[geos-commits] [SCM] GEOS branch main updated. 979185683c608440f7dc36cec1474a5c2ab90b8a
Thu Sep 10 07:46:44 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  979185683c608440f7dc36cec1474a5c2ab90b8a (commit)
       via  52c59386decedfb44594de1d9f9d78e730743a26 (commit)
      from  55809ca8d7e904c363d715791e956875b019221b (commit)
revisions in full, below.
commit 979185683c608440f7dc36cec1474a5c2ab90b8a
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Sep 8 16:09:15 2026 -0400
    GeometrySplitter: Add tests for MultiSurface-LineString split
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index 4e91f7230..8209abca4 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -925,4 +925,15 @@ void object::test<76>()
     ensure_THROW(GeometrySplitter::split(*poly, *line), geos::util::GEOSException);
+template<>
+template<>
+void object::test<77>()
+    set_test_name("split MultiSurface with LineString");
+    testSplit("MULTISURFACE(CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 0 5, 5 5), CIRCULARSTRING(5 5, 7 1, 5 0))))",
+        "LINESTRING(3 6, 3 -1)",
+        "GEOMETRYCOLLECTION (CURVEPOLYGON (COMPOUNDCURVE ((5 0, 3 0, 3 5, 5 5), CIRCULARSTRING (5 5, 7 1, 5 0))), POLYGON ((3 0, 0 0, 0 5, 3 5, 3 0)))");
commit 52c59386decedfb44594de1d9f9d78e730743a26
Date:   Fri Oct 31 09:21:27 2025 -0400
    Geometry::intersects: handle MultiSurface PIP
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index be77ff9d6..11fe95d7d 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -87,6 +87,10 @@ public:
     static bool isContained(const geom::CoordinateXY& p,
                             const geom::Geometry* geom);
+    static bool isAnyPointContained(const geom::Geometry& pt, const geom::Geometry& areaGeom);
+    static bool isEveryPointContained(const geom::Geometry& pt, const geom::Geometry& areaGeom);
     SimplePointInAreaLocator(const geom::Geometry* p_g)
         : g(p_g)
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index 0a7b8e343..a045f2eff 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -18,10 +18,8 @@
 #include <geos/algorithm/locate/SimplePointInAreaLocator.h>
 #include <geos/geom/Geometry.h>
 #include <geos/geom/Polygon.h>
-#include <geos/geom/GeometryCollection.h>
 #include <geos/geom/Location.h>
-#include <geos/geom/CoordinateSequence.h>
-#include <geos/geom/LineString.h>
+#include <geos/util/Assert.h>
 using namespace geos::geom;
@@ -46,6 +44,42 @@ SimplePointInAreaLocator::isContained(const CoordinateXY& p, const Geometry* geo
     return Location::EXTERIOR != locate(p, geom);
+bool
+SimplePointInAreaLocator::isAnyPointContained(const geom::Geometry& pt, const geom::Geometry& area)
+    util::Assert::isTrue(area.getDimension() == Dimension::A);
+    util::Assert::isTrue(pt.getDimension() == Dimension::P);
+    if (pt.getNumGeometries() > 1) {
+        for (size_t i = 0; i < pt.getNumGeometries(); i++ ) {
+            if (isAnyPointContained(*pt.getGeometryN(i), area)) {
+                return true;
+        return false;
+    return isContained(*pt.getCoordinate(), &area);
+bool
+SimplePointInAreaLocator::isEveryPointContained(const geom::Geometry &pt, const geom::Geometry &area)
+            if (!isEveryPointContained(*pt.getGeometryN(i), area)) {
+                return false;
+        return true;
 geom::Location
 SimplePointInAreaLocator::locateInGeometry(const CoordinateXY& p, const Geometry* geom)
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 72ea87ae9..26c68ae62 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -261,6 +261,10 @@ Geometry::getEnvelope() const
 bool
 Geometry::disjoint(const Geometry* g) const
+    if (hasCurvedComponents() || g->hasCurvedComponents()) {
+        return !intersects(g);
 #if USE_RELATENG
     return operation::relateng::RelateNG::disjoint(this, g);
 #else
@@ -323,13 +327,13 @@ Geometry::intersects(const Geometry* g) const
         return predicate::RectangleIntersects::intersects(*p, *this);
-    auto typ = getGeometryTypeId();
-    if (typ == GEOS_CURVEPOLYGON && g->getGeometryTypeId() == GEOS_POINT) {
-        auto loc = locate::SimplePointInAreaLocator::locatePointInSurface(*g->getCoordinate(), *detail::down_cast<const Surface*>(this));
-        return loc != Location::EXTERIOR;
-    } else if (typ == GEOS_POINT && g->getGeometryTypeId() == GEOS_CURVEPOLYGON) {
-        auto loc = locate::SimplePointInAreaLocator::locatePointInSurface(*getCoordinate(), *detail::down_cast<const Surface*>(g));
+        if (isDimensionStrict(Dimension::A) && g->getDimension() == Dimension::P) {
+            return locate::SimplePointInAreaLocator::isAnyPointContained(*g, *this);
+        if (g->isDimensionStrict(Dimension::A) && getDimension() == Dimension::P) {
+            return locate::SimplePointInAreaLocator::isAnyPointContained(*this, *g);
 #if USE_RELATENG
diff --git a/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp b/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp
index 798df3ca6..399e9b332 100644
--- a/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp
+++ b/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp
@@ -1,4 +1,5 @@
 #include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
@@ -6,6 +7,7 @@
 using geos::geom::CoordinateXY;
 using geos::geom::Location;
+using geos::algorithm::locate::SimplePointInAreaLocator;
 namespace tut {
@@ -39,4 +41,40 @@ void object::test<1>()
     checkLocation(*g, {2.5, 1.5}, Location::EXTERIOR); // inside hole
+template<>
+template<>
+void object::test<2>()
+    auto point = reader.read("POINT (1 1)");
+    auto point2 = reader.read("POINT (100 100)");
+    auto multiPoint = reader.read("MULTIPOINT (1 1, 11 11)");
+    auto multiPoint2 = reader.read("MULTIPOINT (100 100, 200 200)");
+    auto poly = reader.read("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))");
+    auto multiPoly = reader.read("MULTIPOLYGON (((0 0, 10 0, 10 10, 0 10, 0 0)), ((10 10, 20 10, 20 20, 10 20, 10 10)))");
+    // isAnyPointContained
+    ensure(SimplePointInAreaLocator::isAnyPointContained(*point, *poly));
+    ensure(SimplePointInAreaLocator::isAnyPointContained(*point, *multiPoly));
+    ensure(SimplePointInAreaLocator::isAnyPointContained(*multiPoint, *poly));
+    ensure(SimplePointInAreaLocator::isAnyPointContained(*multiPoint, *multiPoly));
+    ensure(!SimplePointInAreaLocator::isAnyPointContained(*point2, *poly));
+    ensure(!SimplePointInAreaLocator::isAnyPointContained(*point2, *multiPoly));
+    ensure(!SimplePointInAreaLocator::isAnyPointContained(*multiPoint2, *poly));
+    ensure(!SimplePointInAreaLocator::isAnyPointContained(*multiPoint2, *multiPoly));
+    // isEveryPointContained
+    ensure(SimplePointInAreaLocator::isEveryPointContained(*point, *poly));
+    ensure(SimplePointInAreaLocator::isEveryPointContained(*point, *multiPoly));
+    ensure(!SimplePointInAreaLocator::isEveryPointContained(*multiPoint, *poly));
+    ensure(SimplePointInAreaLocator::isEveryPointContained(*multiPoint, *multiPoly));
+    ensure(!SimplePointInAreaLocator::isEveryPointContained(*point2, *poly));
+    ensure(!SimplePointInAreaLocator::isEveryPointContained(*point2, *multiPoly));
+    ensure(!SimplePointInAreaLocator::isEveryPointContained(*multiPoint2, *poly));
+    ensure(!SimplePointInAreaLocator::isEveryPointContained(*multiPoint2, *multiPoly));
+    // argument order reversed
+    ensure_THROW(SimplePointInAreaLocator::isAnyPointContained(*poly, *point), geos::util::GEOSException);
+    ensure_THROW(SimplePointInAreaLocator::isEveryPointContained(*poly, *point), geos::util::GEOSException);
diff --git a/tests/unit/capi/GEOSDisjointTest.cpp b/tests/unit/capi/GEOSDisjointTest.cpp
index 19b8fe138..24fd1eba0 100644
--- a/tests/unit/capi/GEOSDisjointTest.cpp
+++ b/tests/unit/capi/GEOSDisjointTest.cpp
@@ -58,5 +58,18 @@ void object::test<3>()
     ensure_equals(0, GEOSDisjoint_r(ctxt_, geom1_, geom2_));
+template<>
+template<>
+void object::test<4>()
+    set_test_name("MultiSurface / MultiPoint PIP");
+    geom1_ = fromWKT("MULTISURFACE(POLYGON ((100 100, 200 100, 200 200, 100 100)), CURVEPOLYGON (COMPOUNDCURVE(CIRCULARSTRING(0 0, 1 1, 2 0), (2 0, 0 0))))");
+    geom2_ = fromWKT("MULTIPOINT ((5000 5000), (0.1556955 0.5355459))");
+    ensure_equals(GEOSDisjoint(geom1_, geom2_), 0);
+    ensure_equals(GEOSDisjoint(geom2_, geom1_), 0);
 } // namespace tut
diff --git a/tests/unit/capi/GEOSIntersectsTest.cpp b/tests/unit/capi/GEOSIntersectsTest.cpp
index f11ac8615..63631bfca 100644
--- a/tests/unit/capi/GEOSIntersectsTest.cpp
+++ b/tests/unit/capi/GEOSIntersectsTest.cpp
@@ -236,8 +236,8 @@ template<>
 template<>
 void object::test<12>()
-    geom1_ = fromWKT("CURVEPOLYGON (COMPOUNDCURVE(CIRCULARSTRING(0 0, 1 1, 2 0), (2 0, 0 0)))");
-    geom2_ = fromWKT("POINT (0.1556955 0.5355459)");
     // PostGIS would return false here because geom2 is inside geom1
     // but outside the linearized form of geom1
@@ -272,5 +272,32 @@ void object::test<14>()
     ensure_equals(1, GEOSIntersects_r(ctxt_, geom1_, geom2_));
+template<>
+template<>
+void object::test<15>()
+    set_test_name("PostGIS ticket 5832");
+    geom1_ = fromWKT("MULTISURFACE(CURVEPOLYGON(COMPOUNDCURVE((25492739.7449 6677441.1816,25492771.1213 6677416.7832),CIRCULARSTRING(25492771.1213 6677416.7832,25492832.3384 6677400.8583,25492885.9851 6677434.3719),(25492885.9851 6677434.3719,25492900.7986 6677455.7498),CIRCULARSTRING(25492900.7986 6677455.7498,25492901.1068 6677457.3233,25492900.1601 6677458.6175,25492822.2626 6677477.2365,25492747.0232 6677449.7828),(25492747.0232 6677449.7828,25492739.7748 6677444.3615),CIRCULARSTRING(25492739.7748 6677444.3615,25492738.9731 6677442.7789,25492739.7449 6677441.1816))))");
+    geom2_ = fromWKT("POINT (25492818 6677399.98)");
+    ensure_equals(GEOSIntersects(geom1_, geom2_), 1);
+    ensure_equals(GEOSIntersects(geom2_, geom1_), 1);
+template<>
+template<>
+void object::test<16>()
+    set_test_name("mixed-dimension collection with point");
+    geom1_ = fromWKT("GEOMETRYCOLLECTION (CURVEPOLYGON (COMPOUNDCURVE(CIRCULARSTRING (-5 0, 0 5, 5 0), (5 0, -5 0))), LINESTRING (10 10, 11 11))");
+    geom2_ = fromWKT("POINT (11 11)");
+    // can't rely on PIP with mixed-dimension input, so return error for now
+    ensure_equals(GEOSIntersects(geom1_, geom2_), 2);
+    ensure_equals(GEOSIntersects(geom2_, geom1_), 2);
 } // namespace tut
Summary of changes:
 .../algorithm/locate/SimplePointInAreaLocator.h    |  4 +++
 src/algorithm/locate/SimplePointInAreaLocator.cpp  | 40 ++++++++++++++++++++--
 src/geom/Geometry.cpp                              | 18 ++++++----
 .../locate/SimplePointInAreaLocatorTest.cpp        | 38 ++++++++++++++++++++
 tests/unit/capi/GEOSDisjointTest.cpp               | 13 +++++++
 tests/unit/capi/GEOSIntersectsTest.cpp             | 31 +++++++++++++++--
 .../unit/operation/split/GeometrySplitterTest.cpp  | 11 ++++++
 7 files changed, 143 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
