[geos-commits] [SCM] GEOS branch main updated. 2289bad7aac673a1bffcbbdd96944fcc57405a9c
git at osgeo.org
git at osgeo.org
Fri Oct 30 07:21:53 PDT 2026
the project "GEOS".
The branch, main has been updated
via 2289bad7aac673a1bffcbbdd96944fcc57405a9c (commit)
via 1ff45c6ba7c956c8f38fb5a139db626bb7d4c8dc (commit)
from 4b364c0312ab3b396377afc3bba0a7fd70cf2f51 (commit)
revisions in full, below.
commit 2289bad7aac673a1bffcbbdd96944fcc57405a9c
Author: Alejandro Pacheco <ale at alepacheco.dev>
Date: Thu Oct 29 07:16:51 2026 +0100
Check element types of MultiPoint, MultiLineString and MultiPolygon
The constructors taking a vector of Geometry now throw
IllegalArgumentException for an element of another type, as the
MultiCurve and MultiSurface constructors already do. This also covers
GEOSGeom_createCollection.
buildGeometry(from, toofar) chose its result type by sort index and
dimension, so it put several CircularStrings or CompoundCurves into a
MultiLineString and several collections of one type into a Multi*
geometry. It now calls buildGeometry(const std::vector<const Geometry*>&),
whose semantics its documentation already refers to. As a result,
GEOSUnaryUnion of CircularStrings alone no longer fails with "Noder does
not support curved paths".
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 73fcb5995..22d663468 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -434,54 +434,7 @@ public:
std::unique_ptr<Geometry>
buildGeometry(T from, T toofar) const
- bool isHeterogeneous = false;
- std::size_t count = 0;
- int geomClass = -1;
- for(T i = from; i != toofar; ++i) {
- ++count;
- const Geometry* g = *i;
- if(geomClass < 0) {
- geomClass = g->getSortIndex();
- else if(geomClass != g->getSortIndex()) {
- isHeterogeneous = true;
- // for the empty geometry, return an empty GeometryCollection
- if(count == 0) {
- return std::unique_ptr<Geometry>(createGeometryCollection());
- // for the single geometry, return a clone
- if(count == 1) {
- return (*from)->clone();
- // Now we know it is a collection
- // FIXME:
- // Until we tweak all the createMulti* interfaces
- // to support taking iterators we'll have to build
- // a custom vector here.
- std::vector<std::unique_ptr<Geometry>> fromGeoms;
- fromGeoms.push_back((*i)->clone());
- // for an heterogeneous ...
- if(isHeterogeneous) {
- return createGeometryCollection(std::move(fromGeoms));
- // At this point we know the collection is not hetereogenous.
- switch((*from)->getDimension()) {
- case Dimension::A: return createMultiPolygon(std::move(fromGeoms));
- case Dimension::L: return createMultiLineString(std::move(fromGeoms));
- case Dimension::P: return createMultiPoint(std::move(fromGeoms));
- default:
- throw geos::util::IllegalArgumentException(std::string("Invalid geometry type."));
+ return buildGeometry(std::vector<const Geometry*>(from, toofar));
/** \brief
diff --git a/src/geom/MultiLineString.cpp b/src/geom/MultiLineString.cpp
index c58615076..f4116f0b2 100644
--- a/src/geom/MultiLineString.cpp
+++ b/src/geom/MultiLineString.cpp
@@ -45,7 +45,14 @@ MultiLineString::MultiLineString(std::vector<std::unique_ptr<LineString>> && new
MultiLineString::MultiLineString(std::vector<std::unique_ptr<Geometry>> && newLines,
const GeometryFactory& factory)
: GeometryCollection(std::move(newLines), factory)
+ for (const auto& geom : geometries) {
+ const auto typeId = geom->getGeometryTypeId();
+ if (typeId != GEOS_LINESTRING && typeId != GEOS_LINEARRING) {
+ throw util::IllegalArgumentException("All elements of MultiLineString must be a LineString");
MultiLineString::MultiLineString(std::vector<std::unique_ptr<Curve>> && newLines,
diff --git a/src/geom/MultiPoint.cpp b/src/geom/MultiPoint.cpp
index aa615bf1a..8513e1bf1 100644
--- a/src/geom/MultiPoint.cpp
+++ b/src/geom/MultiPoint.cpp
@@ -22,6 +22,7 @@
#include <geos/geom/MultiPoint.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Dimension.h>
+#include <geos/util/IllegalArgumentException.h>
#include <vector>
@@ -40,7 +41,11 @@ MultiPoint::MultiPoint(std::vector<std::unique_ptr<Geometry>> && newPoints, cons
GeometryCollection(std::move(newPoints), factory)
+ if (geom->getGeometryTypeId() != GEOS_POINT) {
+ throw util::IllegalArgumentException("All elements of MultiPoint must be a Point");
Dimension::DimensionType
diff --git a/src/geom/MultiPolygon.cpp b/src/geom/MultiPolygon.cpp
index ae5c253fc..8f7c82b68 100644
--- a/src/geom/MultiPolygon.cpp
+++ b/src/geom/MultiPolygon.cpp
@@ -25,6 +25,7 @@
#include <geos/geom/MultiSurface.h>
#include <cassert>
#include <string>
@@ -42,7 +43,13 @@ MultiPolygon::MultiPolygon(std::vector<std::unique_ptr<Polygon>> && newPolys, co
MultiPolygon::MultiPolygon(std::vector<std::unique_ptr<Geometry>> && newPolys, const GeometryFactory& factory)
: GeometryCollection(std::move(newPolys), factory)
+ if (geom->getGeometryTypeId() != GEOS_POLYGON) {
+ throw util::IllegalArgumentException("All elements of MultiPolygon must be a Polygon");
MultiPolygon::~MultiPolygon() {}
diff --git a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
index c52bce50a..56f40ef39 100644
--- a/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
@@ -202,5 +202,46 @@ void object::test<9>
-} // namespace tut
+// Error on an element of another type, ownership is still transferred
+template<>
+template<>
+void object::test<10>
+ GEOSGeometry* points[2];
+ points[0] = fromWKT("POINT (0 0)");
+ points[1] = fromWKT("LINESTRING (0 0, 1 1)");
+ geom1_ = GEOSGeom_createCollection(GEOS_MULTIPOINT, points, 2);
+ ensure(geom1_ == nullptr);
+ GEOSGeometry* lines[2];
+ lines[0] = fromWKT("LINESTRING (0 0, 1 1)");
+ lines[1] = fromWKT("MULTILINESTRING ((2 2, 3 3))");
+ geom1_ = GEOSGeom_createCollection(GEOS_MULTILINESTRING, lines, 2);
+ GEOSGeometry* polygons[2];
+ polygons[0] = fromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+ polygons[1] = fromWKT("POINT (5 5)");
+ geom1_ = GEOSGeom_createCollection(GEOS_MULTIPOLYGON, polygons, 2);
+// A LinearRing is accepted as an element of a MultiLineString
+template<>
+template<>
+void object::test<11>
+ lines[0] = fromWKT("LINEARRING (0 0, 1 0, 1 1, 0 0)");
+ lines[1] = fromWKT("LINESTRING (2 2, 3 3)");
+ ensure(geom1_ != nullptr);
+ ensure_equals(GEOSGeomTypeId(geom1_), GEOS_MULTILINESTRING);
+ ensure_equals(GEOSGetNumGeometries(geom1_), 2);
+ ensure_equals(GEOSGeomTypeId(GEOSGetGeometryN(geom1_, 0)), GEOS_LINEARRING);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSUnaryUnionTest.cpp b/tests/unit/capi/GEOSUnaryUnionTest.cpp
index af484b8ef..802078ba9 100644
--- a/tests/unit/capi/GEOSUnaryUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionTest.cpp
@@ -333,6 +333,21 @@ void object::test<17>()
ensure_geometry_equals(result_, input_, 1e-8);
+template<>
+template<>
+void object::test<18>()
+ set_test_name("CircularString-only dim=1 inputs");
+ input_ = fromWKT("MULTICURVE (CIRCULARSTRING (0 0, 1 1, 2 0), CIRCULARSTRING (2 0, 3 -1, 4 0))");
+ result_ = GEOSUnaryUnion(input_);
+ ensure(result_);
+ expected_ = fromWKT("CIRCULARSTRING (0 0, 1 1, 2 0, 3 -1, 4 0)");
+ ensure_geometry_equals(result_, expected_, 1e-8);
} // namespace tut
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index 30a27a924..3d950d03c 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -3,6 +3,7 @@
// tut
#include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
#include <utility.h>
// geos
@@ -1622,4 +1623,87 @@ void object::test<44>()
+template<>
+template<>
+void object::test<45>()
+ set_test_name("createMultiPoint, createMultiLineString, createMultiPolygon reject elements of another type");
+ using geos::geom::Geometry;
+ using geos::util::IllegalArgumentException;
+ auto elements = [this](const std::string& wkt1, const std::string& wkt2) {
+ std::vector<std::unique_ptr<Geometry>> geoms;
+ geoms.push_back(reader_.read(wkt1));
+ geoms.push_back(reader_.read(wkt2));
+ return geoms;
+ ensure_THROW(factory_->createMultiPoint(elements("POINT (0 0)", "MULTIPOINT ((1 1))")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiPoint(elements("POINT (0 0)", "LINESTRING (0 0, 1 1)")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiLineString(elements("LINESTRING (0 0, 1 1)", "MULTILINESTRING ((2 2, 3 3))")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiLineString(elements("LINESTRING (0 0, 1 1)", "CIRCULARSTRING (0 0, 1 1, 2 0)")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiLineString(elements("LINESTRING (0 0, 1 1)", "POINT (0 0)")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiPolygon(elements("POLYGON ((0 0, 1 0, 1 1, 0 0))", "MULTIPOLYGON (((2 2, 3 2, 3 3, 2 2)))")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiPolygon(elements("POLYGON ((0 0, 1 0, 1 1, 0 0))", "CURVEPOLYGON ((2 2, 3 2, 3 3, 2 2))")), IllegalArgumentException);
+ ensure_THROW(factory_->createMultiPolygon(elements("POLYGON ((0 0, 1 0, 1 1, 0 0))", "LINESTRING (0 0, 1 1)")), IllegalArgumentException);
+ // createMultiPolygon(const std::vector<const Geometry*>&) clones into the checked constructor
+ auto poly = reader_.read("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+ auto mpoly = reader_.read("MULTIPOLYGON (((2 2, 3 2, 3 3, 2 2)))");
+ std::vector<const Geometry*> borrowed{ poly.get(), mpoly.get() };
+ ensure_THROW(factory_->createMultiPolygon(borrowed), IllegalArgumentException);
+ // A LinearRing is a LineString
+ auto mls = factory_->createMultiLineString(elements("LINESTRING (0 0, 1 1)", "LINEARRING (2 2, 3 2, 3 3, 2 2)"));
+ ensure_equals(mls->getNumGeometries(), 2u);
+template<>
+template<>
+void object::test<46>()
+ set_test_name("buildGeometry(from, toofar) and buildGeometry(const std::vector<const Geometry*>&) give the same type");
+ using geos::geom::GeometryTypeId;
+ struct Case {
+ std::string wkt1;
+ std::string wkt2;
+ GeometryTypeId type;
+ const std::vector<Case> cases = {
+ { "POINT (1 1)", "POINT (2 2)", geos::geom::GEOS_MULTIPOINT },
+ { "LINESTRING (0 0, 1 1)", "LINESTRING (2 2, 3 3)", geos::geom::GEOS_MULTILINESTRING },
+ { "LINESTRING (0 0, 1 1)", "LINEARRING (2 2, 3 2, 3 3, 2 2)", geos::geom::GEOS_MULTILINESTRING },
+ { "POLYGON ((0 0, 1 0, 1 1, 0 0))", "POLYGON ((2 2, 3 2, 3 3, 2 2))", geos::geom::GEOS_MULTIPOLYGON },
+ { "CIRCULARSTRING (0 0, 1 1, 2 0)", "CIRCULARSTRING (2 0, 3 1, 4 0)", geos::geom::GEOS_MULTICURVE },
+ { "COMPOUNDCURVE ((0 0, 1 1))", "COMPOUNDCURVE ((2 2, 3 3))", geos::geom::GEOS_MULTICURVE },
+ { "LINESTRING (0 0, 1 1)", "CIRCULARSTRING (2 0, 3 1, 4 0)", geos::geom::GEOS_MULTICURVE },
+ { "CURVEPOLYGON ((0 0, 1 0, 1 1, 0 0))", "CURVEPOLYGON ((2 2, 3 2, 3 3, 2 2))", geos::geom::GEOS_MULTISURFACE },
+ { "POLYGON ((0 0, 1 0, 1 1, 0 0))", "CURVEPOLYGON ((2 2, 3 2, 3 3, 2 2))", geos::geom::GEOS_MULTISURFACE },
+ { "MULTIPOINT ((0 0))", "MULTIPOINT ((2 2), (3 3))", geos::geom::GEOS_GEOMETRYCOLLECTION },
+ { "MULTIPOLYGON (((0 0, 1 0, 1 1, 0 0)))", "MULTIPOLYGON (((2 2, 3 2, 3 3, 2 2)))", geos::geom::GEOS_GEOMETRYCOLLECTION },
+ { "POINT (1 1)", "LINESTRING (2 2, 3 3)", geos::geom::GEOS_GEOMETRYCOLLECTION },
+ for (const auto& c : cases) {
+ auto g1 = reader_.read(c.wkt1);
+ auto g2 = reader_.read(c.wkt2);
+ std::vector<const Geometry*> geoms{ g1.get(), g2.get() };
+ auto fromVector = factory_->buildGeometry(geoms);
+ ensure_equals(c.wkt2, fromVector->getGeometryTypeId(), c.type);
+ ensure_equals(c.wkt2, fromVector->getNumGeometries(), 2u);
+ auto fromIterators = factory_->buildGeometry(geoms.begin(), geoms.end());
+ ensure_equals(c.wkt2, fromIterators->getGeometryTypeId(), c.type);
+ ensure_equals(c.wkt2, fromIterators->getNumGeometries(), 2u);
} // namespace tut
commit 1ff45c6ba7c956c8f38fb5a139db626bb7d4c8dc
GeometryFactory::buildGeometry: return GeometryCollection when an element is a collection
Since 4e50c4d3c, commonType compares the dimension of the elements
rather than their type, so a collection among elements of one
dimension gave a MultiPoint, MultiLineString or MultiPolygon holding
that collection. Return a GeometryCollection for these, as the
documentation of buildGeometry says and as 3.14 did.
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 1454dc86a..541b90649 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -903,7 +903,9 @@ GeometryTypeId commonType(const T& geoms) {
for (std::size_t i = 1; i < geoms.size(); i++) {
curvedType |= geoms[i]->hasCurvedTypes();
- if (geoms[i]->getDimension() != dim) {
+ // A collection can only be an element of a GeometryCollection,
+ // even when its dimension matches the other elements.
+ if (geoms[i]->isCollection() || geoms[i]->getDimension() != dim) {
return GEOS_GEOMETRYCOLLECTION;
diff --git a/tests/unit/capi/GEOSDensifyTest.cpp b/tests/unit/capi/GEOSDensifyTest.cpp
index 43e87d569..2f1145132 100644
--- a/tests/unit/capi/GEOSDensifyTest.cpp
+++ b/tests/unit/capi/GEOSDensifyTest.cpp
@@ -227,4 +227,20 @@ void object::test<14>()
+template<>
+template<>
+void object::test<15>()
+ set_test_name("MultiPolygon with rings collapsed to lines gives a GeometryCollection");
+ input_ = fromWKT("MULTIPOLYGON (((0 0, 1 1, 0 0)), ((10 10, 11 11, 10 10), (0 0, 30 0, 30 30, 0 30, 0 0)))");
+ result_ = GEOSDensify(input_, 100);
+ ensure(result_);
+ // Not a MultiLineString with a MultiLineString element
+ ensure_equals(GEOSGeomTypeId(result_), GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(toWKT(result_), "GEOMETRYCOLLECTION (LINESTRING (0 0, 1 1, 0 0), MULTILINESTRING ((10 10, 11 11, 10 10), (0 0, 30 0, 30 30, 0 30, 0 0)))");
} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 2c70f84d3..4f1f1609c 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -339,5 +339,20 @@ void object::test<24>()
ensure_geometry_equals_identical(result_, input_);
-} // namespace tut
+template<>
+template<>
+void object::test<25>()
+ result_ = GEOSGeom_setPrecision(input_, 1.0, GEOS_PREC_NO_TOPO);
+ ensure(result_);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSSnapTest.cpp b/tests/unit/capi/GEOSSnapTest.cpp
index 7fedee2e6..f56f0d5d6 100644
--- a/tests/unit/capi/GEOSSnapTest.cpp
+++ b/tests/unit/capi/GEOSSnapTest.cpp
@@ -220,5 +220,20 @@ void object::test<11>()
ensure("curved geometry not supported", result_ == nullptr);
-} // namespace tut
+template<>
+template<>
+void object::test<12>()
+ result_ = GEOSSnap(input_, input_, 0);
+ ensure(result_);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp b/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
index a6ada22d1..11517b2e9 100644
--- a/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
+++ b/tests/unit/capi/GEOSTopologyPreserveSimplifyTest.cpp
@@ -74,5 +74,20 @@ void object::test<4>()
ensure_geometry_equals_identical(result_, expected_);
-} // namespace tut
+template<>
+template<>
+void object::test<5>()
+ result_ = GEOSTopologyPreserveSimplify(input_, 0);
+ ensure(result_);
+} // namespace tut
index 3b10c2015..30a27a924 100644
@@ -22,6 +22,8 @@
#include <geos/util.h>
// std
+#include <string>
+#include <utility>
#include <vector>
#include <cstring> // std::size_t
@@ -1575,5 +1577,49 @@ void object::test<43>()
ensure_equals(g->getNumGeometries(), 2u);
+template<>
+template<>
+void object::test<44>()
+ set_test_name("buildGeometry returns a GeometryCollection when an element is a collection");
+ const std::vector<std::pair<std::string, std::string>> cases = {
+ { "POINT (1 1)", "MULTIPOINT ((2 2), (3 3))" },
+ { "LINESTRING (0 0, 1 1)", "MULTILINESTRING ((2 2, 3 3), (4 4, 5 5))" },
+ { "POLYGON ((0 0, 1 0, 1 1, 0 0))", "MULTIPOLYGON (((2 2, 3 2, 3 3, 2 2)))" },
+ { "LINESTRING (0 0, 1 1)", "GEOMETRYCOLLECTION (LINESTRING (2 2, 3 3))" },
+ { "CIRCULARSTRING (0 0, 1 1, 2 0)", "MULTICURVE ((2 2, 3 3))" },
+ { "POLYGON ((0 0, 1 0, 1 1, 0 0))", "MULTISURFACE (((2 2, 3 2, 3 3, 2 2)))" },
+ auto single = reader_.read(c.first);
+ auto multi = reader_.read(c.second);
+ for (bool multiFirst : { false, true }) {
+ const Geometry* a = multiFirst ? multi.get() : single.get();
+ const Geometry* b = multiFirst ? single.get() : multi.get();
+ std::vector<std::unique_ptr<Geometry>> owned;
+ owned.push_back(a->clone());
+ owned.push_back(b->clone());
+ auto fromOwned = factory_->buildGeometry(std::move(owned));
+ ensure_equals(c.second, fromOwned->getGeometryTypeId(), geos::geom::GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(c.second, fromOwned->getNumGeometries(), 2u);
+ std::vector<const Geometry*> borrowed{ a, b };
+ auto fromBorrowed = factory_->buildGeometry(borrowed);
+ ensure_equals(c.second, fromBorrowed->getGeometryTypeId(), geos::geom::GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(c.second, fromBorrowed->getNumGeometries(), 2u);
+ auto fromIterators = factory_->buildGeometry(borrowed.begin(), borrowed.end());
+ ensure_equals(c.second, fromIterators->getGeometryTypeId(), geos::geom::GEOS_GEOMETRYCOLLECTION);
+ ensure_equals(c.second, fromIterators->getNumGeometries(), 2u);
} // namespace tut
Summary of changes:
include/geos/geom/GeometryFactory.h | 49 +-------
src/geom/GeometryFactory.cpp | 4 +-
src/geom/MultiLineString.cpp | 9 +-
src/geom/MultiPoint.cpp | 7 +-
src/geom/MultiPolygon.cpp | 9 +-
tests/unit/capi/GEOSDensifyTest.cpp | 16 +++
tests/unit/capi/GEOSGeom_createCollectionTest.cpp | 43 ++++++-
tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 17 ++-
tests/unit/capi/GEOSSnapTest.cpp | 17 ++-
.../unit/capi/GEOSTopologyPreserveSimplifyTest.cpp | 17 ++-
tests/unit/capi/GEOSUnaryUnionTest.cpp | 15 +++
tests/unit/geom/GeometryFactoryTest.cpp | 132 ++++++++++++++++++++-
12 files changed, 278 insertions(+), 57 deletions(-)
hooks/post-receive
More information about the geos-commits
