[geos-devel] Another Portability Quirk
Paul Ramsey
pramsey at refractions.net
Sun Oct 6 22:44:34 EDT 2002
My GNU compilation us currently failing with an error of this sort:
Polygon.cpp:223: no matching function for call to `vector<Geometry *,
allocator<Geometry *> >::at (unsigned int &)'
With the offending code looking like:
for(unsigned int i=0;i<holes.size();i++) {
holes.at(i)->apply(filter);
I assume 'holes' is a 'vector' object from the STL and 'at()' is a
function name which does not exist in my GNU version of the STL.
P.
