[geos-commits] [SCM] GEOS branch main updated. dbb5ced87a4032b7493cfce63b03a2aa3395f99e
Tue Sep 29 07:13:20 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  dbb5ced87a4032b7493cfce63b03a2aa3395f99e (commit)
       via  4f1be197934d552d6c5dbe40e382fc92639fb679 (commit)
      from  ae9cdd98be4e0bae552b918d4d14c94a9ce99c58 (commit)
revisions in full, below.
commit dbb5ced87a4032b7493cfce63b03a2aa3395f99e
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Sep 28 21:14:03 2026 -0400
    Remove header for unimplemented ConsistentAreaTester
diff --git a/include/geos/operation/valid/ConsistentAreaTester.h b/include/geos/operation/valid/ConsistentAreaTester.h
deleted file mode 100644
index 1addfdf21..000000000
--- a/include/geos/operation/valid/ConsistentAreaTester.h
+++ /dev/null
@@ -1,137 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: operation/valid/ConsistentAreaTester.java rev. 1.14 (JTS-1.10)
-#pragma once
-#include <geos/export.h>
-#include <geos/geom/Coordinate.h> // for composition
-#include <geos/algorithm/LineIntersector.h> // for composition
-#include <geos/operation/relate/RelateNodeGraph.h> // for composition
-// Forward declarations
-namespace geos {
-namespace algorithm {
-class LineIntersector;
-namespace geomgraph {
-class GeometryGraph;
-namespace operation {
-namespace relate {
-class RelateNodeGraph;
-namespace geos {
-namespace operation { // geos::operation
-namespace valid { // geos::operation::valid
-/** \brief
- * Checks that a geomgraph::GeometryGraph representing an area
- * (a geom::Polygon or geom::MultiPolygon)
- * has consistent semantics for area geometries.
- * This check is required for any reasonable polygonal model
- * (including the OGC-SFS model, as well as models which allow ring
- * self-intersection at single points)
- * Checks include:
- *  - test for rings which properly intersect
- *    (but not for ring self-intersection, or intersections at vertices)
- *  - test for consistent labelling at all node points
- *    (this detects vertex intersections with invalid topology,
- *    i.e. where the exterior side of an edge lies in the interior of the area)
- *  - test for duplicate rings
- * If an inconsistency is found the location of the problem
- * is recorded and is available to the caller.
-class GEOS_DLL ConsistentAreaTester {
-private:
-    algorithm::LineIntersector li;
-    /// Not owned
-    geomgraph::GeometryGraph* geomGraph;
-    relate::RelateNodeGraph nodeGraph;
-    /// the intersection point found (if any)
-    geom::Coordinate invalidPoint;
-     * Check all nodes to see if their labels are consistent.
-     * If any are not, return false
-    bool isNodeEdgeAreaLabelsConsistent();
-public:
-     * Creates a new tester for consistent areas.
-     * @param newGeomGraph the topology graph of the area geometry.
-     *                     Caller keeps responsibility for its deletion
-    ConsistentAreaTester(geomgraph::GeometryGraph* newGeomGraph);
-    ~ConsistentAreaTester() = default;
-     * @return the intersection point, or <code>null</code>
-     *         if none was found
-    geom::Coordinate& getInvalidPoint();
-    /** \brief
-     * Check all nodes to see if their labels are consistent with
-     * area topology.
-     * @return <code>true</code> if this area has a consistent node
-     *         labelling
-    bool isNodeConsistentArea();
-     * Checks for two duplicate rings in an area.
-     * Duplicate rings are rings that are topologically equal
-     * (that is, which have the same sequence of points up to point order).
-     * If the area is topologically consistent (determined by calling the
-     * <code>isNodeConsistentArea</code>,
-     * duplicate rings can be found by checking for EdgeBundles which contain
-     * more than one geomgraph::EdgeEnd.
-     * (This is because topologically consistent areas cannot have two rings sharing
-     * the same line segment, unless the rings are equal).
-     * The start point of one of the equal rings will be placed in
-     * invalidPoint.
-     * @return true if this area Geometry is topologically consistent but has two duplicate rings
-    bool hasDuplicateRings();
-} // namespace geos::operation::valid
commit 4f1be197934d552d6c5dbe40e382fc92639fb679
Date:   Mon Sep 28 21:13:17 2026 -0400
    IsValidOp: Apply const/static where possible
diff --git a/include/geos/operation/valid/IndexedNestedHoleTester.h b/include/geos/operation/valid/IndexedNestedHoleTester.h
index c52e977a0..7e197ea64 100644
--- a/include/geos/operation/valid/IndexedNestedHoleTester.h
+++ b/include/geos/operation/valid/IndexedNestedHoleTester.h
@@ -18,8 +18,6 @@
 #include <geos/index/strtree/TemplateSTRtree.h>
-#include <memory>
 namespace geos {
 namespace geom {
@@ -61,7 +59,7 @@ public:
     * @return a point on a nested hole, or null if none are nested
-    const CoordinateXY& getNestedPoint() { return nestedPt; }
+    const CoordinateXY& getNestedPoint() const { return nestedPt; }
     * Tests if any hole is nested (contained) within another hole.
diff --git a/include/geos/operation/valid/IndexedNestedPolygonTester.h b/include/geos/operation/valid/IndexedNestedPolygonTester.h
index 22650be44..f1d7d87d2 100644
--- a/include/geos/operation/valid/IndexedNestedPolygonTester.h
+++ b/include/geos/operation/valid/IndexedNestedPolygonTester.h
@@ -19,7 +19,6 @@
 #include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
-#include <memory>
 #include <map>
@@ -65,11 +64,11 @@ private:
     * Finds a point of a shell segment which lies inside a polygon, if any.
-    * The shell is assume to touch the polyon only at shell vertices,
+    * The shell is assumed to touch the polygon only at shell vertices,
     * and does not cross the polygon.
-    * @param the shell to test
-    * @param the polygon to test against
+    * @param shell the shell to test
+    * @param poly the polygon to test against
     * @param coordNested return parameter for found coordinate
     * @return an interior segment point, or null if the shell is nested correctly
diff --git a/include/geos/operation/valid/IsValidOp.h b/include/geos/operation/valid/IsValidOp.h
index 27c6fe4c4..e2d4b71f1 100644
--- a/include/geos/operation/valid/IsValidOp.h
+++ b/include/geos/operation/valid/IsValidOp.h
@@ -148,9 +148,9 @@ private:
      * @param minSize the minimum line size
      * @return true if the line has the required number of non-repeated points
-    bool isNonRepeatedSizeAtLeast(const geom::LineString* line, std::size_t minSize);
+    static bool isNonRepeatedSizeAtLeast(const geom::LineString* line, std::size_t minSize);
-    void checkAreaIntersections(PolygonTopologyAnalyzer& areaAnalyzer);
+    void checkAreaIntersections(const PolygonTopologyAnalyzer& areaAnalyzer);
      * Check whether a ring self-intersects (except at its endpoints).
@@ -183,7 +183,7 @@ private:
      * @param shell the polygon shell to test against
      * @return a hole point outside the shell, or null if it is inside
-    const CoordinateXY* findHoleOutsideShellPoint(
+    static const CoordinateXY* findHoleOutsideShellPoint(
         const geom::LinearRing* hole,
         const geom::LinearRing* shell);
diff --git a/include/geos/operation/valid/PolygonIntersectionAnalyzer.h b/include/geos/operation/valid/PolygonIntersectionAnalyzer.h
index 4a2eed919..153cb9d6a 100644
--- a/include/geos/operation/valid/PolygonIntersectionAnalyzer.h
+++ b/include/geos/operation/valid/PolygonIntersectionAnalyzer.h
@@ -23,8 +23,6 @@
-#include <memory>
 namespace geos {
 namespace noding {
@@ -53,7 +51,7 @@ private:
         const SegmentString* ss0, std::size_t segIndex0,
         const SegmentString* ss1, std::size_t segIndex1);
-    bool addDoubleTouch(
+    static bool addDoubleTouch(
         const SegmentString* ss0, const SegmentString* ss1,
         const CoordinateXY& intPt);
@@ -62,11 +60,11 @@ private:
         const CoordinateXY* e00, const CoordinateXY* e01,
         const CoordinateXY* e10, const CoordinateXY* e11);
-    const CoordinateXY& prevCoordinateInRing(
-        const SegmentString* ringSS, std::size_t segIndex) const;
+    static const CoordinateXY& prevCoordinateInRing(
+        const SegmentString* ringSS, std::size_t segIndex);
-    bool isAdjacentInRing(const SegmentString* ringSS,
-        std::size_t segIndex0, std::size_t segIndex1) const;
+    static bool isAdjacentInRing(const SegmentString* ringSS,
+        std::size_t segIndex0, std::size_t segIndex1);
 public:
@@ -74,7 +72,7 @@ public:
     * Creates a new finder, allowing for the mode where inverted rings are valid.
-    * @param isInvertedRingValid true if inverted rings are valid.
+    * @param p_isInvertedRingValid true if inverted rings are valid.
     PolygonIntersectionAnalyzer(bool p_isInvertedRingValid)
         : isInvertedRingValid(p_isInvertedRingValid)
diff --git a/include/geos/operation/valid/PolygonRing.h b/include/geos/operation/valid/PolygonRing.h
index b1447c18a..bd74812f9 100644
--- a/include/geos/operation/valid/PolygonRing.h
+++ b/include/geos/operation/valid/PolygonRing.h
@@ -21,7 +21,6 @@
-#include <memory>
 #include <map>
@@ -77,7 +76,7 @@ private:
     * Tests if this ring touches a given ring at
     * the single point specified.
-    * @param ring the other PolygonRing
+    * @param polyRing the other PolygonRing
     * @param pt the touch point
     * @return true if the rings touch only at the given point
@@ -93,7 +92,7 @@ private:
     const CoordinateXY* findHoleCycleLocation();
-    void init(PolygonRing* root, std::stack<PolygonRingTouch*>& touchStack);
+    static void init(PolygonRing* root, std::stack<PolygonRingTouch*>& touchStack);
     * Scans for a hole cycle starting at a given touch.
@@ -103,7 +102,7 @@ private:
     * @param touchStack the stack of touches to scan
     * @return a vertex in a hole cycle if found, or null
-    const CoordinateXY* scanForHoleCycle(PolygonRingTouch* currentTouch,
+    static const CoordinateXY* scanForHoleCycle(const PolygonRingTouch* currentTouch,
         PolygonRing* root,
@@ -183,7 +182,7 @@ public:
     * @param polyRings the list of rings to check
     * @return a vertex contained in a ring cycle, or null if none is found
-    static const CoordinateXY* findHoleCycleLocation(std::vector<PolygonRing*> polyRings);
+    static const CoordinateXY* findHoleCycleLocation(const std::vector<PolygonRing*>& polyRings);
     * Finds a location of an interior self-touch in a list of rings,
@@ -194,7 +193,7 @@ public:
     * @return the location of an interior self-touch node, or null if there are none
-    static const CoordinateXY* findInteriorSelfNode(std::vector<PolygonRing*> polyRings);
+    static const CoordinateXY* findInteriorSelfNode(const std::vector<PolygonRing*>& polyRings);
     bool isSamePolygon(const PolygonRing* polyRing) const
@@ -216,7 +215,7 @@ public:
-    const CoordinateXY* findInteriorSelfNode();
+    const CoordinateXY* findInteriorSelfNode() const;
diff --git a/include/geos/operation/valid/PolygonRingSelfNode.h b/include/geos/operation/valid/PolygonRingSelfNode.h
index 2b95eebdb..5803fb437 100644
--- a/include/geos/operation/valid/PolygonRingSelfNode.h
+++ b/include/geos/operation/valid/PolygonRingSelfNode.h
@@ -19,8 +19,6 @@
-#include <memory>
 namespace geos {      // geos.
 namespace operation { // geos.operation
diff --git a/include/geos/operation/valid/PolygonRingTouch.h b/include/geos/operation/valid/PolygonRingTouch.h
index b59e64bbe..c7d9b58f0 100644
--- a/include/geos/operation/valid/PolygonRingTouch.h
+++ b/include/geos/operation/valid/PolygonRingTouch.h
@@ -19,8 +19,6 @@
-#include <memory>
 namespace geos {
diff --git a/include/geos/operation/valid/PolygonTopologyAnalyzer.h b/include/geos/operation/valid/PolygonTopologyAnalyzer.h
index 91beba6bb..4ab9c5237 100644
--- a/include/geos/operation/valid/PolygonTopologyAnalyzer.h
+++ b/include/geos/operation/valid/PolygonTopologyAnalyzer.h
@@ -22,8 +22,6 @@
 #include <geos/operation/valid/PolygonRing.h>
 #include <geos/noding/BasicSegmentString.h>
-#include <memory>
 namespace geos {
 namespace geom {
@@ -102,7 +100,7 @@ private:
     std::vector<SegmentString*> createSegmentStrings(const Geometry* geom, bool isInvertedRingValid);
-    std::vector<PolygonRing*> getPolygonRings(const std::vector<SegmentString*>& segStrings);
+    static std::vector<PolygonRing*> getPolygonRings(const std::vector<SegmentString*>& segStrings);
     SegmentString* createSegString(const LinearRing* ring, const PolygonRing* polyRing);
@@ -145,15 +143,15 @@ public:
     isRingNested(const LinearRing* test,
         const LinearRing* target);
-    bool hasInvalidIntersection() {
+    bool hasInvalidIntersection() const {
         return segInt.isInvalid();
-    int getInvalidCode() {
+    int getInvalidCode() const {
         return segInt.getInvalidCode();
-    const CoordinateXY& getInvalidLocation() {
+    const CoordinateXY& getInvalidLocation() const {
         return segInt.getInvalidLocation();
diff --git a/src/operation/valid/IndexedNestedHoleTester.cpp b/src/operation/valid/IndexedNestedHoleTester.cpp
index c4b9d49af..5d57ac328 100644
--- a/src/operation/valid/IndexedNestedHoleTester.cpp
+++ b/src/operation/valid/IndexedNestedHoleTester.cpp
@@ -44,7 +44,7 @@ bool
 IndexedNestedHoleTester::isNested()
     for (std::size_t i = 0; i < polygon->getNumInteriorRing(); i++) {
-        const LinearRing* hole = static_cast<const LinearRing*>(polygon->getInteriorRingN(i));
+        const LinearRing* hole = polygon->getInteriorRingN(i);
         std::vector<const LinearRing*> results;
         index.query(*(hole->getEnvelopeInternal()), results);
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 454d9a18c..625aafa54 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -346,7 +346,7 @@ IsValidOp::checkTooFewPoints(const LineString* line, std::size_t minSize)
     if (! isNonRepeatedSizeAtLeast(line, minSize) ) {
         CoordinateXY pt = line->getNumPoints() >= 1
                         ? line->getCoordinatesRO()->getAt<CoordinateXY>(0)
-                        : Coordinate();
+                        : CoordinateXY();
         logInvalid(TopologyValidationError::eTooFewPoints, pt);
@@ -372,7 +372,7 @@ IsValidOp::isNonRepeatedSizeAtLeast(const LineString* line, std::size_t minSize)
 /* private */
 void
-IsValidOp::checkAreaIntersections(PolygonTopologyAnalyzer& areaAnalyzer)
+IsValidOp::checkAreaIntersections(const PolygonTopologyAnalyzer& areaAnalyzer)
     if (areaAnalyzer.hasInvalidIntersection()) {
         logInvalid(areaAnalyzer.getInvalidCode(),
diff --git a/src/operation/valid/PolygonIntersectionAnalyzer.cpp b/src/operation/valid/PolygonIntersectionAnalyzer.cpp
index 7f71f0f08..e7ab16071 100644
--- a/src/operation/valid/PolygonIntersectionAnalyzer.cpp
+++ b/src/operation/valid/PolygonIntersectionAnalyzer.cpp
@@ -191,7 +191,7 @@ PolygonIntersectionAnalyzer::addSelfTouch(
 /* private */
 const CoordinateXY&
 PolygonIntersectionAnalyzer::prevCoordinateInRing(
     std::size_t prevIndex;
     if (segIndex == 0) {
@@ -206,7 +206,7 @@ PolygonIntersectionAnalyzer::prevCoordinateInRing(
 /* private */
 bool
 PolygonIntersectionAnalyzer::isAdjacentInRing(const SegmentString* ringSS,
     std::size_t delta = segIndex0 > segIndex1
                         ? segIndex0 - segIndex1
diff --git a/src/operation/valid/PolygonRing.cpp b/src/operation/valid/PolygonRing.cpp
index 5a0c583da..5ff972592 100644
--- a/src/operation/valid/PolygonRing.cpp
+++ b/src/operation/valid/PolygonRing.cpp
@@ -14,7 +14,6 @@
 #include <geos/algorithm/Orientation.h>
-#include <geos/algorithm/PolygonNodeTopology.h>
 #include <geos/geom/LinearRing.h>
@@ -59,7 +58,7 @@ PolygonRing::addTouch(PolygonRing* ring0, PolygonRing* ring1, const CoordinateXY
 /* public static */
 const CoordinateXY*
-PolygonRing::findHoleCycleLocation(std::vector<PolygonRing*> polyRings)
+PolygonRing::findHoleCycleLocation(const std::vector<PolygonRing*>& polyRings)
     for (PolygonRing* polyRing : polyRings) {
         if (! polyRing->isInTouchSet()) {
@@ -73,9 +72,9 @@ PolygonRing::findHoleCycleLocation(std::vector<PolygonRing*> polyRings)
 /* public static */
 const CoordinateXY*
-PolygonRing::findInteriorSelfNode(std::vector<PolygonRing*> polyRings)
+PolygonRing::findInteriorSelfNode(const std::vector<PolygonRing*>& polyRings)
-    for (PolygonRing* polyRing : polyRings) {
+    for (const PolygonRing* polyRing : polyRings) {
         const CoordinateXY* interiorSelfNode = polyRing->findInteriorSelfNode();
         if (interiorSelfNode != nullptr) {
             return interiorSelfNode;
@@ -161,7 +160,7 @@ PolygonRing::findHoleCycleLocation()
     init(root, touchStack);
     while (! touchStack.empty()) {
-        PolygonRingTouch* touch = touchStack.top();
+        const PolygonRingTouch* touch = touchStack.top();
         touchStack.pop();
         const CoordinateXY* holeCyclePt = scanForHoleCycle(touch, root, touchStack);
         if (holeCyclePt != nullptr) {
@@ -185,11 +184,11 @@ PolygonRing::init(PolygonRing* root, std::stack<PolygonRingTouch*>& touchStack)
 /* private */
 const CoordinateXY*
-PolygonRing::scanForHoleCycle(PolygonRingTouch* currentTouch,
+PolygonRing::scanForHoleCycle(const PolygonRingTouch* currentTouch,
     PolygonRing* root,
-    PolygonRing* polyRing = currentTouch->getRing();
+    const PolygonRing* polyRing = currentTouch->getRing();
     const CoordinateXY* currentPt = currentTouch->getCoordinate();
@@ -229,7 +228,7 @@ PolygonRing::scanForHoleCycle(PolygonRingTouch* currentTouch,
 /* public */
 const CoordinateXY*
-PolygonRing::findInteriorSelfNode()
+PolygonRing::findInteriorSelfNode() const
     if (selfNodes.empty()) return nullptr;
diff --git a/src/operation/valid/PolygonTopologyAnalyzer.cpp b/src/operation/valid/PolygonTopologyAnalyzer.cpp
index 2a65cbc16..3e719fdab 100644
--- a/src/operation/valid/PolygonTopologyAnalyzer.cpp
+++ b/src/operation/valid/PolygonTopologyAnalyzer.cpp
@@ -43,7 +43,7 @@ namespace valid {     // geos.operation.valid
 PolygonTopologyAnalyzer::PolygonTopologyAnalyzer(const Geometry* geom, bool p_isInvertedRingValid)
     , segInt(p_isInvertedRingValid)
-    , disconnectionPt(Coordinate::getNull())
+    , disconnectionPt(CoordinateXY::getNull())
     if (geom->isEmpty()){
         return;
@@ -68,7 +68,7 @@ PolygonTopologyAnalyzer::findSelfIntersection(const LinearRing* ring)
     PolygonTopologyAnalyzer ata(ring, false);
     if (ata.hasInvalidIntersection())
         return ata.getInvalidLocation();
-    return Coordinate::getNull();
+    return CoordinateXY::getNull();
 /* public static */
@@ -178,7 +178,6 @@ std::size_t
 PolygonTopologyAnalyzer::intersectingSegIndex(const CoordinateSequence* ringPts,
     const CoordinateXY* pt)
     for (std::size_t i = 0; i < ringPts->size() - 1; i++) {
       if ( algorithm::PointLocation::isOnSegment(*pt, ringPts->getAt<CoordinateXY>(i), ringPts->getAt<CoordinateXY>(i+1)) ) {
         //-- check if pt is the start point of the next segment
Summary of changes:
 .../geos/operation/valid/ConsistentAreaTester.h    | 137 ---------------------
 .../geos/operation/valid/IndexedNestedHoleTester.h |   4 +-
 .../operation/valid/IndexedNestedPolygonTester.h   |   7 +-
 include/geos/operation/valid/IsValidOp.h           |   6 +-
 .../operation/valid/PolygonIntersectionAnalyzer.h  |  14 +--
 include/geos/operation/valid/PolygonRing.h         |  13 +-
 include/geos/operation/valid/PolygonRingSelfNode.h |   2 -
 include/geos/operation/valid/PolygonRingTouch.h    |   2 -
 .../geos/operation/valid/PolygonTopologyAnalyzer.h |  10 +-
 src/operation/valid/IndexedNestedHoleTester.cpp    |   2 +-
 src/operation/valid/IsValidOp.cpp                  |   4 +-
 .../valid/PolygonIntersectionAnalyzer.cpp          |   4 +-
 src/operation/valid/PolygonRing.cpp                |  15 ++-
 src/operation/valid/PolygonTopologyAnalyzer.cpp    |   5 +-
 14 files changed, 37 insertions(+), 188 deletions(-)
 delete mode 100644 include/geos/operation/valid/ConsistentAreaTester.h
hooks/post-receive
More information about the geos-commits mailing list
