[geos-devel] AutoConf Files
Paul Ramsey pramsey at refractions.net
Fri Aug 30 14:20:10 EDT 2002
OK, the autoconf support has been committed.
Remember to do a 'cvs update -dP' ASAP to get the changes, directory
moves etc.
 From Norman's notes on building:
1)  ./autogen.sh
2)  ./configure
3)  make
At the moment, your reward will be alot of compilation failures, but it
is a point to start debugging from. I am attaching the diff file Norman
make which has the "bad" lines commented out. It might serve as a guide
to what is causing the failures on GNU platforms.
P.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
Type: application/x-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20020830/315aae8c/nhv_diffs.bin
