[geos-devel] FW: Report
Paul Ramsey pramsey at refractions.net
Tue Jun 4 22:12:06 EDT 2002
Thanks guys,
Are we still on track to have the object model done by the end of this
week? When we have to object model done, would that be an opportune time
to import the source into CVS?
Paul
> -----Original Message-----
> From: Yury A. Bychkov [mailto:ybychkov at direct.ca]
> Sent: Friday, May 31, 2002 9:45 AM
> To: mbdavis at vividsolutions.com
> Subject: Report
> Just a short report summarizing my activities:
> 1. Spent most of the time learning finer points of Java to C++ conversion
> and
> testing if my C++ classes work.
> 2. Converted Coordinate, CoordinateFilter, Dimension and part of Envelope.
> 3. Conversion time is reducing with each consecutive class as I learn how
> different code structures map from Java to C++.
> 4. Total time spent from Friday, May 24 to Thursday, May 30 (inclusive) is
> 17
> hours 13 min.
> Decisions from Friday, May 31 phone meeting:
> 1. Create a .h file for platform-dependent values (e.g. Double.NaN)
> 2. Replace my additinal code in Coordinate (for 3D comparison) with code
> that
> uses NaN (see #1).
> 3. Use one .h file per package.
> 4. Replace 'equals' method in Comparable java classes with overloaded '='
> 5. Make sure that all Coordinates are values and not references.
> 6. Send weekly emails similar to this one.
> Yury Bychkov
