[geos-devel] BUG: relate(g1,g2) crashes with GEOMETRYCOLLECTION?
Paul Ramsey
pramsey at refractions.net
Tue Apr 8 16:55:47 EDT 2003
G definitionally does not overlap itself if it is a
geometrycollection??? Maybe this was a typo and not an actual decision
on the part of the drafters?
On Tuesday, April 8, 2003, at 01:51 PM, Martin Davis wrote:
> Yep, overlaps(G,G) = false according to the OGC spec. This may be a
> bit counter-intuitive. Not sure what the rationale behind this
> decision was.
> I usually use A.relate(B, "T********") to determine if things overlap
> "properly".
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
>> -----Original Message-----
>> From: David Blasby [mailto:dblasby at refractions.net]
>> Sent: Tuesday, April 08, 2003 1:43 PM
>> To: GEOS Development List
>> Subject: Re: [geos-devel] BUG: relate(g1,g2) crashes with
>> GEOMETRYCOLLECTION?
>> Martin Davis wrote:
>>> Yep. Neither GEOS nor JTS support GeometryCollections as
>> arguments to relate. This is partly because the semantics
>> aren't very well defined, and partly because the obvious
>> semantics [ X.relate(GC) = X.relate(union(GC.components) ]
>> would make the operation non-robust.
>>> That said, we or you could always implement the above
>> semantics fairly easily...
>> Its unfortunate that the spec doesnt tell you what to do in
>> the case of
>> GEOMETRYCOLLECTIONs.
>> I've also noticed that overlaps(g,g) is FALSE!
>> dave
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
