[geos-devel] Debugging results on Solaris
Carsten Neumann CarstenNeumann at web.de
Thu Apr 17 07:12:38 EDT 2003
I have recompiled the library with "-g" and now at least some of the test
run fine (XMLTester, CTS). The others still fail.
> autoheader-1.6
> automake-1.6 --add-missing --gnu
> autoconf
> configure CXXFLAGS="-g" CFLAGS="-g"
> make
bash-2.03$ gdb .libs/SimpleWKTTester
This GDB was configured as "sparc-sun-solaris2.8"...
(gdb) run
Starting program:
/home/neumancn/nexus/src/geos/source/test/.libs/SimpleWKTTeste
r
Start Testing:
Program received signal SIGSEGV, Segmentation fault.
0xff29aa6c in _ZN9WKTReader14getCoordinatesEP15StringTokenizer (
    this=<incomplete type>, tokenizer=0x230b0) at ../io/WKTReader.cpp:32
32              CoordinateList
*coordinates=CoordinateListFactory::internalFacto
ry->createCoordinateList();
(gdb) bt
#0  0xff29aa6c in _ZN9WKTReader14getCoordinatesEP15StringTokenizer (
#1  0xff29cb58 in _ZN9WKTReader18readLineStringTextEP15StringTokenizer (
    this=<incomplete type>, tokenizer=0x230b0) at ../io/WKTReader.cpp:155
#2  0xff29c55c in _ZN9WKTReader22readGeometryTaggedTextEP15StringTokenizer (
    this=<incomplete type>, tokenizer=0x230b0) at ../io/WKTReader.cpp:125
#3  0xff29a814 in _ZN9WKTReader4readESs (this=<incomplete type>,
    wellKnownText={static npos = <incomplete type>,
      _M_dataplus = {<allocator<char>> = {<No data fields>},
        _M_p = 0x29a14 "LINESTRING(40 40, 50 130, 130 130)"},
      static _S_empty_rep_storage = {0, 0, 1, 0}}) at ../io/WKTReader.cpp:20
#4  0x11744 in main (argc=1, argv=0xffbef4f4) at SimpleWKTTester.cpp:27
bash-2.03$ gdb .libs/CTS
(gdb) run
Starting program: /home/neumancn/nexus/src/geos/source/test/.libs/CTS
Start:
End
Program exited normally.
bash-2.03$ gdb .libs/XMLTester
(gdb) run
Starting program: /home/neumancn/nexus/src/geos/source/test/.libs/XMLTester
Precision Model:
Failed: 0
Succeeded: 0
End Test
bash-2.03$ gdb .libs/CoordinateListsExample
(gdb) run
Starting program:
/home/neumancn/nexus/src/geos/source/examples/.libs/Coordinate
ListsExample
Start:
0x11824 in main (argc=1, argv=0xffbef4e4) at CoordinateListsExample.cpp:17
17              CoordinateList
*cl1=CoordinateListFactory::internalFactory->crea
teCoordinateList();
(gdb) bt
#0  0x11824 in main (argc=1, argv=0xffbef4e4) at
bash-2.03$ gdb .libs/CustomCoordinateListExample
(gdb) run
Starting program:
/home/neumancn/nexus/src/geos/source/examples/.libs/CustomCoor
dinateListExample
Start:
CoordinateList cl: (11,11,1.7e-308) (140,200,1.7e-308) (240,200,1.7e-308)
(55,55
,1.7e-308) (140,120,1.7e-308)
CoordinateList cl: (140,120,1.7e-308) (140,200,1.7e-308) (240,200,1.7e-308)
(240
,120,1.7e-308) (140,120,1.7e-308)
Geometry:
POLYGON ((140.0000000000000000 120.0000000000000000, 140.0000000000000000
200.00
00000000000000, 240.0000000000000000 200.0000000000000000,
120.0000000000000000, 140.0000000000000000 120.0000000000000000))
0xff2b3efc in
_ZN22GeometryGraphOperation23setComputationPrecisionEP14PrecisionM
odel (this=<incomplete type>, pm=0x2bc08)
    at ../operation/GeometryGraphOperation.cpp:27
27              li->setMakePrecise(makePrecise);
(gdb) bt
#0  0xff2b3efc in
ionModel (this=<incomplete type>, pm=0x2bc08)
#1  0xff2b3b90 in _ZN22GeometryGraphOperationC2EP8Geometry (
    this=<incomplete type>, g0=0x2cb10)
    at ../operation/GeometryGraphOperation.cpp:16
#2  0xff2c4420 in _ZN9IsValidOpC1EP8Geometry (this=<incomplete type>,
    g=0x2cb10) at ../operation/valid/IsValidOp.cpp:22
#3  0xff26a434 in _ZN8Geometry7isValidEv (this=<incomplete type>)
    at Geometry.cpp:121
#4  0x1519c in main (argc=1, argv=0xffbef4dc)
    at CustomCoordinateListExample.cpp:56
___________
Carsten
