[geos-devel] Coordinate & Coordinate list (20% faster now)
Norman Vine
nhv at cape.com
Thu Nov 14 19:18:04 EST 2002
David Blasby writes:
> I tested my theory:
> 50,000 points TestSweepLineSpeed
> takes about 10.2 seconds on my machine
> I changed CoordinateList's getAt(int) from:
> Coordinate CoordinateList::getAt(int pos)
> moveTo(pos);
> return get();
> to:
> if ((pos>vect->size()-1) || (pos<0) )
> throw "Invalid argument: out of bounds\n" ;
> else
> current=pos;
> return (*vect)[current];
> This is *exactly* the same code, but I pulled the MoveTo() and get() into the function. This should only really save 2 function
call overheads and one call to the copy constructor.
> The results is 8.2 seconds. Thats 20% faster!!!
> So, the CooridinateList is a pretty key code portion!
> We could probably save a bunch more time by:
> actually implementing the vector in the class (save a bunch of class calling overhead)
> returning pointers instead of actual objects
> I'd love to see the Copy Constructor called only 50,000 times for a 50,000 point input set.
> dave
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
