[geos-devel] Coordinate & Coordinate list (20% faster now)
David Blasby
dblasby at refractions.net
Thu Nov 14 19:15:17 EST 2002
I tested my theory:
50,000 points TestSweepLineSpeed
takes about 10.2 seconds on my machine
I changed CoordinateList's getAt(int) from:
Coordinate CoordinateList::getAt(int pos)
moveTo(pos);
return get();
to:
if ((pos>vect->size()-1) || (pos<0) )
throw "Invalid argument: out of bounds\n" ;
else
current=pos;
return (*vect)[current];
This is *exactly* the same code, but I pulled the MoveTo() and get() into the function. This should only really save 2 function call overheads and one call to the copy constructor.
The results is 8.2 seconds. Thats 20% faster!!!
So, the CooridinateList is a pretty key code portion!
We could probably save a bunch more time by:
actually implementing the vector in the class (save a bunch of class calling overhead)
returning pointers instead of actual objects
I'd love to see the Copy Constructor called only 50,000 times for a 50,000 point input set.
dave
