[geos-devel] GEOS libraries
Ferdinando Villa fvilla at zoo.uvm.edu
Fri Aug 30 13:23:44 EDT 2002
I'll be pleased to either 1) do that or 2) let Norman do it! Norman,
your call. I'll be following the development and periodically try to
compile here (Redhat 7.3) anyway - I need geos!
f.
On Fri, 2002-08-30 at 14:56, Paul Ramsey wrote:
>    I think now that we have a simple autoconf framework, the next bit is
> to get things compiling cleanly, then linking into the one library. I
> would like to hear from Yury that the changes committed thus far have
> not mucked up what he is working on... :)
>    I can give you and/or Norman write access to the archive to keep the
> build framework up to date, as Yury will be continuing to add a good
> deal of code over the next couple months, and it would be better that he
> focus on the code and not on the build details.
>    So, can either of you look over the build consistency and portability
> issues once every couple weeks or so?
> P.
> Ferdinando Villa wrote:
> > I almost had a complete distro when Norman's tarball came in. It makes
> > one single library (shared through libtool and static) - also I was
> > writing geos-config and m4 support for configuring GEOS in other
> > distributions. Should I finish this (after you commit what we have) or
> > you guys are already beyond me on these things? btw, it's great to see
> > open source at work....
> > ciao ferdinando
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
ferdinando villa, ph.d.                    associate professor
gund institute for ecological economics, university of vermont
590 main street, burlington, vt 05405    phone: (802) 656-2972
