[geos-commits] [SCM] GEOS branch main updated. 493bfff3b8f4f4e356820bbf22e41b64d7077cc5
git at osgeo.org
git at osgeo.org
Fri Sep 11 04:48:56 PDT 2026
the project "GEOS".
The branch, main has been updated
via 493bfff3b8f4f4e356820bbf22e41b64d7077cc5 (commit)
from 979185683c608440f7dc36cec1474a5c2ab90b8a (commit)
revisions in full, below.
commit 493bfff3b8f4f4e356820bbf22e41b64d7077cc5
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Aug 31 05:27:20 2026 +0000
Expose revision-level version information
Adds:
- GEOS_REVISION in version.h header
- GEOSrevision() CAPI function,
- geos-config --revision switch
Includes unit test
Closes GH-1446
diff --git a/.gitignore b/.gitignore
index 9d8abedec..60c481cfb 100644
--- a/.gitignore
+++ b/.gitignore
@@ -3,6 +3,7 @@
aclocal.m4
Makefile.in
Makefile
+Testing
.libs
.deps
.vimrc
@@ -53,6 +54,7 @@ src/cmake_install.cmake
src/deps/cmake_install.cmake
tests/CTestTestfile.cmake
tests/cmake_install.cmake
+tests/fuzz/cmake_install.cmake
tests/unit/CTestTestfile.cmake
tests/unit/cmake_install.cmake
tests/xmltester/CTestTestfile.cmake
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 541288b93..865995778 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -78,6 +78,38 @@ message(STATUS "GEOS: Version ${GEOS_VERSION}")
message(STATUS "GEOS: C API Version ${CAPI_VERSION}")
message(STATUS "GEOS: JTS port ${JTS_PORT}")
+# Generate revision information from git
+execute_process(
+ COMMAND git describe --tags --always
+ WORKING_DIRECTORY ${CMAKE_SOURCE_DIR}
+ OUTPUT_VARIABLE _git_describe
+ ERROR_VARIABLE _git_describe_err
+# Strip any trailing newline/whitespace from the description
+string(STRIP "${_git_describe}" _git_describe_stripped)
+set(GEOS_REVISION "${_git_describe_stripped}" CACHE STRING "git describe output")
+# Check if the working tree is dirty
+execute_process(
+ COMMAND git diff --quiet
+ RESULT_VARIABLE _diff_rc
+if(NOT _diff_rc EQUAL 0)
+ set(GEOS_REVISION "${GEOS_REVISION} (dirty)")
+else()
+ # Also check for untracked files
+ execute_process(
+ COMMAND git status --porcelain
+ OUTPUT_VARIABLE _status
+ if(_status MATCHES "\\?\\?")
+ endif()
+endif()
if(CMAKE_VERSION VERSION_LESS 3.21)
if(CMAKE_CURRENT_SOURCE_DIR STREQUAL CMAKE_SOURCE_DIR)
set(PROJECT_IS_TOP_LEVEL ON)
diff --git a/NEWS.md b/NEWS.md
index f3b920928..a42c4db2f 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -4,6 +4,10 @@
- Fixes/Improvements:
+- New things:
+ - Expose code revision: GEOS_REVISION, GEOSrevision, geos-config --revision
+ (GH-1446 Sandro Santilli)
## Changes in 3.15.0
2026-09-01
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 8121146ba..19ec83cd0 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -69,6 +69,9 @@ extern "C" {
#ifndef GEOS_VERSION
#define GEOS_VERSION "@VERSION@"
#endif
+#ifndef GEOS_REVISION
+#define GEOS_REVISION "@GEOS_REVISION@"
+#endif
#ifndef GEOS_JTS_PORT
#define GEOS_JTS_PORT "@JTS_PORT@"
#endif
@@ -2537,6 +2540,15 @@ extern void GEOS_DLL GEOSFree_r(
extern const char GEOS_DLL *GEOSversion(void);
+* Returns the current GEOS revision string. eg: "3.15.0rc1-3-g952699419 (dirty)"
+* This function does not have a reentrant variant and is
+* available if `GEOS_USE_ONLY_R_API` is defined.
+* \return revision string
+* \since 3.15
+extern const char GEOS_DLL *GEOSrevision(void);
* External code to GEOS can define GEOS_USE_ONLY_R_API
* to strip the non-reentrant API functions from this header,
@@ -3205,7 +3217,7 @@ extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN(
* Returns the number of simple curves in a CompoundCurve.
-* Returns 1 for a non-empty LineString/CircularString, and 0
+* Returns 1 for a non-empty LineString/CircularString, and 0
* for other inputs.
* \param g Input geometry
* \return Number of child curves in this geometry
@@ -4787,7 +4799,7 @@ extern int GEOS_DLL GEOSBufferParams_setSingleSided(
* Generates a buffer using the special parameters in the GEOSBufferParams
* @INPUT_CURVES_CONVERTED_TO_LINES@
* \param g The geometry to buffer
@@ -5600,8 +5612,8 @@ extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram(
extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
-/** Split a linear or polygonal input
+/** Split a linear or polygonal input
* Linear inputs can be split with points, lines, and/or polygons.
* Polygons can be split with lines and/or polygons.
@@ -5758,7 +5770,7 @@ extern GEOSGeometry GEOS_DLL *GEOSBuildArea(const GEOSGeometry* g);
* evenly subdivide that segment. Z and M values of added
* vertices will be interpolated.
* Only linear components of input geometry are densified.
* Curved geometries are not supported, unless curve-to-line parameters are
* registered with the context handle. Output geometries will not contain
* curves.
@@ -6077,7 +6089,7 @@ extern GEOSGeometry GEOS_DLL *GEOSGeom_setPrecision(
* NULL on exception
* \since 3.15
extern GEOSGeometry GEOS_DLL *GEOSCurveToLine(
const GEOSGeometry* g,
const GEOSCurveToLineParams* params);
@@ -6093,7 +6105,7 @@ extern void GEOS_DLL GEOSCurveToLineParams_destroy(GEOSCurveToLineParams* params
* \return 1 if the operation succeeded, 0 otherwise
* \since 3.15
extern int GEOS_DLL GEOSCurveToLineParams_setMaxStepDegrees(
GEOSCurveToLineParams* params,
double tolerance);
@@ -6105,7 +6117,7 @@ extern int GEOS_DLL GEOSCurveToLineParams_setMaxStepDegrees(
* \since 3.15
extern int GEOS_DLL GEOSCurveToLineParams_setMaxDeviation(
double tolerance);
@@ -6119,7 +6131,7 @@ extern int GEOS_DLL GEOSCurveToLineParams_setMaxDeviation(
* NULL on exception
* \since 3.15
extern GEOSGeometry GEOS_DLL *GEOSLineToCurve(
const GEOSLineToCurveParams* params);
@@ -6133,7 +6145,7 @@ extern void GEOS_DLL GEOSLineToCurveParams_destroy(GEOSLineToCurveParams* params
* A vertex may be considered to continue a circular arc if its distance to the
* previously-computed circle center is within the specified fraction of the
* circle radius.
* \param params the parameters object
* \param tolerance the tolerance value
* \return 1 on success, 0 on failure
@@ -6149,7 +6161,7 @@ extern int GEOS_DLL GEOSLineToCurveParams_setRadiusTolerance(
* the point and the final point in the arc is less than the specified
* tolerance. Because of round-off errors, this value should be slightly
* greater than the one used in \ref GEOSCurveToLineParams_setMaxStepDegrees.
@@ -6165,9 +6177,9 @@ extern int GEOS_DLL GEOSLineToCurveParams_setMaxStepDegrees(
* the point and the final point in the arc is within the specified
* tolerance of the angle calculated when the final point in the arc was
* added. This tolerance can be used to ensure that the step spacing is
-* regular, which is an indication of a line that was generated by
+* regular, which is an indication of a line that was generated by
* linearizing a curve.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index eaccf1739..179015f24 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3190,6 +3190,13 @@ extern "C" {
return version;
+ const char* GEOSrevision()
+ static char rev[256];
+ snprintf(rev, 256, "%s", GEOS_REVISION);
+ return rev;
const char* GEOSjtsport()
return GEOS_JTS_PORT;
diff --git a/include/geos/version.h.in b/include/geos/version.h.in
index 104f0173d..ecaca0b96 100644
--- a/include/geos/version.h.in
+++ b/include/geos/version.h.in
@@ -30,6 +30,9 @@
#endif
+/* Revision-level version information */
#endif
diff --git a/tests/unit/capi/GEOSCAPIDefinesTest.cpp b/tests/unit/capi/GEOSCAPIDefinesTest.cpp
index b86c8fe1c..68e6c9c94 100644
--- a/tests/unit/capi/GEOSCAPIDefinesTest.cpp
+++ b/tests/unit/capi/GEOSCAPIDefinesTest.cpp
@@ -60,5 +60,14 @@ void object::test<3>
ensure_equals(GEOS_CAPI_VERSION, std::string(GEOSversion()));
+// Make sure revision define is consistent with function
+template<>
+template<>
+void object::test<4>
+ ensure_equals(GEOS_REVISION, std::string(GEOSrevision()));
} // namespace tut
diff --git a/tools/geos-config.in b/tools/geos-config.in
index c04b5957e..f61b4e930 100644
--- a/tools/geos-config.in
+++ b/tools/geos-config.in
@@ -12,6 +12,7 @@ Usage: geos-config [OPTIONS]
Options:
[--prefix]
[--version]
+ [--revision]
[--libs]
[--clibs]
[--cclibs]
@@ -41,6 +42,9 @@ while test $# -gt 0; do
--version)
echo @VERSION@
+ --revision)
+ echo "@GEOS_REVISION@"
--libs)
# TODO: make an alias for --clibs
# see http://trac.osgeo.org/geos/ticket/497
Summary of changes:
.gitignore | 2 ++
CMakeLists.txt | 32 +++++++++++++++++++++++++++
NEWS.md | 4 ++++
capi/geos_c.h.in | 38 ++++++++++++++++++++++-----------
capi/geos_ts_c.cpp | 7 ++++++
include/geos/version.h.in | 3 +++
tests/unit/capi/GEOSCAPIDefinesTest.cpp | 9 ++++++++
tools/geos-config.in | 4 ++++
8 files changed, 86 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits
