[geos-devel] Coordinate & Coordinate list
    David Blasby
    dblasby at refractions.net
    Thu Nov 14 18:09:52 EST 2002
Good points, Martin.
The profing of GEOS seemed to indicate that most of the time was spent constructing and get()ing coordinates.  I think the get() function should be returning pointers to coordinates instead of actual coordinates (which require quite a bit of memory moving and allocation).
The important thing is to *not* return a Coordinate, but a pointer-to-coordinate.
Any word on why there were 250 million Coordinate constructions?
dave
ps. I checked  and Coordinate is only 24 bytes long (I thought there would be a bunch of other information in it for the class and class methods).
pps. you're right about array-of-pointers being less efficient.  I thought they would be more efficient because your memory space wouldnt be chopped-up so much, but after thinking about it, the malloc() free table should be pretty empty.
