Carsten Neumann writes: > > I have recompiled the library with "-g" and now at least some of the test > run fine (XMLTester, CTS). The others still fail. Carsten OK we can see where the programs are failing now we just have to figure out why :-) What compiler are you using ?? % gcc --version Thanks Norman
