[geos-devel] latest geos cvs breaks on make
Norman Vine
nhv at cape.com
Sat Aug 16 15:37:34 EDT 2003
Heitzso writes:
> (note this is after deleting references to examples tree
> from configure and configure.in)
> ./configure
> make
> fails with the following message:
> source/geom/Makefile.am:
> required file './depcomp' not found
> Am I missing something or is the cvs tree unstable
> at the moment?
Since you are working with developer files and not a 'release'
you are expected to unerstand the gnu autotool system :-)
i.e
aclocal, automake libtool and friends
Probably easiest to just run the included autogen.sh script
which should just do the right things for you
For some background info see
http://sources.redhat.com/autobook/
and thread starting here
http://postgis.refractions.net/pipermail/postgis-users/2003-August/002852.html
HTH
Norman
