[geos-devel] Portability
Norman Vine nhv at cape.com
Fri Sep 13 08:58:20 EDT 2002
Hi All,
Ferdinando's libtoolizing seems to work well for me, with
only minor modifications, on Cygwin and Mingw32, however
I haven't had much joy trying to get this to compile with either
 gcc version 2.95.3-10 (cygwin special)
   or the MUCH more  standard compliant but pickier
 gcc version 3.2 (mingw special 20020817-1)
If I can be so bold migh I suggest that the MSVC developers 'try'
compiling this using the STL_PORT Library occasionally :-)
Another suggestion is that we use the C++ namespace feature.
I think that this would greatly enhance the usability of this code
esp. given the 'reasonably common' classnames that are being
used
Cheers
Norman
