[geos-devel] New performance test with 2 large geometrys
Martin Davis
mbdavis at VividSolutions.com
Fri Nov 8 20:16:11 EST 2002
I tried a slight variation of the original SineStar test (call it SineStarSquared). It compares two SineStars, each with the same number of points. One sineStar is offset from the other by 50 units in the y direction. This means that the number of actual intersections is constant. With the indexing implemented in JTS the expected performance is linear (and this is in fact what happens, I'm happy to say). (Note that an implementation with poor or no indexing could have time of O(n^2), however.)
Here's the timings. They're only 50% slower than the original SineStarBox test, which is pretty good.
n Pts: 1000 Executed in 2804 ms
n Pts: 2000 Executed in 60 ms
n Pts: 4000 Executed in 120 ms
n Pts: 8000 Executed in 210 ms
n Pts: 16000 Executed in 401 ms
n Pts: 32000 Executed in 661 ms
n Pts: 64000 Executed in 1421 ms
n Pts: 128000 Executed in 2644 ms
n Pts: 256000 Executed in 5307 ms
(Yury: to implement this simply replace the line
Polygon box = GeometryTestFactory.createBox(fact,0,0,1,100.0);
with
Polygon box = GeometryTestFactory.createSineStar(fact, 0.0, size/2, size, armLen, nArms, nPts);
Martin Davis, Senior Technical Specialist
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
