[geos-devel] Issue with returning Coordinate * rather than value
Norman Vine
nhv at cape.com
Fri Nov 15 12:56:26 EST 2002
David Blasby writes:
> > Coordinate *getAt(int i) /// Safe
> > Coordinate *[int i] /// DANGER !!!! super fast RAW access
> Yes - I like that. The getAt(int) should return a non-pointer or its should allocate a new
> Cooridinate and return that.
> Is the [int] method going to do range checking or are we just going to assume the caller is
> competent?
Good question :-)
I usually just have it return the underlying vector<> [] operator
if you want SAFE access DON'T use it !!
Norman
