[geos-devel] commit of automake/libtool support
Ferdinando Villa
fvilla at zoo.uvm.edu
Tue Sep 3 08:37:31 EDT 2002
Hi all,
I've just committed the following changes. Let me know if there's any
problem associated with them. Ciao f
* Add automake/autoconf support for one-lib compilation
* add libtool support for shared libraries. --enable-shared={yes|no} and
--enable-static={yes|no} control static and shared lib generation.
* Makefile.in and configure files added to cvs (for users without
automake)
* add dir macros/ with a GEOS_INIT macro to be used in configure.in
of other packages using geos (not used by geos itself)
* add dir tools/ with geos-config script
* the makefile in source/geom is the only one that generates a
library - all others have the source files in EXTRA_DIST only
* small glitch: 'make dist' will give errors trying to add the
source files non local to source/geom to the archive using relative
paths. Does not have consequences other than the error messages - will
see if I can fix this. In general the one-lib, complex-tree solution
is not
easy to work with in automake.
ferdinando villa, ph.d. associate professor
gund institute for ecological economics, university of vermont
590 main street, burlington, vt 05405 phone: (802) 656-2972
