[geos-commits] [SCM] GEOS branch 3.15 updated. 86a4af483db99dc3f8914cd6a16cbfddd9961130
git at osgeo.org
git at osgeo.org
Mon Sep 21 09:48:40 PDT 2026
the project "GEOS".
The branch, 3.15 has been updated
via 86a4af483db99dc3f8914cd6a16cbfddd9961130 (commit)
from ba13c5a0329ee8b0edd5d2562286f220e55866fe (commit)
revisions in full, below.
commit 86a4af483db99dc3f8914cd6a16cbfddd9961130
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Sep 21 12:42:23 2026 -0400
GEOSGridIntersectionFractions: Set cells outside geometry bounding box to zero (#1532)
diff --git a/NEWS.md b/NEWS.md
index 7ba8f81b8..e5a2885ef 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -4,6 +4,7 @@
- Fixes/Improvements:
- Fix arc noding failure with endpoint intersections (GH-1513, Dan Baston)
- Make GeometrySplitter able to split MultiSurface inputs (GH-1518, Dan Baston)
+ - GEOSGridIntersectionFractions: Set cells outside geometry bounding box to zero (GH-1532, Dan Baston)
## Changes in 3.15.0
2026-09-01
diff --git a/include/geos/operation/grid/Matrix.h b/include/geos/operation/grid/Matrix.h
index 67d49d9cc..1d1a1bccd 100644
--- a/include/geos/operation/grid/Matrix.h
+++ b/include/geos/operation/grid/Matrix.h
@@ -141,6 +141,10 @@ class Matrix
return m_data.get() + m_rows * m_cols;
+ void fill(const T& val) {
+ std::fill(m_data.get(), m_data.get() + m_rows * m_cols, val);
#ifdef MATRIX_CHECK_BOUNDS
void check(size_t row, size_t col) const
diff --git a/src/operation/grid/GridIntersection.cpp b/src/operation/grid/GridIntersection.cpp
index 7c4815b75..c60c3aaec 100644
--- a/src/operation/grid/GridIntersection.cpp
+++ b/src/operation/grid/GridIntersection.cpp
@@ -60,6 +60,31 @@ get_cell(Matrix<std::unique_ptr<Cell>>& cells, const Grid<infinite_extent>& ex,
return cells(row, col).get();
+static Grid<infinite_extent>
+getSubgrid(const Envelope& box, const Grid<infinite_extent>& geometry_grid)
+ Envelope cropped_ring_extent = geometry_grid.getExtent().intersection(box);
+ return geometry_grid.shrinkToFit(cropped_ring_extent);
+getSubgrid(const Geometry& ls, const Grid<infinite_extent>& geometry_grid)
+ return getSubgrid(*ls.getEnvelopeInternal(), geometry_grid);
+template<typename T>
+static void
+initialize(const T& geom, const Grid<infinite_extent> geom_grid, Matrix<float>* cov)
+ const auto subgrid = getSubgrid(geom, geom_grid);
+ if (subgrid.getNumRows() < geom_grid.getNumRows() || subgrid.getNumCols() < geom_grid.getNumCols()) {
+ cov->fill(0);
Envelope
GridIntersection::processingRegion(const Envelope& raster_extent, const Geometry& g)
@@ -96,6 +121,10 @@ GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, cons
if (!m_geometry_grid.isEmpty()) {
+ if (cov) {
+ initialize(g, m_geometry_grid, cov.get());
process(g);
@@ -107,6 +136,10 @@ GridIntersection::GridIntersection(const Grid<bounded_extent>& raster_grid, cons
, m_areal{ false }
+ if (cov) {
+ initialize(box, m_geometry_grid, cov.get());
processRectangularRing(box, true);
@@ -140,19 +173,6 @@ GridIntersection::process(const Geometry& g)
-static Grid<infinite_extent>
-get_box_grid(const Envelope& box, const Grid<infinite_extent>& geometry_grid)
- Envelope cropped_ring_extent = geometry_grid.getExtent().intersection(box);
- return geometry_grid.shrinkToFit(cropped_ring_extent);
-get_ring_grid(const Geometry& ls, const Grid<infinite_extent>& geometry_grid)
- return get_box_grid(*ls.getEnvelopeInternal(), geometry_grid);
void
GridIntersection::processRectangularRing(const Envelope& box, bool exterior_ring)
@@ -160,7 +180,7 @@ GridIntersection::processRectangularRing(const Envelope& box, bool exterior_ring
return;
- auto ring_grid = get_box_grid(box, m_geometry_grid);
+ auto ring_grid = getSubgrid(box, m_geometry_grid);
auto row_min = ring_grid.getRow(box.getMaxY());
auto row_max = ring_grid.getRow(box.getMinY());
@@ -406,7 +426,7 @@ GridIntersection::processLine(const LineString& ls, bool exterior_ring)
- Grid<infinite_extent> ring_grid = get_ring_grid(ls, m_geometry_grid);
+ Grid<infinite_extent> ring_grid = getSubgrid(ls, m_geometry_grid);
size_t rows = ring_grid.getNumRows();
size_t cols = ring_grid.getNumCols();
diff --git a/tests/unit/capi/GEOSGridIntersectionFractionsTest.cpp b/tests/unit/capi/GEOSGridIntersectionFractionsTest.cpp
index 5dacbf175..59d0c9eaa 100644
--- a/tests/unit/capi/GEOSGridIntersectionFractionsTest.cpp
+++ b/tests/unit/capi/GEOSGridIntersectionFractionsTest.cpp
@@ -64,4 +64,31 @@ void object::test<3>()
ensure_equals(result, 0);
+template<>
+template<>
+void object::test<4>()
+ set_test_name("values outside the geometry bounding box are set to zero");
+ input_ = fromWKT("POLYGON ((0.5 0.5, 2.5 0.5, 2.5 2.5, 0.5 2.5, 0.5 0.5))");
+ const unsigned nx = 5;
+ const unsigned ny = 5;
+ const float init_value = 99999;
+ std::vector<float> result_vec(nx * ny, init_value);
+ int result = GEOSGridIntersectionFractions(input_, 0, 0, nx, ny, nx, ny, result_vec.data());
+ ensure_equals(result, 1);
+ std::vector<float> expected = {
+ 0, 0, 0, 0, 0,
+ 0, 0, 0, 0, 0,
+ 0.25, 0.5, 0.25, 0, 0,
+ 0.5, 1.0, 0.5, 0, 0,
+ ensure(result_vec == expected);
Summary of changes:
NEWS.md | 1 +
include/geos/operation/grid/Matrix.h | 4 ++
src/operation/grid/GridIntersection.cpp | 50 +++++++++++++++-------
.../capi/GEOSGridIntersectionFractionsTest.cpp | 27 ++++++++++++
4 files changed, 67 insertions(+), 15 deletions(-)
hooks/post-receive
More information about the geos-commits
