[geos-commits] [SCM] GEOS branch 3.15 updated. ba13c5a0329ee8b0edd5d2562286f220e55866fe
git at osgeo.org
git at osgeo.org
Thu Sep 10 08:37:39 PDT 2026
the project "GEOS".
The branch, 3.15 has been updated
via ba13c5a0329ee8b0edd5d2562286f220e55866fe (commit)
from 19ff2e15e6be07e853db3c4ec5c3229ed10abf42 (commit)
revisions in full, below.
commit ba13c5a0329ee8b0edd5d2562286f220e55866fe
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Sep 10 11:37:20 2026 -0400
GeometrySplitter: handle MultiSurface inputs (#1527)
diff --git a/NEWS.md b/NEWS.md
index 831d214db..7ba8f81b8 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -3,6 +3,7 @@
- Fixes/Improvements:
- Fix arc noding failure with endpoint intersections (GH-1513, Dan Baston)
+ - Make GeometrySplitter able to split MultiSurface inputs (GH-1518, Dan Baston)
## Changes in 3.15.0
2026-09-01
diff --git a/src/operation/split/GeometrySplitter.cpp b/src/operation/split/GeometrySplitter.cpp
index b669b14ea..5319acd91 100644
--- a/src/operation/split/GeometrySplitter.cpp
+++ b/src/operation/split/GeometrySplitter.cpp
@@ -14,6 +14,7 @@
#include <geos/operation/split/GeometrySplitter.h>
+#include <geos/algorithm/locate/SimplePointInAreaLocator.h>
#include <geos/geom/CircularString.h>
#include <geos/geom/CompoundCurve.h>
#include <geos/geom/CoordinateSequence.h>
@@ -363,7 +364,7 @@ GeometrySplitter::splitPolygonalWithEdge(const Geometry &geom, const Geometry &e
for (auto& surface : surfaces)
const auto testPoint = getInteriorPoint(*surface);
- if (geom.intersects(testPoint.get())) {
+ if (algorithm::locate::SimplePointInAreaLocator::isContained(*testPoint->getCoordinate(), &geom)) {
keep.push_back(std::move(surface));
diff --git a/tests/unit/operation/split/GeometrySplitterTest.cpp b/tests/unit/operation/split/GeometrySplitterTest.cpp
index d4700ec47..478c053ec 100644
--- a/tests/unit/operation/split/GeometrySplitterTest.cpp
+++ b/tests/unit/operation/split/GeometrySplitterTest.cpp
@@ -912,4 +912,15 @@ void object::test<75>()
"GEOMETRYCOLLECTION (CURVEPOLYGON (COMPOUNDCURVE ((5 0, 0 0, 5 5), CIRCULARSTRING (5 5, 7 1, 5 0))), POLYGON ((0 0, 0 5, 5 5, 0 0)))");
+template<>
+template<>
+void object::test<77>()
+ set_test_name("split MultiSurface with LineString");
+ testSplit("MULTISURFACE(CURVEPOLYGON (COMPOUNDCURVE((5 0, 0 0, 0 5, 5 5), CIRCULARSTRING(5 5, 7 1, 5 0))))",
+ "LINESTRING(3 6, 3 -1)",
+ "GEOMETRYCOLLECTION (CURVEPOLYGON (COMPOUNDCURVE ((5 0, 3 0, 3 5, 5 5), CIRCULARSTRING (5 5, 7 1, 5 0))), POLYGON ((3 0, 0 0, 0 5, 3 5, 3 0)))");
Summary of changes:
NEWS.md | 1 +
src/operation/split/GeometrySplitter.cpp | 3 ++-
tests/unit/operation/split/GeometrySplitterTest.cpp | 11 +++++++++++
3 files changed, 14 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
