407e (commit)
revisions in full, below.
commit 4b364c0312ab3b396377afc3bba0a7fd70cf2f51
Author: Daniel Baston <dbaston at gmail.com>
Date:   Thu Oct 29 10:28:09 2026 -0400
    CircularArcs: Fix missing candidates in closestPointsArcSegment (#1577)
    Check for case where closest points are found on segment interior, arc
    endpoint, or segment/arc tangency missed by intersection test.
    Co-authored-by: Jeroen Bloemscheer <jbloemscheer at gmail.com>
diff --git a/src/algorithm/CircularArcs.cpp b/src/algorithm/CircularArcs.cpp
index f997f19f0..4c403f942 100644
--- a/src/algorithm/CircularArcs.cpp
+++ b/src/algorithm/CircularArcs.cpp
@@ -502,7 +502,7 @@ CircularArcs::closestPointsArcSegment(const CoordinateXY& c, double r,
     // Calculate distance between line and circle center
-    const CoordinateXY d = geom::LineSegment::closestPoint(q0, q1, c);
+    const CoordinateXY d = LineSegment::closestPoint(q0, q1, c);
     const double dist_cd = d.distance(c);
     if (dist_cd <= r) {
@@ -516,14 +516,18 @@ CircularArcs::closestPointsArcSegment(const CoordinateXY& c, double r,
             return {isect1, isect1};
-        // Closest point is one of the segment endpoints.
-        const auto e0 = closestPointArcPoint(c, r, p0, p2, isCCW, q0);
-        const auto e1 = closestPointArcPoint(c, r, p0, p2, isCCW, q1);
-        if (e0.distance(q0) < e1.distance(q1)) {
-            return {e0, q0};
+        // Closest point should be a segment or arc endpoint
+        std::array<std::array<CoordinateXY, 2>, 5> candidates;
+        candidates[0] = {closestPointArcPoint(c, r, p0, p2, isCCW, q0), q0};
+        candidates[1] = {closestPointArcPoint(c, r, p0, p2, isCCW, q1), q1};
+        candidates[2] = {p0, LineSegment::closestPoint(q0, q1, p0)};
+        candidates[3] = {p2, LineSegment::closestPoint(q0, q1, p2)};
+        // But we could have also missed a tangency point
+        candidates[4] = {closestPointArcPoint(c, r, p0, p2, isCCW, d), d};
-        return {e1, q1};
+        return *std::min_element(candidates.begin(), candidates.end(), [](const auto& a, const auto& b) {
+            return a[0].distance(a[1]) < b[0].distance(b[1]);
     // Find closest point on circle
@@ -541,10 +545,10 @@ CircularArcs::closestPointsArcSegment(const CoordinateXY& c, double r,
     const auto e1 = LineSegment::closestPoint(q0, q1, p2);
     if (e0.distance(p0) < e1.distance(p2)) {
-        return {e0, p0};
+        return {p0, e0};
-    return {e1, p2};
+    return {p2, e1};
 double
diff --git a/tests/unit/algorithm/CircularArcsTest.cpp b/tests/unit/algorithm/CircularArcsTest.cpp
index a19ccb50d..b1de7b939 100644
--- a/tests/unit/algorithm/CircularArcsTest.cpp
+++ b/tests/unit/algorithm/CircularArcsTest.cpp
@@ -1,6 +1,7 @@
 #include <tut/tut.hpp>
 #include <geos/geom/Coordinate.h>
+#include <geos/geom/CircularString.h>
 #include <geos/algorithm/CircularArcs.h>
 #include <geos/geom/CircularArc.h>
 #include <geos/geom/Quadrant.h>
@@ -1006,8 +1007,7 @@ set_test_name("getMidpointAngle");
 template<>
 template<>
-void object::test<71>()
+void object::test<71>() {
     set_test_name("containsAngle");
     using geos::algorithm::Orientation;
@@ -1043,4 +1043,90 @@ void object::test<71>()
     checkAngleContained(MATH_PI, MATH_PI/4, 9*MATH_PI/4, BOTH_);
+template<>
+template<>
+void object::test<72>()
+    set_test_name("arc-seg distance, segment inside circle, closest to arc endpoint");
+    // The segment lies inside the circle and does not reach the arc, so the
+    // closest pair joins the arc endpoint at 70 degrees to the segment interior.
+    const double r = 10;
+    CircularArc arc = CircularArc::create(XY{r*std::cos(MATH_PI/3), r*std::sin(MATH_PI/3)},
+                                          XY{r*std::cos(13*MATH_PI/36), r*std::sin(13*MATH_PI/36)},
+                                          XY{r*std::cos(7*MATH_PI/18), r*std::sin(7*MATH_PI/18)});
+    XY q0{2, 0};
+    XY q1{2, 9.5};
+    ensure_equals("distance", arc.distance(q0, q1), arc.p2().x - 2, 1e-12);
+template<>
+template<>
+void object::test<73>()
+    set_test_name("arc-seg distance, segment outside circle, closest to segment endpoint");
+    // The closest pair joins a segment endpoint to the arc interior.
+    CircularArc arc = CircularArc::create(XY{-3.48172, 2.91175}, XY{9.45735, -6.02278}, XY{1.44247, -0.448891});
+    XY q0{4.48559, 4.09741};
+    XY q1{-5.45188, -9.20177};
+    ensure_equals("distance", arc.distance(q0, q1), 0.2835665009749685, 1e-9);
+    const auto pts = CircularArcs::closestPointsArcSegment(arc.getCenter(), arc.getRadius(),
+                     arc.p0(), arc.p2(), arc.isCCW(), q0, q1);
+    ensure("first point is on the arc", std::abs(pts[0].distance(arc.getCenter()) - arc.getRadius()) < 1e-9);
+    ensure_equals("closest points distance", pts[0].distance(pts[1]), 0.2835665009749685, 1e-9);
+template<>
+template<>
+void object::test<74>()
+    set_test_name("arc-seg distance, segment tangent to arc");
+    // The segment is tangent to the circle at (4, 3), which lies on the arc,
+    // but roundoff hides the intersection from circleIntersectsSegment.
+    CircularArc arc = CircularArc::create(XY{0, -5}, XY{4, -3}, XY{0, 5});
+    XY q0{7, -1};
+    XY q1{1, 7};
+    ensure_equals("distance", arc.distance(q0, q1), 0, 1e-12);
+    ensure_equals("distance (reversed segment)", arc.distance(q1, q0), 0, 1e-12);
+template<>
+template<>
+void object::test<75>()
+    set_test_name("arc-seg distance, segment nearly tangent to arc");
+    // Found by differential testing against NetTopologySuite.Proofs ARC_SEGMENT_DISTANCE.
+    CircularArc arc = CircularArc::create(XY{-81.85405104117687, -125.94712311622965},
+                                          XY{118.46299847713223, -81.33910481556457},
+                                          XY{73.85498017646715, 118.97794470274454});
+    XY q0{176.08930671152348, -164.72607692939968};
+    XY q1{97.98804198508518, 227.31432409657776};
+    ensure_equals("distance", arc.distance(q0, q1), 0, 1e-9);
+    ensure_equals("distance (reversed segment)", arc.distance(q1, q0), 0, 1e-9);
+template<>
+template<>
+void object::test<76>()
+    set_test_name("arc-seg closest points, segment outside circle, closest to arc endpoint");
+    // Closest pair joins the arc endpoint (5, 0) to the segment endpoint (10, -1).
+    CircularArc arc = CircularArc::create(XY{5, 0}, XY{3, 4}, XY{0, 5});
+    XY q0{10, -10};
+    XY q1{10, -1};
+    const auto pts = arc.closestPoints(q0, q1);
+    ensure_equals("first point is on the arc", pts[0], XY{5, 0});
+    ensure_equals("second point is on the segment", pts[1], XY{10, -1});
Summary of changes:
 src/algorithm/CircularArcs.cpp            | 24 +++++----
 tests/unit/algorithm/CircularArcsTest.cpp | 90 ++++++++++++++++++++++++++++++-
 2 files changed, 102 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
