[geos-devel] Status (New Example)
Norman Vine nhv at cape.com
Sun Apr 6 10:11:07 EDT 2003
Let me try that again I cleaned up to much of
my debugging 'cruft' from my earlier files
Norman
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net]On Behalf Of Norman Vine
> Sent: Sunday, April 06, 2003 9:47 AM
> To: GEOS Development List
> Subject: RE: [geos-devel] Status (New Example)
> David Blasby writes:
> > I've attached 2 files - a .cpp wrapper for geos and a little .c
> program.
> >  Basically it passes a string to the
> > wrapper (test.cpp) that turns it into a Geometry.  The resulting
> > Geometry is wrapper in a GeometryWrapper
> > and returned to the C program.  The C program then passes the
> > GeometryWrapper to the .cpp library
> > and asks it to return a string (char *) representation.  Really simple,
> > but it doesnt work.
> HTH
> Norman
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030406/a032aba7/geos_api.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030406/a032aba7/test.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20030406/a032aba7/test_cpp.obj
