[geos-devel] problems with C/C++- getting warmer! (Reader Frees
toomuch?)
David Blasby
dblasby at refractions.net
Mon Apr 7 17:08:14 EDT 2003
Norman Vine wrote:
>David Blasby writes:
>>Norman,
>> Could you give this little C++ code a try? Then try it again
>>without the "delete r; delete w;" lines commented out.
>>On my linux system, it works with the 2 lines commented out, but fails
>>with them actually in. More specficially it
>>fails if the reader (r) is deleted.
>Sure this works OK albeit but will leak a bit of memory
I'm not advocating not deleting the reader - but its obviously a big
hint as to why I'm having troubles. I'm looking at the Readers code now.
