[geos-devel] Coordinate & Coordinate list
Martin Davis mbdavis at VividSolutions.com
Thu Nov 14 18:30:39 EST 2002
Good point about returning a pointer instead of a value.  Or even better I think (certainly a more precise reflection of the usage), return a reference.
Not sure about the reason for the large number of Coordinate allocations.  I think we should make the obvious changes to the CoordinateList interface and then rerun the metrics, since things may change quite a bit.
Martin Davis, Senior Technical Specialist
Vivid Solutions Inc.
Suite #1A-2328 Government Street   Victoria, B.C.   V8T 5G5
Phone: (250) 385 6040    Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com  Web: www.vividsolutions.com
> -----Original Message-----
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: Thursday, November 14, 2002 3:10 PM
> To: geos-devel at geos.refractions.net
> Subject: Re: [geos-devel] Coordinate & Coordinate list
> Good points, Martin.
> The profing of GEOS seemed to indicate that most of the time
> was spent constructing and get()ing coordinates.  I think the
> get() function should be returning pointers to coordinates
> instead of actual coordinates (which require quite a bit of
> memory moving and allocation).
> The important thing is to *not* return a Coordinate, but a
> pointer-to-coordinate.
> Any word on why there were 250 million Coordinate constructions?
> dave
> ps. I checked  and Coordinate is only 24 bytes long (I
> thought there would be a bunch of other information in it for
> the class and class methods).
> pps. you're right about array-of-pointers being less
> efficient.  I thought they would be more efficient because
> your memory space wouldnt be chopped-up so much, but after
> thinking about it, the malloc() free table should be pretty empty.
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
