[geos-devel] Profiling results
Norman Vine
nhv at cape.com
Wed Nov 20 13:52:01 EST 2002
Hi all,
While looking into why all the calls to signOfDet2x2()
I experimented with an early out mechanism in
RobustLineIntersector::computeIntersect(...)
I think that computeIntersect() is still 'correct'
but would appreciate comments as to otherwise
< see below >
following results from a 2,000,000 point test
< note new functions indexOfMaxY() and getMinMax2()
are simple scans of the CoordinateList that
reflect the time to traverse the List >
Cheers
Norman
< before >
81.21 6.31 6.31 28704650 0.00 0.00 RobustDeterminant::signOfDet2x2(double&, double&, double&, double&)
10.17 7.10 0.79 10352339 0.00 0.00 SegmentIntersector::addIntersections(Edge*, int, Edge*, int)
3.73 7.39 0.29 1 0.29 0.29 GeometryTestFactory::createSineStar(double, double, double, double, int, int)
2.83 7.61 0.22 2 0.11 0.11 CoordinateList::getMinMax2D(double*, double*, double*, double*)
1.16 7.70 0.09 2 0.04 0.04 CoordinateList::indexOfMaxY()
0.26 7.72 0.02 2 0.01 0.02 LineString::LineString(CoordinateList, PrecisionModel, int)
0.13 7.73 0.01 19 0.00 0.00 PrecisionModel::PrecisionModel(PrecisionModel const&)
0.13 7.74 0.01 2 0.01 0.01 LineString::isClosed()
0.13 7.75 0.01 2 0.01 0.01 PlanarGraph::insertEdge(Edge*)
0.13 7.76 0.01 2 0.01 0.01 CoordinateList::hasNullElement()
0.13 7.77 0.01 2 0.01 0.01 EdgeIntersectionList::EdgeIntersectionList(Edge*)
< after >
66.92 1.78 1.78 17999884 0.00 0.00 RobustDeterminant::signOfDet2x2(double&, double&, double&, double&)
12.41 2.11 0.33 1 0.33 0.33 GeometryTestFactory::createSineStar(double, double, double, double, int, int)
9.77 2.37 0.26 10352339 0.00 0.00 SegmentIntersector::addIntersections(Edge*, int, Edge*, int)
4.89 2.50 0.13 2 0.07 0.07 CoordinateList::getMinMax2D(double*, double*, double*, double*)
3.38 2.59 0.09 2 0.04 0.04 CoordinateList::indexOfMaxY()
0.75 2.61 0.02 2 0.01 0.01 LineString::LineString(CoordinateList, PrecisionModel, int)
0.38 2.62 0.01 6 0.00 0.00 RobustCGAlgorithms::RobustCGAlgorithms()
0.38 2.63 0.01 2 0.01 0.01 LineString::isClosed()
0.38 2.64 0.01 2 0.01 0.05 GeometryGraph::addPolygonRing(LinearRing*, int, int)
0.38 2.65 0.01 2 0.01 0.01 CoordinateList::hasNullElement()
0.38 2.66 0.01 _GLOBAL__I__ZN18GeometryCollectionC2Ev
int RobustLineIntersector::computeIntersect(Coordinate p1,Coordinate p2,
Coordinate q1,Coordinate q2)
isProperVar=false;
* for each endpoint,compute which side of the other
* segment it lies, if both endpoints lie on the same side
* of the other segment,the segments do not intersect
// But first lets try a trivial reject
double minq = min(q1.x, q2.x);
double maxq = max(q1.x, q2.x);
double minp = min(p1.x, p2.x);
double maxp = max(p1.x, p2.x);
if( minp > maxq )
return DONT_INTERSECT;
if( maxp < minq )
minq = min(q1.y, q2.y);
maxq = max(q1.y, q2.y);
minp = min(p1.y, p2.y);
maxp = max(p1.y, p2.y);
if( minp > maxq )
if( maxp < minq )
int Pq1=RobustCGAlgorithms::orientationIndex(p1,p2,q1);
int Pq2=RobustCGAlgorithms::orientationIndex(p1,p2,q2);
if ((Pq1>0 && Pq2>0) || (Pq1<0 && Pq2<0)) {
int Qp1=RobustCGAlgorithms::orientationIndex(q1,q2,p1);
int Qp2=RobustCGAlgorithms::orientationIndex(q1,q2,p2);
if ((Qp1>0 && Qp2>0) || (Qp1<0 && Qp2<0)) {
// if collinear
if ((Pq1==0) && (Pq2==0) && (Qp1==0) && (Qp2==0)) {
return computeCollinearIntersection(p1,p2,q1,q2);
* Check if the intersection is an endpoint.
* If it is,copy the endpoint as the intersection point.
* Copying the point rather than computing it ensures the
* point has the exact value, which is important for
* robustness. It is sufficient to simply check for an
* endpoint which is on the other line,since at this point
* we know that the inputLines must intersect.
if ((Pq1==0) || (Pq2==0) || (Qp1==0) || (Qp2==0)) {
isProperVar=false;
if (Pq1==0) {
intPt[0].setCoordinate(q1);
if (Pq2==0) {
intPt[0].setCoordinate(q2);
if (Qp1==0) {
intPt[0].setCoordinate(p1);
if (Qp2==0) {
intPt[0].setCoordinate(p2);
} else {
isProperVar=true;
intPt[0].setCoordinate(intersection(p1,p2,q1,q2));
return DO_INTERSECT;
