[geos-devel] Status (New Example)
Norman Vine nhv at cape.com
Sun Apr 6 09:47:10 EDT 2003
David Blasby writes:
> I've attached 2 files - a .cpp wrapper for geos and a little .c program.
>  Basically it passes a string to the
> wrapper (test.cpp) that turns it into a Geometry.  The resulting
> Geometry is wrapper in a GeometryWrapper
> and returned to the C program.  The C program then passes the
> GeometryWrapper to the .cpp library
> and asks it to return a string (char *) representation.  Really simple,
> but it doesnt work.
HTH
Norman
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030406/c83f7af9/geos_api.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030406/c83f7af9/test.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030406/c83f7af9/test_cpp.obj
