[geos-devel] GEOS libraries
Norman Vine nhv at cape.com
Fri Aug 30 15:08:47 EDT 2002
Ferdinando Villa writes:
> I almost had a complete distro when Norman's tarball came in. It makes
> one single library (shared through libtool and static) - also I was
> writing geos-config and m4 support for configuring GEOS in other
> distributions. Should I finish this (after you commit what we have) or
> you guys are already beyond me on these things? btw,
Ferdinando
Your system sounds better in that mine made a library per directory.
When you have got yours working it should only take a CVS commit
to change over to your 'better' one :-)
But until then my system will let those of us using gcc get started.
> it's great to see  open source at work....
Indeed :-))
ciao
Norman
