[geos-devel] Coordinate & Coordinate list (20% faster now)
Martin Davis
mbdavis at VividSolutions.com
Thu Nov 14 19:17:43 EST 2002
Excellent - shows we're on the right track.
I wonder how much ditching the use of vector really saves? Aren't most of the vector functions inlined? However, it should be pretty easy & secure to implement a coordinate array directly instead of a vector, so it's worth trying.
Martin Davis, Senior Technical Specialist
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> -----Original Message-----
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: Thursday, November 14, 2002 4:15 PM
> To: geos-devel at geos.refractions.net
> Subject: Re: [geos-devel] Coordinate & Coordinate list (20%
> faster now)
> I tested my theory:
> 50,000 points TestSweepLineSpeed
> takes about 10.2 seconds on my machine
> I changed CoordinateList's getAt(int) from:
> Coordinate CoordinateList::getAt(int pos)
> moveTo(pos);
> return get();
> to:
> if ((pos>vect->size()-1) || (pos<0) )
> throw "Invalid argument: out of bounds\n" ;
> else
> current=pos;
> return (*vect)[current];
> This is *exactly* the same code, but I pulled the MoveTo()
> and get() into the function. This should only really save 2
> function call overheads and one call to the copy constructor.
> The results is 8.2 seconds. Thats 20% faster!!!
> So, the CooridinateList is a pretty key code portion!
> We could probably save a bunch more time by:
> actually implementing the vector in the class (save a
> bunch of class calling overhead)
> returning pointers instead of actual objects
> I'd love to see the Copy Constructor called only 50,000 times
> for a 50,000 point input set.
> dave
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
